  1. At least on the 24V the alternator charge line runs beside the ground for the PCM, ECM and VP44. Creates that issue. Being the 12V doesn't have a ECM and VP44 PSG those are out. But as for grounding of the PCM I'm not sure.
  2. That's the whole problem to measure at the time of the problem. You could just have the alternator bench tested.
  3. Now measure at highway speed. Start watching when the TQ conv starts hunting.
  4. Ask @Me78569 about his Spicer ball joints...
  5. I changed them early at 30k miles. Yea I need to leave them in longer. I'm changing too early at 30k miles. Factory rate 15k miles is like fresh out the box yet. Running good ol' petroleum diesel. Mostly from Maverik Fuel Stations here on the west side.
  6. Just select the normal front amber bulb then. https://www.superbrightleds.com/moreinfo/front-sidemarker-light-bulb/3156-3157-ck-led-bulb-dual-function-27-smd-led-tower-wedge-retrofit/3557/7522/?year=2002&make=22&model=1351&scc_id=1396 Here you go. https://www.superbrightleds.com/moreinfo/back-up-light-bulb/3156-3157-ck-led-bulb-dual-function-27-smd-led-tower-wedge-retrofit/3557/?year=2002&make=22&model=1351&scc_id=1427 Actually once outside in bright daylight not bad.
  7. AC noise from the alternator affects all sensors with speed. Like tachometer, output speed sensor, ABS speed sensors, etc. The bad part is the only tool that can see the noise is o-scope.
  8. Alternator noise issue possibly. Here is the fix for the 24V I'm not sure how it will pan out for the 12V.
  9. I highly suggest not to do a sump. If you do you take a huge risk at ruining a fuel tank there is already been a few members here done a sump and ended up replacing a fuel tank from leaking. Not to mention there are issues law wise about bottom draw tanks which may not be DOT legal. might be fine for the track but I do not suggest it on the highway. Not to mention more fuel line exposed to cold air blowing under the truck and greater chance of gelling up.
  10. Ahh... Opps... Ok he need to upgrade..
  11. That because New Venture went out of business after 124 years. There are very few cores left in the world so the core prices are even monster high. https://en.wikipedia.org/wiki/New_Venture_Gear More on the article of the shut down. https://www.syracuse.com/news/index.ssf/2012/08/new_process_gear_closes_this_w.html
  12. Set the warmup mode temperature. Like I've got 170*F for this setting. Then you need to set the high idle delay time which I've got 15-second delay. Warning don't run the Quadzilla high idle with the factory high idle on the ECM enabled. If for chance the 3 CYL mode is kicked in while the Quadzilla running 6 CYL it will create a heck of a problem.
  13. Sounds like it. This is one of the problems of "Canned Tuners" as you keep upgrading the truck with different turbos and injectors the canned tune no longer fits correctly. Just the mere fact of the injectors wearing out and pop pressure falling off will require adjustments to the tune to keep it running efficiently.
  14. The play is most likely the pump. What you'll need to do is pull the belt and check the shaft play for the pump. If the pump is the problem make sure to flush the system BEFORE removing the old pump. This will flush the system of any debris before installing the new pump.
  15. Tap point -> Needle valve -> Snubber -> 5 to 7 feet of tubing -> Fuel pressure sensor.
  16. Absolutely. Even on low the new Ford truck suck. Horridly bright and always in your face. Must be that Ford squatting problem.
  17. If you figure from -40 to 204 That is 255 degree (have to count zero too) span which is exactly FF in hexadecimal. Strange though the OBDII port reports correctly all the way to 240*F. This is part of the CCD Network. Where the Quadzilla is on the ECM CANBus.
  18. Be aware... Now with mechanical gauges typically there is 5 to 7 feet of tubing between the tap point and the gauge. Now with electric gauges you need the same amount of tubing distance as well. A lot of people just screw the sensor directly into the tap point. This is wrong. You need to have that 5 to 7 feet of tubing yet this what allows the pulses to fade into the distances of the tubing. Still need a snubber too..
  19. One of the few reasons I do my own mechanic work.
  20. I deal with those every single day. More so in the big city areas more. Up here it mostly people get huge light bars with massive wattages and running them on the highway. Which is illegal to run cab top light bar on the highway.
  21. There are two 100w spotlights on the rear axles. Eventually, get changed out for LED's as well. Might look at. That what you see on my truck. http://www.piaa.com/store/p/147-LP-530-Driving-LED-Light-Kit.aspx
  22. There is a separate power lead. Black and red wire. Hook those up to the reverse lights. The red pigtails on the video RCA cable does nothing.
  23. Not really I've been talking to folks trying to move into Ontario area and there is nothing affordable or available. This isn't an option. Being I could never get Mom to move down there she won't do it. Neither will I. This comes back around to find a person to do the training. The dialysis training is FREE it cost nothing but takes 8 hours a day, for 5 days a week for 2 months to complete. If you have a medical background this can be shortened. I've come close 4 times now. Sad the best one out of all them live right here in New Meadows, ID she is a retired EMT and plenty of medical knowledge but the day we were going to start training she found out she had cancer. Dang... I found the second one in Riggins, ID that was a nurse for the clinic and she did her husbands dialysis for over 7 years. The day we suppose to start training she informs me that she's moving to the south. Crap! Had the third one in Council, ID that works at McCall hospital. She opted for it but couldn't do the training without losing her job. If I could find the right girlfriend possibly I could get this filled in...
  24. Pull the speed sensor back out of the differential and using a mirror and flashlight look in the hole for the tone wheel. Is the tone wheel centered in the hole or off to one side? When the axles are turned is the tone wheel all there no missing chunks or missing teeth? Now you need to check the wiring from the sensor to the ABS module. With the plug pull on the sensor make a jumper wire between the two pins. Make sure the ignition is OFF. Now unplug the ABS module plugs and ohm out the rear sensor pins it should be 0 ohms but no more than 5 ohms. If all this checks out then you be sending your module off the ABS to someone to rebuild. There is Module Masters in Moscow, ID.
  25. I'll wait I've got a fresh grille that needs a new one...
