vac pump oil line leak
I've never bothered to pull the oil fitting off the vacuum pump. If the fitting is national pipe thread then it should be self-sealing. If the thread is straight then there should be a o-ring or seal of some sort.
Going to 4" tailpipe versus 3?
Went from 3" to 4" and ZERO change in EGT's. Tunning on the Quadzilla does more to change EGT's than exhaust does. Drone is louder. The exhaust brake is louder. I did a 4" Diamond Eye Aluminized exhaust system with muffler. Cruising is quiet. Power band pulling up grades there is a spot where drone gets loud in the cab. Then every time I break over the top of Midvale grade and start hitting the exhaust brake coming down the back side its rather on the loud side.
Is mild steel okay in fuel tank?
I've never messed with my fuel pickup module. I use an old school draw straw for 12 years. Less problems with breaking plastic parts that you can no longer replace. So I thought that was part of the OEM basket at first look but now looking again yeah I see it now.
White smoke on start up less with warm motor
Those are good too. I'm running the DAP +75HP (7x0.0085 VCO) injectors. Without a tuner they might be a bit too smokey. Basically about the same amount of power as a Edge EZ or Smarty would provide +10-15 HP over.
I've had good luck with both RV275 Bosch injectors and Vulcan Performance +50 HP injectors.
Safe to drive but the file economy will be lowered. In a nutshell how these engines work is your compressing air enough to create the heat. Then injecting fine atomized fuel into the heated air to make it go bang. So when the injectors wear out the injector pop pressure opens early. So stock is suppose to be at 4,500 PSI +/- 250 PSI. Now the injector is opening early the spray is not atomized good so there is a smoky haze because the heat isn't enough to make all the fuel burn completely. The most you might notice is a offbeat or miss idle when hot this is the injectors causing this.
Injectors are most likely shot. Typically have to replace 100-150k miles. Typically the blue haze could be either fuel that is not burning or like in my case it valve guide seal that are failing. But valve guide only let off a single puff of blue smoke and it smells like burning oil. Since you not talking about a burning oil smell I would have to stick to the injectors are worn out.
Did my VP go too?
Thank you sir. You post will expire in one year so make sure to review it again in a year. You can contact one of the staff and they can renew the listing. This is done so if you happen to fall away from the family then you don't end up with people calling you.
Then the only thing that comes to mind is the injectors are getting wore out and pissy. How many miles on the truck?
key trick to read the ECM.
Yeah you do. The old post over on CF was of the P1693 code was because the 2000 and 2001 would report the P1693 code and nothing more for a failed VP44. This because Cummins didn't have the code added in the ECM for the key trick so Dodge PCM typically always had it but the 98.5 and 99 didn't get the key trick. The order it read codes is ALWAYS PCM first then ECM (companion module). Even on the 2002 it reports P_PCU and P_ECU in that order. Just for information value. Disconnecting the batteries does not clear any codes ore reset any computers.
Did my VP go too?
This is why I want as many people to post there contact details in the 911 contact listing. This way if you have a failure somewhere you can get support from other members in the area even if it a safe place to say while you do the repair. https://mopar1973man.com/cummins/911-support.html/contacts/
Look right there in your photo. Right at 6 o'clock on the black plastic ring. What does it say... ABS... Glare of the camera really makes that pop out.
idles at 800 and revs to 1400..thats it
I would have to say its most likely a VP44. The only data that is screwy is the data from the VP44. All other data you have posted from the ECM has shown to be in good working order but the VP44 communication error and the wild data from the VP44 is strange. You tested from end to end with 0 ohms. The VP44 volts could be a bad fuel pump relay. You can swap the horn relay with the fuel pump relay and see if that fixes anything. The VP44, ECM and PCM all get there ground from the passenger side battery terminal. You might talk to @W-T about his ground wire post.
I'm curious do you have P0216 code? Remember some codes do NOT trip the CEL.
1998.5 and 1999 do not work. 2000 and 2001 may or may not read both typically just the PCM. 2002 will display both PCM and ECM codes.
Did my VP go too?
Stock VP44 injection pumps are just fine. You just need to make sure you are getting a pump that is by a certified Bosch rebuilder.
Makes sense. ECM is commanding max fuel because the VP44 RPM is too low. So you've got a communication issues between the ECM and VP44.
@dripley in your case the gauge pegs because of lack of ground. @snowshoveler In your case, the P0238 code is most likely a bad ground on the MAP sensor or bad MAP sensor. The P1689 code is worrying me a bit. I would try trading the fuel pump relay in the PDC with like the horn. The weird part is the VP44 is allowing it to start so the fuel pump relay is most likely fine. You going to end up testing the Bus wires between the ECM and the VP44.
This should help you'll see the sensors on the bottom of the wiring map. Map sensor is up above the ECM.
Hang out here. We'll teach you from a distance...
Those are like $3,000 tools! You stole that!
Very rare indeed. Most here only dream of having DRBIII tool.
Most codes are not reported correctly on OBDII tools. Here is the correct definitions.. https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/obdii-error-codes_94/
Doubt its a APPS sensor... Typically its a ECM when there do a limited rev.
Towing EGT's
Just wait till people are stealing your pressure sensors.
