  1. Nope, you are good. Mine started at 13% and now down to 9% engine load at idle. When you dropping to 3 to 4% when it's getting too low.
  2. That's what we are here for is help out the best we can. After lunch time today I'm going out to do a test run myself on the tune I just released.
  3. @TheGreatWhite You might want to read over this too. Might edit that up and define what a big injector tune really is... Suggestion.
  4. Hmmm... The best I can say is look at my mod list done all this myself. There are 3 pages of modifications I've done. https://mopar1973man.com/garage/vehicle/101-2002-dodge-ram-2500/?show=mods
  5. Another thing to point out is levels of power. Level 2 is only 0 to 100% fuel no added fuel above stock. Level 3 is only CANBus fuel table. Level 4 is Wiretap on up which can be divided up for as many levels up.
  6. https://www.amazon.com/UGREEN-Charging-Controller-Players-Receiver/dp/B00P0GI68M/ref=sr_1_1_sspa?crid=1E3VLKQW3QHPF&keywords=mini+usb+cable&qid=1552062277&s=gateway&sprefix=mini+usb%2Caps%2C251&sr=8-1-spons&psc=1 Unless this is the first time he really heard the turbo spool. (Just kidding...)
  7. No. The only tool that would is the DRBIII tool from the dealer. I'm going to say start with the update. We don't know what version you are starting from. This just levels the playing field. I'm going to bet the APPS is fine but the flash is old version on the Quadzilla.
  8. The current release of the flash update. Yes. Because there is no free rev fuel and timing table. Free revving needs a fairly steep timing curve to do it. Quadzilla team didn't see a reason for free timing table and left it out. Well, that is half of it. The other half is the IVS switches. (Idle Validation Switches) will ground when they are in their particular mode. The idle state will ground the idle leg and then flip-flop and ground the throttle pin when not in an idle state. Typically I check by my exhaust brake or high idle kit for that. If the exhaust brake works then the IVS is hitting the idle state. High Idle is the same way if the IVS is in the idle state then it should engage high idle modes.
  9. Did you update the Quadzilla box to current software? I would suggest making sure the new board is up to date first. There is no free rev fuel table. The timing is not designed to free rev. Simple solution, don't free rev the engine. Might check the fuel table for a slider that is smooth in the curve like one that is bottom out. Now make sure your APPS is actually making it to idle state. When the APPS is at idle state the ECM is direct control of the idle speed and the Quadzilla is ignored. Quadzilla should not come to action till after 1,000 RPM.
  10. Oh no! @IBMobile heading for @JAG1 place... Not good. Bad things happen when these two get together.
  11. Pacific North West
  12. Welcome to the family of Cummins nuts. I love to joke around too. You'll find other members poke fun at each other as well. You'll fit in just fine as well.
  13. Exactly. That's the problem...
  14. Dual disc clutch do not spin down fast enough. Too much rotational mass. Fluids really aren't going to change that much.
