  1. Could you post up your axle gear ratio and tire size. This plays a huge role in if you can control smoke and EGT's. Could you export you tune and upload it to the post as an attachment so we can look at your settings.
  2. I would investigate the crank sensor. Dropping of tach signal can prevent starting also prevent the lift pump from firing up. Kind of hard to read the gauge if it's under the hood. You need to be able to see the gauge while cranking and driving for proper fuel pressure. So you might be looking at that crank sensor first. Here is the article on the code and how to test. Funny... AC noise possible too.
  3. Might be worth looking into on the 96 Dodge and seeing if I can resolve that issue a bit more. (Sticking on release time).
  4. Now if I can get some free time I want to do the mod too. Just seems like my time is always sucked up so fast. Ugh!
  5. Close enough... Dave is right. The boost pressure is built up in the air intake system and when you drop off the throttle the drive pressure drops away from the turbine. So now the pressure attempts to leave the manifold the easiest way it can by blowing back out the mouth of the turbo. Since there is no drive pressure on the turbine the boost pressure can spin the shaft backward as the air rushing out the mouth of the turbo. This is harsh on the turbo and possible to break the turbine shaft. Not a Holset turbo but you get the point...
  6. Actually, it's your tires. The 35" tires change your final gear ratio way too low in the 3.1x to 3.2x realm. This adds huge amount of load on the engine typically creates way more heat both coolant and EGT's. Now if the axles where regeared for 4.10 this topic wouldn't happen. Most people choke when they hear the price of regearing the axle to keep their pretty 35 to 37 inch tires. Fuzzy math. 35" tire with 3.55 gears in the axle has a final ratio of 3.14:1 Like on my truck I'm running 235's with 3.55 gears. Now if I switch over to 245/75 R16 that will change the final gear ratio to 3.7x or so. This would improve my torque output to the ground and allow more pulling power with more speed. Way too many people look at the cool factor but forget about the science of the gears. Tires are just a smooth gear and when you increase tire size you increase engine load because the gear ratio went too low. Optimal towing ratio is right at 3.73.
  7. @Me78569 data log repository... That is one thing I will give Nick he was logging nut. He data logged everything he did.
  8. I think it wild to see diesel power boats that just flat haul . I think its cool that the first boat was a 12V Cummins.
  9. Another reason I hate warranty. It always seems to take long getting something fixed. Even a vehicle with warranty it seems to take forever to get through the channels and get the parts and work done. Like my warranty claim, VP44 at 50k miles took over 8 hours to be installed. Shop labor rate is 4 hours. Now today I can install VP44 in about 1.5 to 2 hours and be running the longest thing is getting the part shipped here. Funny tidbit an extended warranty company sent me a letter that I could get extended warranty on my truck for a price. Here what happened... I'll most likely continue to buy used RV's and used vehicles.
  10. Drop your EGT's to about 1000-1100*F it will hang at about 205-208*F coolant. I got several steep grades here in Idaho and have no issues with cooling or engine temperature. Now if I was to push 1,200 to 1,250*F it can go to 220-225*F engine coolant temperature.
  11. I made it a point to contact @mountaindan on the phone today and try to help him out. Anyone near Dan would be a service to help him out.
  12. You could look at the 911 listing and see if there are other members near you that might be willing to help. https://mopar1973man.com/cummins/911-support.html You could ask other members here in the forum to help you. Most guys here are really good at being helpful and helping with doing repairs on trucks. I'd love to help but I'm on the wrong side of the island from you.
  13. Sorry to hear that. All I can say is you might pay more money for taking to a shop and have some shop monkey wildly guessing at the problem charging you large amounts of money. There are things on these truck that is considered maintenance items like injectors. They are supposed to be replaced every 100k to 150k miles for the optimal performance. I know many people will say they ran their injectors over 400k miles and never changed them. Might be true but the fuel economy typically is much lower. Sorry to say 230 bar is junk its way too low and will not atomize the fuel well at all. It will create misfire conditions. This is why some of us are experimenting with high pop pressure about the 330 bar realm to find out if there is anything to gain. Like myself as soon as I can get money ahead I'm planning on pulling my +75HP injectors out and going for (7x0.010) with pop pressure of 330 bar. As the pop pressure goes down the injection event happens early and and not sprayed in fine mist but a squirt. Remember two things are needed for diesel to run well. 1. Compression - Valve lash in good adjustment, cylinder health (good piston rings and no blowby), boost pressure. 2. Fuel - Sprayed in the cylinder in a fine mist at the right time.
  14. Tach working? Any P0336 error code? If there is any error code for tach signal (crank sensor) the ECM will not know to start the lift pump. Does the lift pump run when you bump the starter? Is there 12V from the lift pump lead? If not then you looking at sending the ECM for repair. WARNING I do not suggest putting a toggle switch on the lift pump or wiring the lift pump to the key switch. This is a huge safety hazard if you in an accident there is no way to shut down the fuel if you are unconscious. I highly suggest you have the ECM repair then replace the lift pump with an AirDog or FASS with a protection relay so the load of the pump is never on the ECM.
  15. Hype... Typically when the P0121, P0122 or P0123 code is present with the "Dead Pedal" its going to be APPS sensor issue. The bast way to test is to have a live data tool and data log both Engine Load and the APPS sensor together in graph form. The engine load reports the amount of fuel given to the engine. So if the APPS and the Engine Load drop together its a APPS sensor issue. If the APPS sensor stays high and the engine load drops then it could be an ECM issue.
  16. Thanks, I feel the love...
  17. Finally after 10 plus years I went in and got new glasses. My old glasses where giving me random headaches and struggled to read road signs and some days even the computer screen. Nice part is this is the first time with polycarbonate lens. Wow! Much lighter on my nose. So here is my at home desk glasses. Geek stylin' Now my driving glasses and clip on polarized shades. I've got a wide range of vision so the larger lens really help with driving.
  18. Point taken... Some of us are stuck with what we have and don't have a little car.
  19. Basically room for improvement.
  20. Gotta ask. What do you get for pretty decent mileage? I'm also a daily driver for the most part. Approximately 750-1000 miles a week.
