AirDog 150 - Finally failed
Well, then I've had several. All the years of backing trailers on the woods getting firewood. All the time idling setting up to drag logs. Like yesterday if my truck was running again driving very slow up forestry roads looking for firewood. Below 20 MPH. True its not a life average either. Still I'm sitting here thinking al the times I've fired it up and left it idling is quite a bit. That what caused my last alternator to fail was the excessive amount of idling last winter with grid heaters banging away at the alternator burned the diodes out. I can think of lots of times it was started and left to idle.
Quadzilla V2 Custom Tunes
More advanced timing, lower boost. More retarded timing high boost. Not the fuel in this cases. Stock ECM tune is heavily retarded hence the high boost pressure.
About like myself my Hybrid 35/40 turbo spikes out at 45 PSI tops and then settles at about 40-42 PSI at WOT throttle wire tapped. Now CANBus only its only about 32 PSI tops. In any case the cruise pressure is really low like I said about 2-3 PSI on flat ground. A couple of screen shots. No I don't display boost being 2002 for some reason are off. I use my ISSPro gauges more.
Just about right. At 65 MPH I'm typically about 2-3 PSI on flat ground. While your building your tune you want to keep an eye on the engine load. The more you can drop engine load the less fuel your burning. When you find a good timing you notice EGT's are lower and so is the engine load. Now the trick is when you drop cruise timing you want just enough retard timing to kick the boost back up to build and pull up the power and then get you back to the cruise timing quickly.
Help - Truck won't start
I agree the ground cable sound to be rotten and should be replaced most likely. I've seen cases where the cable broke in the middle and the vehicle would randomly start. Away to check this is to take a set of jumper cables and go from the negative post of the battery to the block if it starts better then the cables are damaged or shot.
Quadzilla is a clean tuner. We are consuming all the fuel and turning into power. Old canned tunes like Edge Comp or Edge Juice worked good with stock injectors but couldn't be cleaned up because of lack of timing control and fuel control. Quadzilla you can clean up 90% of the smoke with a good tune consuming all the fuel. Towing reasons. So I'm running tapped as a daily driver (level 4-7) but when I hitch up a trailer I turn down to level 3 which is strictly CANBus and then the EGT's are totally under control. Another reason is when road surface is slick be it ice or mud you can cut your power to prevent shocking the tires which might spin. So I would still tap the wire but use the iQuad app to control when you use the wiretap. It gets deeper. You can set how much TPS signal it takes to trigger wiretap. Then you can set how much boost is required to trip the wiretap. You can set how much wiretap to start with percentage number. Then how far up the boost scale to reach 100%. So you have full control over the wiretap and even my tune I can tune out the majority of the smoke.
Injector upgrade options
Like I'm running a +75HP (7 x 0.0085) VCO injectors, HX35/40 hybrid turbo (60/60/12), with the Quadzilla Adrenaline. In level 3 (CANBus Only) I can hold the throttle to the floor and never reach 1,200*F EGT's. Towing I can reach it but takes a while to get hot. Now wiretap level 4th gear gets stupid it's possible to break the rear tires loose.
New, to me, chainsaw!!
No way to bring it home since the road is a mess. No to mention its already been logged out. In the past I've done that quite a bit I use to take Mom's Chevy S-10 and a little Pullan saw and get anything I could from up there. Now the road is in horrid shape the land owner behind me won't maintain the road. It fairly dangerous now with a ATV.
In the beginning was 360 to 400 miles. Currently its 250 to 300 miles.
Fuel pump shutoff solenoid
Wait to start light coming on? If not the ECM is not booting up and will not turn on either the lift pump or the VP44. Lift pump should be directly controlled by the ECM. The VP44 is turn on by the fuel pump relay in the PDC.
Engine loss of fuel after hard acceleration.
Just the cost of the Smarty and the recovery file which will most likely be more than entire rebuilt ECM. Again 1 shop hour at the dealer is about $120 I seriously doubt you'll be able to buy a Smarty S-03 and the recovery file for under $120. All you need to do is tow the truck to the dealer.
