  1. That's exactly right. Need to figure out what caused the failure. Other than that you'll continue to replace ECM and get frustrated.
  2. You should try the Smarty touch. Quadzilla V2 is a breeze compared to Smarty Touch. Smarty Touch is even more complicated and cost 3 times as much ($1,724) as a Quadzilla sad part is it still only a +60 HP tuner (some say 100 HP). https://smartysupport.com/store/product/9-smarty-touch-kit/ For right now stay to Level 3 till you get the CANBus fixed up and timing set for what you got then you can play with the wiretap. Like I'm still testing and tweaking my latest tune. It doesn't happen overnight. You got to put the truck through its paces and fix the tune as issues are found. Like just tuning the server here on the website it doesn't just happen. It takes time and testing to find all the bugs and set the server up correctly.
  3. The light next to the turn signal marker will operate as a hi/lo beam. The othe bulb towards the grille is only high beam. It has its own relay and fuse. Here you go...
  4. Slowly working at converting my truck all over to LED. So far everything I've done I've been seriously happy with. There is one mod I'm trying to plan out for is doing footwell lighting for the truck. Always happens at some point at night you drop something flip on the interior light bend over and now cast a shadow on the floor for what you're looking for. I'm going to work at the under hood light and the rear cab brake light as well.
  5. WARNING: Spacers are a very very bad idea. Not a safe way to mount wheels to axles that don't properly fit.
  6. You could but... He's got a point you need to have some info. ACS will at least bench test it before starting. You can call them and ask about the WTS light issue and dying out.
  7. ECM's are like a PC. It's got a hard drive (EPROM), BIOS that tells the CPU to boot the EPROM. CPU and Memory to run the software. So when there is issues either the WTS light doesn't come on or it flashes to note issues. I highly suggest you don't swap ECM's there is about 52 version of software per YEAR. I would suggest just having your current ECM repaired and put back into service this way there is less problems with software issues. I've seen issues where a swapped ECM refuses to talk to the PCM because of software differences. I've seen all kinds of weird issues with swapped ECM's.
  8. Bingo... It's taken me over 3 years to learn what Quadzilla can do... Don't expect to learn to tune overnight and have the perfect truck in seconds.
  9. Let it drip. Catch can just make a bigger mess. When it fills up and sloshes around. Never worked in the front of the engine why would it work on the back of the engine. Still a broken idea.
  10. The truck will function without an IAT sensor. You can delete the grid heater all together still start and run normally. Common in the south. All the important ground are hooked to the passenger side ground terminal. Flashing WTS light is a bad news deal that points to internal ECM problem. Booting issue or EPROM issues. Mostly caused by excessive AC noise from the alternator.
  11. I don't suggest EZ because of circuit board issues. There known for water getting in the module and failing. If you going this route don't go above RV275's. That will be the cleanest you can do. Oh, be aware early series of ECM don't like being flashed too much with a Smarty S03. Some ECM's have been known to fail. Then you take the risk of being locked out and not being able to start your truck then have to pay $150 buck to recover your ECM. One of the few Smarty issues it does happen.
  12. You'll be stuck with stock injectors. Can't adjust timing or fuel maps. Quadzilla Adrenaline and Smarty Touch are the only two tuners that allow for cleaning burning 7 x 0.010 injectors. Edge Juice and Edge Comp are very dirty with +50 HP and above. I've got an Edge Comp and its a smoke bomb with 7 x 0.010. It was a smoke bomb with 7 x 0.0085 injectors. Canned tuners are junk on anything bigger than stock. Timing is for sure wrong fuel map way too smoky. I'll admit on stock and RV275's wasn't bad. Starts getting smoky with +50 HP. There is no way to use large injectors on Edge product. S03 is also stuck to fair small injectors and very limited timing control. If you ever got down here to Idaho I'd straighten that out in a mere few minutes.
  13. Change the Maximum fuel stretch down towards 1,200. TPS Max should be 100 TPS Min should be 0 Minim pump tap fueling should be 0 Pump low boost scale PSI go from 10 up towards 15 Boost scaling should be 40 Another is number of power level change it from 7 to 11. Now turn down the power level to mellow the hit. Try a Smarty Touch it's even more complex and crazy.
  14. ECM internal error. Most likely going to require sending the ECM for repair.
  15. It's been so long ago I forgot what it was.
  16. Awesome idea for people that randomly drive their trucks.
  17. No issues here 2 / 6 Amp charger never bothered the Quadzilla.
  18. That matting does nothing for sound. It does make great mouse bedding all over your engine. Then if you have an oil leak it soaks up oil and the sags down on the engine. It is great for dumping tons of dust and dirt in your valve train when you are doing valve lash or injectors. On both trucks, the hood mat came out and the firewall mat came out. No loss...
  19. No fuse or relay in the stock ECM fuel pump control. The FASS should have its own fuse and relay setup.
  20. Thief - This is a hold-up. Trreed - Let me go back to my truck and unlock my gun so I can shoot you. Thief - "BANG" Trreed - .... A locked up weapon is worthless. A weapon left behind in your vehicle is worthless. A weapon locked up in a gun safe is worthless. Average 911 response time here in my area is better than 1 hour. You better be able to hold your own for at least 1 hour.
