  1. Plug in the OBDLink. Install the OBDLink App on your phone. Pair the bluetooth or hook up on the WiFi. Now monitor the TPS signal as you drive on your cellphone. Pretty simple. Hence why I've got the gooseneck in my truck. https://mopar1973man.com/garage/modification/279-mobile-phone-gooseneck/#
  2. Double checking... I still think your heater core link is displaced or install wrong. As you can see my line is back towards the block from the oil plug on the filter head.
  3. Personally... AirDog 150 - Small package easy to tuck nearly anywhere out of the damage path of the tires. I'm at 12 years of age and heading for 13 years. 150 model has better pressure stability over a 100 series which typically has a wider range of pressure fall. More volume the better the pressure stability. To install any fuel system is going to require dropping the tank and installing a 1/2" draw straw of some sort. Other than that you'll end up cavitating the pump and creating air bubbles.Best to have 1/2" line from the tank all the way to the VP44. Best pressure stability you can have. Keep in mind you will want to keep the stock filter can for extra filtration. Vulcan Performance sells the Big line kit for this. I ran into this problem as well with my AirDog I was running out of time and needed the truck. So I installed the pump and used the stock pickup basket this resulted in big drops of pressure during heavy throttle like pulling a grade. I'm not fond of the mechanical belt driven pumps. If you don't keep an electric primer pump you'll never get it started again unless you can spin the mechanical pump with a drill or something to prime the system again. This creates extra plumbing nightmare with check valves and tees to include the stock pump again. Lot of people like the belt driven because pressure rises with RPM. You have to remember this is strictly a pump. No air separation, no water separator, no extra filter. Like both AirDog and FASS you can get 3um filters. Basically stuck with stock filters. FASS I've installed a few of these and I'm not impressed. Extremely large pump and filter assembly nearly twice as big as the AirDog. This limits the install to basically where the manual suggest hanging it off the front bed bolt. This places the filters in the damage path and tends to get struck from all the road debris. The one I installed locally has way more issues with gelling fuel in the winter time than my truck. If seen a few local ranchers out here stuck in the backcountry because the filters got yanked off my logs, rocks and hitting the ground while being offroad. 13 years of hanging here... So old now the AirDog label fell off
  4. Here you go gang... How to remove the VP44 the quick and easy way. Takes approximately 45 minutes for me to do this much. Remove the Mopar1973Man Crankcase vent (if applicable) Using a 10mm socket remove the air horn bolts and dipstick bolt. Using a 7/16 or 11mm loosen the top clamp of the boost boot. Move everything out of your way. Pack a shop rag in the intake to prevent stuff from falling in. Using a 13mm socket loosen the 3 bolts holding the APPS sensor and unplug and move. Now unplug the VP44 main connector and wire tap . This connector is a two step plug lock. Pull the release tab and wiggle the plug out then pull a bit more on the release and the plug should release fully. Now using a 10mm loosen the 3 bolts holding the 1,2,4 injection rail in place. Using a 3/4" wrench loosen 1,2,4 injection lines. Now remove 1,2,4 injection lines as a group. Using a 3/4" wrench remove the overflow valve banjo and remove your supply line (may differ from mine being a big line kit) Now remove the crankcase vent. Just unscrews normal right hand threads. Do not pry on the nipple. Now remove the pump shaft nut with a 1 1/16 inch socket. Using a 23mm socket roll the alternator towards the coolant bottle to bring the keyway on the pump gear to TDC position and then install your gear puller and pull the gear loose on the shaft. Now loosen the 3,5,6 lines but you do not have to remove. Now you want to loosen the 2 bolts on the rear bracket with a 13mm socket. Now remove the 4 nuts holding the pump to the gear case. Now careful kick the 3,5,6 lines out there nipples towards the block. Now lightly pry the pump away from the case and remove. Check for the key in the shaft make sure its present. This is what you should have after removal... View full Cummins article
  5. Here you go gang... How to remove the VP44 the quick and easy way. Takes approximately 45 minutes for me to do this much. Remove the Mopar1973Man Crankcase vent (if applicable) Using a 10mm socket remove the air horn bolts and dipstick bolt. Using a 7/16 or 11mm loosen the top clamp of the boost boot. Move everything out of your way. Pack a shop rag in the intake to prevent stuff from falling in. Using a 13mm socket loosen the 3 bolts holding the APPS sensor and unplug and move. Now unplug the VP44 main connector and wire tap . This connector is a two step plug lock. Pull the release tab and wiggle the plug out then pull a bit more on the release and the plug should release fully. Now using a 10mm loosen the 3 bolts holding the 1,2,4 injection rail in place. Using a 3/4" wrench loosen 1,2,4 injection lines. Now remove 1,2,4 injection lines as a group. Using a 3/4" wrench remove the overflow valve banjo and remove your supply line (may differ from mine being a big line kit) Now remove the crankcase vent. Just unscrews normal right hand threads. Do not pry on the nipple. Now remove the pump shaft nut with a 1 1/16 inch socket. Using a 23mm socket roll the alternator towards the coolant bottle to bring the keyway on the pump gear to TDC position and then install your gear puller and pull the gear loose on the shaft. Now loosen the 3,5,6 lines but you do not have to remove. Now you want to loosen the 2 bolts on the rear bracket with a 13mm socket. Now remove the 4 nuts holding the pump to the gear case. Now careful kick the 3,5,6 lines out there nipples towards the block. Now lightly pry the pump away from the case and remove. Check for the key in the shaft make sure its present. This is what you should have after removal...
