  1. His is the early series which has both the cam and crank sensor. You in the late series like myself where the cam sensor was dropped and the crank sensor was moved to the cam sensor location. Sounds confusing. 98.5 to 99 had a single tooth tone wheel on the cam. Then the actual tone wheel like you see on the crank for tach signal. 00 to 02 had ditch the single tooth cam gear and then replace the gear with a multi-tooth and the sensor location was moved inward on the cam gear. The crank tone wheel was ditch completely. Now the ECM wiring for the crank sensor is the same pin on the ECM as the late series cam sensor. All years used the pin 17 on the ECM for tach signal. Pin 9 was the early Cam sensor which was dropped and no longer used.
  2. Nothing to core out. The circuit board is mylar and it glued directly to the aluminum cover. If it burnt or damaged there is nothing to core out.
  3. 174k on stock injectors I'm sure they are shot. Popping below 293 bar.
  4. Lot of instructions call for the test port but it's a invalid reading. Stale fluid that is not flowing. Most transmission builders call for putting a bung in the pan. Most guys on forum like the hot line heading to the cooler.
  5. Best I can say is have your ECM tested. Grab the rebuild list and pick one.
  6. Ummm... Sensor suppose to be either in the hot line going to the cooler. Or... Suppose to be in the pan. Test ports are invalid. Not flowing fluid.
  7. @Auto Computer Specialist is one of the vendors here. You might want to look them up.
  8. Weather is OK down here. Funny I made my 8.2 mile ride and just started to snow on me within about 1/4 mile from my truck.
  9. Ontario, OR. Clean and clear. Snow line is about 2,500 feet and Ontario is just below that. Damn stupid people. Everyday dealing with a dumb driving along at 20 MPH in panic mode. Please people put you Toyota Prius away and get your 4WD your pickups out.
  10. Heck if your close enough come to my shop, ill break out the beer, and get it done. But you already this far along.
  11. Gets better for me... Time to turn down the Quadzilla to Level 3 and keep the tires under the truck. From what I can see the snow goes from Pollock, ID to Weiser, ID and the roads are snow covered. It's going to be a long day for me.
  12. Edge Products and Quadzilla ZERO impact. All it does insert commands on the CANBus with high priority and has no impact on the ECM. ECM has no clue the tuner is even there. Now Smarty or any flash tuner puts stress on the EPROM which has a finite number of times it can be flashed. Then if the flash goes wrong you can make a mess out of the ECM that requires reflashing or replacement. Smarty and SuperChips wipe out all the ECM software and reflash with completely different software. Addon... Like my combo of the Quadzilla Adrenaline and the 7 x 0.010 injectors, this reduces the stress on the VP44. Being my idle engine load is about 13% and then my cruising 60 MPH engine load is only 17%. I'm not down to running Level 3 (No wiretap) which is the cleanest overall runs with the same power as stock injectors and Edge Comp with about 35 PSI of max boost.
  13. That also happened with ITD (Idaho turbo Diesels) they also had a Bomb party too and had guys attempting to steal tools, free work, and at dyno events attempting to get free dyno runs.
  14. Quadzilla Adrenaline, Edge Products, no. They do not leave a footprint. Smarty is a possible footprint but they claim it undetectable.
  15. @Alterego could I get you to write an article about the tone ring install? I'll make it worth your while.
  16. I think some good gains can be had with ecomony and smoke control with added pop pressure. I will admit the flow rate is reduced I'm pretty sure of that.
  17. I've a got a membership over there but wasn't fond of the members...
  18. Get that alternator tested if it fails replace it.
  19. No. Engine won't run without a tach signal. No. There is no way to fool the crank sensor. Naw... I'll drop a bolt in your manifold...
  20. I would pull that alternator and have it bench tested to verify that its failed for sure. Then it would be time to look towards an alternator replacement. I would disconnect the field lead on the back and go for a test drive and see if the problem goes away. If not you might be looking at having that ECM verified being it might already be damaged from the AC noise.
  21. Looks like the insert came out and rest got damage as it got slung off the crank. Make sure you index that gap section right.
