  1. Still baffled by the lack of boost. Drive pressure leaks (crack manifold or blown exhaust gaskets) Wastegate malfunction (wastegate rusted/stuck open) Boost leaks... Another dumb question? Do you have an exhaust brake? Is it stuck closed? This could produce seriously high EGT's and lack of boost pressure. The fact there is that much EGT's you've got the fuel but are you getting the drive pressure to the turbine to spin the compressor. I've seen several photos floating around the Internet of turbos with broken shafts. Damaged turbine wheel or damaged compressor wheels. Look for wheel damage. Chipped fins, rub marks where it's made contact. Wastegate seen here. It might be worth pulling that turbo to look at both sides. So you can inspect the wastegate and the turbine wheel.
  2. I've got to ask is this a stock turbo?
  3. True. Small boost leaks most likely will not affect the maximum boost. Larger ones like a single manifold bolt missing or a chunk of intake gasket missing will leak pretty good. Another mistake is removing stock filter can and reusing the old bolts which are too long and the manifold will leak.
  4. Still missing my question. If I have my max set for 25* I noticed it will cancel the cruise timing if timing rises above 25*. That's fine. Now if the performance timing rises above 25* will it cap out or will it continue with what is programmed? Again what does the MAX timing slider control? What does it cap out?
  5. This post is focused more so towards @Me78569 ... I need to find an answer to a value here. In the timing EQ sliders the max timing value. I've found out you can limit your reach of the cruise timing with this value. Now does it limit the reach of the performance timing too? I need to know the reach of this value and what it caps out.
  6. I've got the Vulcan Performance Silicone boots and they fit fine.
  7. After watching this part done by @Dynamic it's not to bad doing the valve body. Just time and standard tools.
  8. Might talk to @Dynamic and see what he has to offer as well for a kit.
  9. I'm allowed a break after driving from New Meadows, ID to Ontario, OR then back over to Parma, ID. Then on top of it I've got 4 hours to wait now so might as well go where there is air conditioning and somewhere comfortable to be for 4 hours. Now if I would of bought my laptop I could have been working on the website more but I didn't. So I got the case of the lazies and took a nap. @MnTom I would have to agree with @JAG1 I think a replacement would be better because of the flooring issues. Like that was one of the thing I was taught during the purchase of my Jayco. Since I'm fairly heavy and big I could walk in an RV and feel if the floor was strong or not. Most of the newer units felt weak in the flooring like it was flexing excessively. Like my Jayco has a double square tube frame and 1/2 plywood floor which does make for a heavier unit but no flooring problems or flex.
  10. Yeah, I know but I've not found what I'm looking for... I find the little round 2 amp USB ports all day long in Amazon.
  11. I bought someone's old camper and love it. Already broke in and no warranty issues to deal with.
  12. Got back to my other home after the long weekend. Come to find that the trailer was knocked off it tongue blocks. Looking more found the passenger side wheel chock was knocked out. When it fell off the tongue blocks it landed on the driver side stabilizer jack in the front and bent the top mount. Talking to the land owner and he said the gust was upwards of 50 to 60 MPH. He figured as long as the trailer was still standing was a good thing. I was more worried about the fridge but it was still cold and freezer was still frozen. So here I sit and enjoy my A/C in the RV. No harm done!
  13. I doubt ill ever buy a new RV for the same reasons here. My Dad bought the 1976 Dodge Jamboree Class C motor home brand new. I had a bag that was full of all the work orders go back and forth to the dealer with issues. My current Jayco I bought used 10 years old and owned it now for 8 years. Minor issues but still towing it down the highway.
  14. Actually a crap ton of Oxidizer.
  15. Well as for removal there is a air hammer bit that is like cup socket that fit over the bolt head. Basically loosen the bolts, use you air hammer to drive the bearing out. Another way is to use a steel rod. Take one person to turn the steering wheel and a second person to hold the rod. Not very safe but can be done. As for the hub I think you have to drive the studs out to get the rotor off.
  16. Might ask @Dynamic about the shutter its possibly transmission. Again a educated direction.
  17. Possible ECM. There is a state called limited pedal. What you'll see is the TPS is still commanding fuel but the ECM commanding the VP44 even less. You can see this in engine load. Engine load is equal to commanded fuel by the ECM. So do the log again and add engine load with TPS so you can see both.
  18. Well I can tell you it's not the APPS sensor if it climbs smoothly. Even the graph you post doesn't drop to zero. For there to be lack off power you need to drop to zero.
  19. You not running a lift 9n your truck I'm going to assume the u joint angles are correct. The only u joint that could get weird is the one right at the pinion with axle wrap it might get some bind. Educated guess.
  20. Use what you read here and what you find in your research to make an educated choice.
  21. Yeah tour going to need a flex oil drain line. That's only a band aid for now.
  22. That's doesn't look good. Wastegate rod rubbing the oil return (I think that what I'm looking at).
  23. I was the same way years ago doing my first VP44 replacement. Now I've done so many that it doesn't even phase me and I can just about grab every tool I need before starting. My fast R&R time was in a hay field in a rainstorm I was completed and driving back to the owner's house in a little over 1.5 hours. Trust me you don't want to drop anything or have to crawl out from the tarp over the hood. Makes a good tent and stay dry.
  24. I think the idea of replacement is coming... (Crossing my fingers for you!)
  25. Ummm... I don't think that will work. Trust me the Morimoto HID headlights are awesome the light up way more. You'll only need the standard two bulbs not four bulbs. I'm running the Morimoto D2S HID's. Several other members here are running the Morimoto Mini H1 HID's. I'll admit the D2S are a larger lens and cast more light out on the highway.
