Brake Lights will not turn off when vehicle is parked.
Did the trailer brake controller do the trick or is it still turning on the brake lights?
Terminal tools for 2nd gen
Here is a good pair of wire strippers. I've got these. https://www.homedepot.com/p/Klein-Tools-Katapult-Wire-Stripper-and-Cutter-for-8-20-AWG-Solid-and-10-22-AWG-Stranded-Wire-11063W/204660476 Here is excellent crimping tool. I might have to buy these much better than my old school junk. https://www.homedepot.com/p/Pro-sKit-Ratcheted-Crimper-for-Open-Barrel-Terminals-300-005/206369459
No. That's a sign of the hydrobooster leaking power steering fluid into the cab. This is most likely caused from lack of power steering fluid flushing and the oil is contaminated and broke down so the seals take a beating. Power steering fluid should be changed every 30k miles.
Trailer brake controller? Not sure if you got one. Possible the control back feeding the brake light leads.
Take notice of there are 3 fuses. (Fuse 4, 5, 10 in the Cab) It can be the muti-function switch or brake light switch. Being the Hazard switch will use the same filament as the brake like switch and if the flash relay is shot then the light just stay on. (Fuse 4 and 10) Brake lights is Fuse 5.
7x.012 with HX
Basically what @Me78569 is getting at for building fuel curves. This is how you would break it down into smaller chunks and clean up each piece of the fuel map. Start with level 1 set your valet mode power till you get the smoke tuned out. Now that is going to be your start power %. Now step up to Level 2 and now build your curve till you make your starting point to 100% fuel clean. If you need to clean up more push your 100% point higher in the boost range. Now Step up to level 3 and build from the 100% to the max you can handle without smoking heavy for the rest of the span. Now step up to level 4 or higher and build your wiretap level. With as big as your injectors are I really wonder if wiretap will be even needed.
bwbrewco
Might talk to @IBMobile he's down there in the California area. I think also @KATOOM is in California. Might ask these guys if they can help.
How can I eliminate pcm from 01ram 24v
Ok. PCM is the master computer ECM is the secondary computer PCM uses ECM and ABS. Cruise control uses ABS signal. (Either pass to the ECM or vacuum motor) Security feature PCM gets do not start signal and sends to the ECM. Cluster requires ECM, PCM, and ABS. Cluster gets the coolant temperature oil pressure, and the tach from the ECM. Cluster gets the fuel level and the voltage from the PCM Cluster gets the speed from the ABS. ECM requires PCM and ABS module. ABS control the grid heater canceling. Radio requires Central Timer (Steering wheel controls). Central Timer Requires PCM (security feature). Overhead console requires PCM. All p-pumping the engine does is remove the VP44. You still need the ECM for the cluster to display gauge functions. Remove the PCM the whole system dies and the truck won't function. This why the two codes tend to prevent function of the truck typically.
7x.012 with HX
Then use level 2 to build your defuel range.
Ground Reference VP44,ECM,PCM,PDC plus TC lock/unlock
I'll tell you why he's gun shy to changing the VP44. Last time I did the VP44 in his other truck was was quick to ask, "Where does this bolt go?" - CLANK! and it disappeared. After hunting for about 15-30 minutes we found it in the bottom of the intercooler. I've got no problem doing the VP44 @JAG1 knows my average speed is half of the labor book. Not to mention the A/C problem he's been nagging me about for months since last summer if I don't do it JAG1 will be beating with the stick next. You always welcome for a wrench party here. It's always the old and slow ones that know what they're doing. (Sign of great wisdom).
No way to remove the PCM. Its the master computer. Without it the rest of the truck fails. The only thing p-pump does is remove the VP44 you still need the ECM.
i guess dead pedal
Ill bet money on the sensor.
New NV4500 Probelms
Possible pilot bearing if the rest are fine.
New NV4500 Probelms
That's because of the extra rotational mass of the 2 friction disks to slow down. One of the few reasons I won't do a dual disc.