  22. P0087 - Fuel Rail Pressure Too Low Special Tools: Click to display a list of tools used in this procedure When Monitored and Set Conditions When Monitored: This diagnostic runs continuously when the following conditions are met: • With the engine running. Set Conditions: • The Powertrain Control Module (PCM) detects that the actual fuel pressure reading is below a calibrated threshold. This DTC will cause active regeneration to be disabled. Default Actions: • The MIL is illuminated. Possible Causes P000F PRESENT EXTERNAL FUEL LEAKS GELLED FUEL NO VOLTAGE AT CHASSIS MOUNTED FUEL HEATER NO VOLTAGE AT ENGINE MOUNTED FUEL HEATER CHASSIS MOUNTED FUEL HEATER-FUEL FILTER ENGINE MOUNTED FUEL HEATER-FUEL FILTER HIGH PRESSURE PUMP INJECTOR LEAKAGE IN TANK LIFT PUMP FUEL PRESSURE LIMITING VALVE Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 28 - DTCBased Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 1. P000F PRESENT 1. Ignition on, engine not running. 2. With the scan tool, read DTCs. Is DTC P000F active? Yes • Perform the Diagnostics for DTC P000F first. • If DTC P0087 is still active or pending after the P000F Diagnostics is completed, begin this Diagnostic Tree again. No • Go To 2 2. CHECK FOR OTHER DTCS 1. With the scan tool, read DTCs. Are any other injector/fuel pressure related DTCs present? Yes • Troubleshoot other injector/fuel pressure related DTCs first. No • Go To 3 3. CHECK FOR EXTERNAL FUEL LEAKS 1. Put on personal protective equipment. 2. Operate engine at idle when looking for fuel leaks. 3. Use the scan tool to operate engine at a variety of engine speeds. Any external leaks detected? Yes • Repair or replace component with external fuel leak. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 4 4. CHECK OPERATING CONDITIONS 1. Determine the environmental conditions at or near the time the DTC set. Has the vehicle been operated or cold soaked in ambient temperatures below freezing? Yes • Go To 5 No • Go To 7 5. CHECK FOR GELLED FUEL/PERFORM THE IN-TANK LIFT PUMP FLOW TEST NOTE: Before performing the IN-TANK FUEL LIFT PUMP FLOW test, verify that the fuel level in the fuel tank is above 1/4 full. If fuel tank is not above 1/4 full the pump will take in air causing the test results to be inaccurate. 1. Disconnect the low pressure fuel supply line from the High Pressure Fuel Pump. Connect the Decay Tool, Fuel 8978A to the low pressure fuel supply line. WARNING: To reduce the risk of fire and serious possible serious or fatal injury, place the Reservoir Assembly 534960 (3) on the floor and out of the way so that it is not a trip hazard. 2. Perform the following to purge air from the system: • With the scan tool, actuate the In-Tank Fuel Lift Pump Module. • Open the Flow Test Valve and allow the fuel to flow into the Reservoir for 10 seconds, then close the Flow Test Valve. • Turn the ignition off. • Disconnect, empty, and then reconnect the Reservoir Assembly. 3. Perform the following three times to find the average flow rate: • With the scan tool, actuate the In-Tank Fuel Lift Pump Module. • Open the Flow Test Valve (1) for 10 seconds, then close the Valve. • Turn the ignition off. • Measure and record the amount of fuel in the Reservoir Assembly. • Disconnect, empty, and then reconnect the Reservoir Assembly. 4. Add the three recorded measurements and then divide the total by three to calculate the average flow rate. NOTE: The flow rate specification is 500 ml in 10 seconds. Does the average flow rate meet or exceed the specification? Yes • If the vehicle exhibited symptoms related to fuel gelling such as hard start, start and stall, and/or low power, but no longer exhibits these symptoms, fuel gelling may have been present but corrected itself. The fuel temperature may have increased through normal operation or if the vehicle was parked inside a warm building. Verify both fuel heaters are receiving power with the ignition on, and also check for proper operation of the fuel heaters. (Refer to 14 - Fuel System/Fuel Delivery, 6.7L Diesel/HEATER, Fuel/Diagnosis and Testing) . • Then, Go To 7 No • Leave the Fuel Decay Tester installed. Remove both fuel filters and inspect for fuel gelling/wax build-up and other contaminants. If wax build-up is found, the fuel has gelled. Replace both fuel filters and correct the fuel gelling accordingly before any further testing. Verify both fuel heaters are receiving power with the ignition on, and also check for proper operation of the fuel heaters. (Refer to 14 - Fuel System/Fuel Delivery, 6.7L Diesel/HEATER, Fuel/Diagnosis and Testing) . • If no wax build-up or signs of fuel gelling is found, replace both Fuel Filter/Water Separators in accordance with the Service Information. • Then, Go To 6 6. RECHECK IN-TANK FUEL LIFT PUMP FLOW 1. Perform the following to purge air from the system: • With the scan tool, actuate the In-Tank Fuel Lift Pump Module. • Open the Flow Test Valve for 10 seconds, then close the Valve. • Turn the ignition off. • Disconnect, empty, and then reconnect the Reservoir Assembly. 2. Perform the following three times to find the average flow rate: • With the scan tool, actuate the In-Tank Fuel Lift Pump Module. • Open the Flow Test Valve for 10 seconds, then close the valve. • Turn the ignition off. • Measure and record the amount of fuel in the Reservoir Assembly. • Disconnect, empty, and then reconnect the Reservoir Assembly. 3. Add the three recorded measurements and then divide the total by three to calculate the average flow rate. NOTE: The flow rate specification is 500 ml in 10 seconds. Does the average flow rate meet or exceed the specification? Yes • Repair complete. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Use the wiring diagram as a guide to check the In-Tank Fuel Lift Pump wiring for an open, high resistance, or short to ground. If the In-Tank Fuel Lift Pump wiring is okay, remove the fuel tank and replace the In-Tank Fuel Lift Pump Module in accordance with the Service Information. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 7. CHECK THE FUEL DELIVERY SYSTEM 1. (Refer to 29 - Non-DTC Diagnostics/Drivability - Diesel - Diagnosis and Testing) and perform the CHECKING THE FUEL DELIVERY SYSTEM diagnostic procedure. Were any problems found? Yes • Repair as necessary. No • Perform the INTERMITTENT CONDITION diagnostic procedure. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure).