  15. All the wire maps... https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/electrical/
  16. Go through the pages I've linked to and do the diagnostics and clean up the issues.
  17. OMG... Geez, you guys are a tough crowd.
  18. Oh damn... P0577 I don't have but... https://www.obd-codes.com/p0577
  19. What error codes do you see? Did you ohm out your wiring? Did you check for 5V signal from the ECM?
  20. I've thought of stuff like this but not sure what kind of possible sales we could have.
  21. I'm not cheating... See its all there. No trap door.
  22. P0106 - Manifold Absolute Pressure Sensor Performance Theory of Operation The Charge Air Cooler Temperature Sensor (CAC) and the Boost Pressure Sensor are combined in one sensor. This combination sensor is called the Temperature/Pressure MAP Sensor. It is located on the EGR Airflow Throttle Control Valve on the Regular Cab. For the Cab and Chassis, it is located on the Intake Manifold. The Cab and Chassis version also receives the Intake Manifold Temperature signal. The Regular Cab still has a separate Intake Manifold Temperature Sensor. The Boost Pressure Sensor is used to measure pressure in the intake manifold. The Powertrain Control Module (PCM) provides a 5-Volt supply and sensor ground for the Boost Pressure Sensor. The Boost Pressure Sensor provides a signal back to the PCM on the Boost Pressure Sensor Signal circuit. The PCM will detect a low signal voltage at operating conditions such as during an idle or a deceleration. The PCM will detect a high signal voltage during high engine load operating conditions. At key on, the readings for the Boost Pressure Sensor, Exhaust Gas Pressure Sensor, and Barometric Pressure Sensor are compared. This fault code occurs if the boost pressure reading is different from the others. During normal engine operation, the PCM estimates the Boost Pressure Sensor value using other fuel system related inputs. The PCM compares the actual Boost Pressure Sensor reading to this estimated value. If the two values are out of range for a calibrated period of time, an error is recorded. When Monitored and Set Conditions When Monitored: This diagnostic runs continuously when the following conditions are met: • With the Engine running. Set Conditions: • The Powertrain Control Module (PCM) has detected the Inlet Air Pressure Sensor value or the boost pressure reading is not within a calibrated threshold. Default Actions: • The MIL is illuminated. Possible Causes INTAKE AIR SYSTEM LEAK EGR AIRFLOW THROTTLE CONTROL VALVE PLUGGED AIR FILTER TEMPERATURE/PRESSURE MAP SENSOR Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 28 - DTCBased Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 1. ACTIVE DTC NOTE: If DTCs P0107 or P0108 are present, repair those DTCs before proceeding. NOTE: If there are any EGR Valve or EGR Airflow Control Valve DTCs present, repair those DTCs before proceeding. NOTE: If customer states that there was an EVIC message "Service Air Filter", or if Freeze Frame Data shows "Air Filter Plugged Error equals ON", replace the Air Filter before continuing. 1. Turn the ignition on. 2. With the scan tool, record all Freeze frame data. 3. With the scan tool, erase DTCs. 4. Turn the ignition on for 75 seconds. 5. Start the engine and let idle. 6. With the scan tool, read DTCs. Did the DTC return? Yes • Go To 2 No • Perform the INTERMITTENT CONDITION diagnostic procedure. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 2. CHECK FOR AN INTAKE AIR SYSTEM LEAK 1. Perform the INTAKE AIR SYSTEM PRESSURE TEST. (Refer to 29 - Non-DTC Diagnostics/Drivability - Diesel - Diagnosis and Testing) Where any leaks found? Yes • Repair the leak and perform a Mobile Desoot of the aftertreatment system. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Leave the Air Inlet Tube disconnected. Go To 3 3. TURBOCHARGER 1. Inspect the impeller gear on the turbocharger for damage or broken teeth. Was there any damage found? Yes • Replace the Turbocharger assembly in accordance with the service information. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Go To 4 4. CHECK THE EGR AIRFLOW THROTTLE CONTROL VALVE 1. Remove the boot from the EGR Airflow Throttle Control Valve. 2. Using a mirror, look at the butterfly valve on the inside of the EGR Airflow Throttle Control Valve. 3. Start the vehicle, let idle for 10 seconds. 4. Turn the ignition off. NOTE: If functioning properly the EGR Airflow Throttle Control Valve will cycle closed immediately after the engine is shut down. Did the EGR Airflow Throttle Control Valve cycle closed immediately after the engine was shut down? Yes • Go To 5 No • Replace the EGR Airflow Throttle Control Valve in accordance with the Service Information.(Refer to 25 - Emissions Control/Exhaust Gas Recirculation, Diesel/VALVE, Exhaust Gas Recirculation (EGR) Airflow Control/Removal) • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 5. TEMPERATURE/PRESSURE MAP SENSOR 1. Turn ignition switch on. Wait five seconds after ignition switch is turned on. 2. Using the scan tool, read DTCs Is P0106 stored? Yes • Go To 6 No • Replace the Temperature/Pressure MAP Sensor in accordance with the Service Information.(Refer to 14 - Fuel System/Fuel Injection/SENSOR, TMAP-Intake Manifold/Removal) • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). 6. TEMPERATURE/PRESSURE MAP SENSOR 1. Erase the DTC with the scan tool. 2. Start the engine and let it idle for one minute. 3. With the scan tool, monitor the boost pressure reading. Does the Boost Pressure Sensor fluctuate slightly, indicating the sensor is not stuck? Yes • Repair complete. • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure). No • Replace the Temperature/Pressure MAP Sensor in accordance with the Service Information.(Refer to 14 - Fuel System/Fuel Injection/SENSOR, TMAP-Intake Manifold/Removal) • Perform the POWERTRAIN VERIFICATION TEST - 6.7L. (Refer to 28 - DTC-Based Diagnostics/MODULE, Powertrain Control (PCM) - Standard Procedure).
  23. Adjust your throttle valve cable. Make it a bit less pull and this will lighten up more.
  24. These number are just the sizes of the wheels. Compressure wheel is 62mm Turbine wheel is 67mm Exhaust housing is 12cm2 in the opening. VS. Compressure wheel is 62mm Turbine wheel is 68mm (+1 mm) Exhaust housing is 12cm2 in the opening.