7x.012 with HX
Look at it this way. The Stock ECM tune can use the full range of the VP44 timing already. It's just when does it occur. All we are doing is dictating when and where the timing occurs. So the VP44 is capable of 30 degrees of timing and stock can touchh the 30 degrees but I'm going to assume its way up the RPM range. I'm more focused on the timing where I do the most driving, So the 1,500 and 2,000 RPM band is where I spend the most time. So those two ranges are the most important to me. Now as for the 2,500 and 3,000 I look at those for passing power but I might use those ranges only 1% of the time. Give you a feel. (7 x 0.0085) Injectors... No studs, HX35/40 hybrid 60/60/12... 18, 21, 24, 27, 27 (Timing max) Max load offset 3* Low PSI Timing reduct 5* Timing reduct Scaling 50% Light Throttle Timing Adv 3* Light Throttle Load 20%
Control center rat trap on top
Back when I had both the 1973 Dodge Charger under the tree I stuck mothballs in the Dodge Charger the mice would pack them around the car. So instead of being in the cup where I had mothballs in I'd find them all over the car then. I tried the dryer sheet idea too and watch how mice used the sheets for bedding. Even in the RV I tried again. Mice walked right past the mothballs wouldn't phase them. Drier sheets again they dragged them off and made nest out of them. Two things I found that keeps mice out is noise and lack of entry. Even mice need to have sleep so if there constant loud, obnoxious noise all the time they will not build home there. The other then is not to have shelter or warmth. Lot of ranchers up here leave the hood open then vents the heat out quickly and doesn't provide shelter for the mice.
Thank you. Information confirmed.
7x.012 with HX
Ok another way to look at it. Set the Quadzilla for Level 0 and monitor your timing. Now build a timing setup which is plus 1 or plus 2 over stock. Not exactly a good way to look it being stock has a nasty retard hole in the middle of the map. I'd rather base it off engine load and EGT then you know you got efficiency on you side.
7x.012 with HX
Not the way to look at it. It more what do you want for a target timing value during cruise? This should be based more on engine load and EGTs. As you get closer to optimal timing the EGT and engine load will fall. The amount to give is more on the experiment and see side.
Quadzilla V2 Custom Tunes
Exactly. More defuel you have in you cruise realm the more TPS is required creating extra pull on TV cable which is holding gears longer.
New NV4500 Probelms
I'm going to say clutch/transmission install issues. If the pilot bearing is dragging on the input shaft it could create this issue. I've had it myself after replacing my clutch and being careful about the alignment of the transmission I've never had the issue again. Being the clutch is pushed in and the input is still spinning with the crank if the bearing is binding up then shift quality is an issue.
Throttle required to start
Starter most likely. I've seen where one brush fails and the starter is now on half power and struggles to twist. Contacts typically just don't deliver power yeah it does happen that it could cause poor cranking but rare. Another is cables I've seen some battery cable that look like junk and people do weird things to gain a better connection.
7x.012 with HX
High you go up with the main timing values the more this can go down because engine load will be reduced. Like I'm at 20% light throttle load limit and cruise at 65 MPH at about 15-17%. Holding this number too high will cause efficiency problems. This is all based on the max timing. I've been as high as 7* here. Now which base timing being pulled up this has to go down. 18, 21, 24, 27 so now add +3 to that. 21, 24, 27, 30 is my cruise timing. Since my max is 27 the cruise timing ends shortly after 2k on the tach and forced back to performance timing values. 27* is about all mine can do with bucking.
For daily driven truck there is no real reason for extending the RPM range. I would not suggest extending the range unless you have the supporting mods to handle the RPM.
United States Forest Circus... I've got no love for them and they are not "fire fighters". They are "Fire Managers" in other words they are not in the business of putting the fire out but allowing the fire to burn and manage where it burns at. After working with US Forest Circus for over 12 years and fighting fires. I watch how these clowns play with back fires and poor management to create bad fire seasons.