  6. I buy mine from DAP. DAP sells both Midwest Injection and Industrial Injection VP44 pumps. Vulcan Performance is another safe bet also sells Industrial Injection.
  7. AC noise can impact the throttle signal. Like on my truck with a manual it creates a surgy cruise control or using normal throttle it feels like you not holding your foot still even though the TPS signal says otherwise. This is because the AC noise muddy the tach signal from the engine and ECM starts changing fueling commands because of the noise in the tach signal.
  8. After going out and looking at my truck and comparing the picture to what I'm looking at that compressor housing has to HUGE. If the heater core line is bolted down in stock placement there isn't much you can do other than possibly dent the line where the compressor housing would hit.
  9. Heater core line. Looks like your manifold blanket is displacing the line.
  10. Software is constantly changing all the time. New features, new abilities, etc. Sometimes things get overlooked or software get old and starts failing. I've got no problem looking into issues if you can't get into the website.
  11. Should have called me I would have got you fixed up. Contact Us information is on the bottom of every page on the website.
  12. Here you go the wiring between the VP44 and the ECM pretty simple to test. Basically, unhook both the VP44 and the ECM. Now ohm test from pin to pin it should be ZERO ohms. With it still unhooked now do the pin to GROUND. This just proves there is no wires shorted to ground this should show INFINITE ohms (Open circuit).
  13. P1689 is communication code. Basically anything to screw up communication between VP44 and the ECM. Possible Causes Wiring & Connectors Fuel Injection Pump Relay Output Circuit Open Ground Circuit Open Or High Resistance Datalink (+) Circuit Open Datalink (+) Circuit Shorted To Ground Datalink (-) Open Datalink (-) Shorted To Ground ECM
  14. To me, it looks like the rubber roof was never glued down like its suppose to. Looks like it grew a blister of air and the wind beat the rubber till it tore. This is because the rubber wasn't glued down to the roof.
  15. I would have to say time to call warranty on those shocks. I've got a set of Rancho's that are nearly 200k miles on them and still doing OK. Starting to get a bit more bounce than I like.
  16. Bottom of ANY page should have "Contact Us" and it has my phone number listed there. https://mopar1973man.com/contact/
  17. The problem is the crank sensor was moved to the cam. Then the early version cam sensor was removed. The cam gear has a tone ring now in the later series so this requires changing the cam. Since the cam tone ring is in a different position then that means the gear case has to be swapped. If you think you can just swap the electronics this typically turns into a bigger issue because of the wiring difference and communication difference between early and late trucks. This is why its best to get the same year of engine that way there are no issues with electronics versus mechanical. If you give me a call some time I can explain easier on the phone what the problem is and why this is such a headache to deal with.
  18. This would be a first... I've never heard of a stitched block holding up...
  19. No. Again gear case issues, cam issues wiring issues. only a 98.5, 99 or 2000. That won't work either. Most fail again after stitch the black back together. The only thing you could do is convert the entire truck over to 2001 or 2002 but this requires replacing all the wiring harness cab included, change the gear case, change the cam, change both PCM and ECM as a pair. Still much easier to find a 98.5, 99, or 2000 engine.
  20. Won't work. Wiring issues, cam issues, gear case issue, etc. Best to buy another 1999 engine that way there are no issues.
  21. That's what it cost for my entire truck in 2002. This is just a rebuild... I'll skip the common rail world Thank You. That's just insane amount of money because of a CR injector failure.
  22. all the wiretap does is pull to ground for a set microseconds once the PSG module on the VP44 stops. Just to clarify your last state a bit more.
  23. Might look better but I wonder if it can exceed OEM lifespan. Mine went 334k miles on the OEM drag link and tie rod ends. Let's see if it holds up to the test of time.
