Remaned ECM took out vp44?
Could you get in contact with @pepsi71ocean and tell him about this so he can update his list of ECM rebuilders.
2nd gen engine cooling
NAPA fan clutches tend to be OK. I've installed a few of those without any failing yet. https://www.napaonline.com/en/p/TEM271361
Free but you pay shipping TDR 98-to current
That's sick. Adams County (Idaho) and common household trash is free. Appliances, tires have a small price. Even my waste engine oil is free. I just got to haul it to the dump site. Typically 20-25 gallons at a time. Local dumpsters are free as long as you can get the trash the man opening. Pollock has 5 larger dumpsters. Everything from deer carcases, tires, household trash, you name it.
balljoint time again.
Looking at the Dynatrac those things are crazy high price. That is just the ball joint alone. For that kind of money I can buy the entire axle for less from a wrecking yard... https://www.dynatrac.com/rebuildable-ball-joints/balljoints/hd-balljoints-for-2003-2012-dodge-ram-2500-and-3500-4x4.html Way different story... https://www.rockauto.com/en/catalog/dodge,2008,ram+2500+pickup,5.9l+l6+diesel+turbocharged,1441433,suspension,ball+joint,10070
Older vehicles beware - Ignition switch
Looking that up its a perfect FFFF hexadecimal. Good question. I don't know either why there is a key counter. DRBIII tool typically is thousands of dollars to even purchase. This tool is "THE" tool that does all reflash work on any module on our truck. It can enable or disable high idle mode, reflash ECM's and PCM's. Calibrate ABS speed setup for larger tires. Read data from all sensors. Like I said this is "THE" tool of tools for the Dodge Cummins!
Terminology question
Reason Quadzilla can't read codes is because of it on the CANBus not the OBDII port. CANBus port requires the Cummins Insite tool to ready error codes from there. This is limited to only the ECM errors you cannot see any others. OBDII port can read error and give some live data. Quadzilla is able to reach father giving like fuel temperature, commanded timing, oil pressure, and few other bits of data that OBDII port can't do. I would suggest an easy live data tool like OBDLink or similar. I tend to like the Bluetooth models because now you not limited by a cord. I can have my phone in my hand be under the hood chasing loose wires or wiggling wires and watch for changes. This can't be done with corded models.
I had another friend trying to pass off his TDR magazine collection on me... I told him I would haul them to the dump. Why would I want to read outdated information? Even here some of my articles I've pulled because new information replaced the old information.
Fuel pressure alarm 10 psi
Just buy a ISSPro EV2 gauge comes with a programable warning light. Matter of fact this gauge just saved my VP44 from damage.
Might try AC Delco. OEM lasted 150k the AC Delco just crossing 200k really soon. Just had the front end inspected and aligned not long ago.
2001 Dodge Ram 2500 BUCKING ISSUE
Yes, that will work.
Yes sir. @W-T put it back to the way the Dodge FSM states it should be. Not the OEM way which is incorrect. Dodge FSM shows the ECM, PCM and VP44 getting ground from the Driver Side battery.
Brake Lights will not turn off when vehicle is parked.
I forgot about something too. Another reason for these seal failures could be the use of wrong fluids in the power steering system. I've seen in the past where people have used ATF in these truck assuming it will work fine. It will not. ATF will cause seal damage and our system requires only power steering fluid. I suggest staying away from synthetics as well in this system. Being I've crossed 344k miles on the OEM pump and hydrobooster. I'd still have the factory steering box if I didn't screw up the input shaft cover.
You create this ground. From the VP44 bolt to the driver side battery.
Start with the ground a the passenger side battery, trace it to the alternator. Thenfrom there split the loom open all the way to the to the VP44. You'll see the ground splice.
In a nutshell the large gauge wire will be spliced with the lighter gauge wires. At that point to cut the wire.
Basically the TPS is how much fuel your commanding, engine load is how much fuel given. So if you command high amounts of fuel and the engine load is jumping like a jack rabbit then the ECM is damaged and providing bad data to the VP44.
Again not a APPS problem ECM problem I need the data... Again look at my post I updated it...
@Me78569 Idle software from the ECM seems to be clean. It's when it flips over to throttle mode fuel data gets dirty. Best suggestion is to grab an OBDLink OBDII dongle and data log both the TPS and the Engine Load in graph mode. At least we can see what TPS and the fuel signals are doing. Here is another members post about a possible APPS issues which in his case turned to be a bad ECM. We need the data of the TPS and engine load to figure out whats going on. Yes, it's possible the ECM could be damaged.
Did you try test drive with the Edge EZ removed? Do you have air bubbles coming through the fuel system? Raptor could be drawing air into the lines and since there is no air separator then it would start bucking. Under load the fuel flow is higher so ithe air bubbles will be more plentiful. Still you will wnat to di the ground mod above. @dripley reported a 50% reduction to the noise levels. dropping him to the 0.01x realm.
That why I'm asking for signature information so I can see if there is something else in the system muddy the signal. Do you have any tuners programmers anything like that? turbo? Injectors? Any engine modifications?
Hmmm... Could you list out all your mods you have on the truck in your signature? I'm looking for more clues on what it could be. It's still electrical natured.
Did you do the ground mod? What typically it is the ac noise muddys the tach signal and the ECM start the bucking. Another way of testing is disconnect the alternator field lead go for drive. If it goes away the problem is for sure AC noise related. Noise filter is a huge clue in this and should be removed.
trreed's upgrade thread
I guess you won't say, "Here hold my beer and watch this chit!" Leaves you without a truck for quite awhile and simple things like seals are tough to get.
And a bad alternator. Ditch the ATS noise filter return the electrical back to stock. Most likely replace the alternator but have it tested for AC ripple. Then you'll want to do this ground mod.
Wildlife
I've had a Robin nest outside my bedroom window for several weeks. Momma hasn't been bothered by my yard work or anything. She'll normally fly off and watch from a distance. In the begining she would go nuts if I went near the nest. Now she just watches from a distance. Here is what's in the nest... Two newborn Robin's. Thankful for the high power zoom I could keep my distance and still zoom in good and see what's in the nest.
