I’m a Newbie and need help
Raptor DDRP - No... Raptor Yes... (Frame mount) ISSPro EV2 series matches the stock dash in design. Even USB programable.
Personally, I wouldn't suggest any DDRP pumps. The problem is none of them upgrade the stock plumbing then all them end up hooking directly to ECM and have no protection relay added. As I replied that @IBMobile could talk him through it.
Quad 4K tuning help
Should be in the article section under 24V fuel.
Mistake. Please delete
OMG you guys...
Quad 4K tuning help
You might want to talk to @Me78569 and @jlbayes between these two I'm sure you can you answers.
Airdog filters only?
Cut them both open! Seriously, you'll learn something if you examine the filter media. Like my water separator I've been rinsing out and re-using. The marking and paint is disappearing. Like my last filter, I cut open at 60k miles for the year and it was still "OK" the media color was still visible but darken heading towards black.
Amount of blow by...useful or not?
Exactly. This is a summation of all blowby in the engine. Like @jlwelding learned years ago you can have a cracked piston creating a misfire problem but still pass the blowby test even though the cylinder was dumping its compression in the crankcase. This is not a good way of measuring cylinder health. If you want to know the cylinder health you can do a compression test or leak down test. Most opt for the compression test being its easy to do. A typical engine should be 400-425 PSI in good shape.
You might want to get ahold of @IBMobile I'm sure he'd be willing to talk you through it.
If you going to be oversizing the filters I highly suggest you cut them open and see the condition of the media after your normal run time. Like I'm still running the small (or tiny) AirDog filter but Donaldson like @AH64ID suggest but I'm finding that about 50k to 60k miles before the media is truly discolored. The stock filter pickup some debris but it takes a bit to get it dirty too. I was finding that at 15k miles like manufacture suggest my filters look like they were new out of the box yet. I kept doubling the mileage and cutting the filters open. So my change interval is 50k to 60k range. So far all them at that point are just discolored not BLACK. You can still see the color of the media yet. (Either white or yellow). For something that big (physically) you might go well past 100k miles on filter changes. This is also based on if you getting clean fuel in the first place. If your getting cheap fuel or raiding farm fuel tank you might be in a different ball park.
Also a AirDog owner. I just got a replacement pump head for the first time after 250k miles. No need for relay mod with a proper lift pump. Those from RockAuto have to use excessive pressure at the start to keep the volume up under load because of the small fuel lines and banjo's you've got stock. Me first before @dripley ... I can always use another 2nd Gen...
I'm going to bet you are right... https://www.rockauto.com/en/catalog/dodge,2001,ram+2500+pickup,5.9l+l6+diesel+turbocharged,1366602,fuel+&+air,fuel+pump,6256 Need to look at the AirDog or FASS fuel systems. Those on RockAuto don't resolve several problems. No protection relay to keep the lift pump load off the ECM. Stock fuel system plumbing is way too restrictive. Those lift pumps don't have enough volume to keep the VP44 lubed and cooled under heavy throttle.
I've got to ask what lift pump do you have installed?
Alternator rebuild kit
Hit the nail on the head. Stock alternator is only 140 Amps. Even at that its possible ot overheat stock diodes with extended grid heater usage. Now increase the size of the alternator and you'll burn out the stock diode pack quicker. I've been hunting for oversized diodes for a long time that in the 180 amp realm. I've even called Nations and few other attempting to buy just the high current diodes from upgrade alternator to solve the AC noise issue. So far the best I could do is stock 140 Amp diode at least so people could rebuild there own alternators at a fraction of buying a chain store alternator that might fail.
Quadzilla V2 Custom Tunes
I still laugh at that video. Dragging an empty fuel tank. How about full offroad use of the truck with a full fuel tank? Hmmm... Now take that sump and have it installed in a 8,000 pound truck with 35 gallons of fuel (diesel is 6.1 pounds per gallon equal to 213 pounds) now drive over a tree stump or large rock. I promise you that sump will disappear. When I'm grossing over 20,000 pounds I'm sure that little 1 bolt sump will snap off. I should post picture of the dent in my rear passenger side floorboard from running over logs and other things.
How about one of our vendors. https://www.dieselautopower.com/catalogsearch/result/?q=sealing+washers
Quadzilla Adrenaline
Blow by some times is worried about too much. Serious blow by you will have something like this... You might want to upload a copy of your tune and members here can discuss the settings with you. Just having the timing wrong or the fuel curve set up wrong can limit the power. Another member was using boost limits and that cutting the fuel by 70% on the top end. So poor set up of a tune could possibly limit your power.
Did you try unhooking the lift pump just for test to see? The ECM has a way of controlling the lift pump by pulsing the power at 50% duty cycle off and on. This brings down the starting pressure of the lift pump to prevent the VP44 from over advancing the timing during cranking. Banjo bolt in the back of the head needs to have two fresh sealing washers installed too.
Got a fuel pressure gauge? If not install one. What is your cranking fuel pressure during this no start condition? Typical cranking fuel pressure is 7 to 12 PSI. Pressures above this can create hard starting or no starting conditions. To test from another way is unplug the power from the lift during a no start condition and attempt to start the engine. If it starts then the fuel pressure during cranking is too high. Replace the sealing washers. This might be a source of an air leak.
P-Pump 24V with V2 tuning
1st Pump lasted 50k miles. Failed from low fuel pressure less than 8 PSI. P0216 Code. 2nd pump lasted 243k miles. Failed from pure wear. Stuck in full advancement. P0216 code. Currently at 346k miles.
There is 4 ways to kill a VP44... 1. Low fuel pressure. Typically low fuel pressure problems caused the P0216 code. 2. Poor Filtration. I've seen several trucks with the stock filter can filled with dirt in the bottom and using junk filters. Too much debris usually got to the injection pump. 3. Low Lubricity. Bosch states that fuel should be 460 HFRR or less of optimal lifespan. When ULSD was released it raised the bar to 520 HFRR which is outside the realm of Bosch specs. Too many people used cetane booster and fuel injector cleaners that raised the HFRR score even more producing more wear. Hence the start of the "2 Cycle Oil Theory" years ago. 4. Excessive AC noise. This is problem that most are fighting for automatics with TQ Converter lockup issues. But they would band-aid with noise filter or some lame mod. The AC noise would eventually fry the PSG on the VP44. Typically toss P025x codes.
One or the other... Can't do both. If you update to high amp alternator you cannot use our diode kit. Diode kit only fits the stock Denso alternators. Bosch alternator has solder in diodes. There is a few members here that opted for high amp alternators to hopefully get away from the issues. Unknown if it has resolved the AC noise issue for most are just getting started in mileage and time.
No. There is no electronic tuner with a P-pump. Not to mention there is no timing advancement with a p-pump. It's a static timed pump what timing you set it for is the timing across the range of RPM. Yes. VP44 injection pump has a dynamic timing and can be advanced as much as 30 degrees before TDC. You can control timing over a wider range of engine load and RPM.
- Quadzilla V2 Custom Tunes
A mod I want to do is use an ISSPro addon relay kit and program the relay to be hooked into the CHECK GAGE light on the dash and send the chime signal. This way I could program the gauge relay to trigger the factory chime and CHECK GAGE.- Quadzilla V2 Custom Tunes
As far as I know, Quadzilla does not have any audible alarm only visual yellow bar at the bottom. - Quadzilla V2 Custom Tunes