ECM has to be on the truck. Dealer can only flash what the VIN states. Typically a dealer charges one shop hour. All flash work is done through the OBDII port.
Just in fuzzy math assuming I kept the engine running for the last year every time I went down to Ontario for dialysis treatments for MoparMom. 13 hours per trip x 3 day a week = 39 hours a week x 52 week in a year = 2,028 hours running. Just in One Year. I've almost got 2 years counting of running back and forth. Excessive maybe... But fuzzy math and not accounting for the actual stop time. So now spread that over 12 years and this number might be a bit more or less. Just looking from another angle and the amount of running time in resent times. Then there might be years where its was much less. I remember more than once where the engine was started and never really got shut down all day. Truthfully, I really not going to complain about the pump motor failing. I think I've got my $520 dollars worth from a 12-year-old pump traveling 250k miles.
Strange but true. My old Stihl Chainsaw never got any real maintenance to it other than blowing out the air filter and fresh chains. When I bought my new saw I sent my old saw in to be looked at and taken care of. They changed the spark plug but the electrodes were still good. Good burn color and in good condition. Change the air filter. Then rebuilt the carburetor. The only repair I did to that saw was the throttle handle got damage when it got crushed by a log that rolled. Now I'm getting set up for wood season. I've already hunted down my firewood and found plenty of Pine. Even found some nice dry Red Fir but I got to hurry to get that. Wood spot is found. Now it time to get firewood permit, fresh saw fuel mixed 50:1 ratio, fresh chains on both saws. Trailer is already empty. Friend is going to do the towing work for me for now till my truck gets repaired.
Kind of hard to judge on mileage alone. I can tell of many times sitting in parking lots idling away to keep warm with 0*F weather. Then like last summer many days of idling in parking lots to keep from frying to death. All the times I kicked 3 cylinder warm up or 6 cylinder warm up. Jump-starting other vehicles. I'm sure there is a few thousand hours more on the pump motor in idle time.
Neither... It's in the ABS module. Smarty only programs the ECM. The only other thing it can program is the ABS for Speedometer. Personally, I would skip the Smarty and just have a dealer flash the tires size for you. Smarty S-03 just for tire size change is rather expensive. You can get a dealer to flash it for much less.
Wildlife
Do you see it? Here it is... I was out with a friend today scouting for firewood. Just below our first spot on the way back we spotted this little fawn pop up of the edge of the road it spotted us and laid down instantly. Not knowing where Momma was we were not going to get out of the truck. So we quickly snapped photos of this little fawn and moved on down the road.
2001 2500 starting issue
Might look into the ground wire mod by @W-T .
Surging
That made me think a second. If I'm not mistaken the 6.7L have oxygen sensors. I again I wish I had some live data. You would be able to see the sensor that is creating the surge. My knowledge on the 6.7L is limited but I've got a basic understanding.
New meadows root beer
Hit the "Contact Us" at the bottom of the page. Then click on directions you'll be led right to my house.
I can see!!!
Here is the full story... So you can see my adventure started back in October 6, 2016... Now you understand the 60k miles a year driving. @IBMobile his wife (Jennifer) and MoparMom (Rosalie my Mom - far right)... This was back in May 2018...
Surging
That's what I'm trying to do is see what is causing the issue by getting some information from the engine and possibly see why its surging. Right now all I can do is guess that it could be injectors, FCA, coolant sensor, IAT/MAP sensor Etc. There is a lot of information used by the engine from different sensors and without being able to see the data it tough to point the finger at something.
I can see!!!
Figures Dorkweed would take a poke at me...
I have 01 Ram 24 Valve
The reason why tune files don't require donation it the file size is very small. Your usage of the bandwidth is very small. Our larger files it could impact the site rather quickly and eat our monthly bandwidth allotment. 570 bytes tune file is nothing...
MPG Offset I'm using for 7 x 0.0085 injectors is 135% which is darn close. Make sure the switch ON and lit green. Tire size I'm using the 95.7 inches which is stock signal passed through. (Still off by about 0.5 MPH).
