Clear button doesn't work
Imctrying to clear out any data logs and fuel mileage logs and the clear button is broke. Hit it once scroll the screen the data is back. Return to the main screen the mpg data is back.
Help stuck, failed steering gear and power steering pump
I would get that system flushed out. All the seals are not designed for ATF. Again the ATF used in 2003 and up because Dodge started using Ford steering boxes. Every thing from 2002 and back is all power steering fluid. Knocking I would pull the vacuum pump and power steering pump again and inspect everything from the gear to pump shaft.
Finally, Tie rod ends and drag link replacement.
I've got to admit I screwed up... I was trying to cheat and change out the parts with the truck parked straight in the shop and mount the parts without disturbing the toe. Sad part was it ate the front tires up pretty good after 2 trips to Ontario, OR. I noticed when I was installing the new steering dampener. I hate to see the angle I had before. I asked MoparMom to hold the tape measure found out I was toed out pretty good. I readjust the toe to using a standard tape measure. Lesson learned... Take the time and at least measure in your new parts and then find an alignment shop. I got lucky and they were having a sale on it and it only cost me $32 for the alignment and took about 45 minutes. Now it drives like a sports car. Super tight steering, ZERO slop, and very reactive.
Did my VP go too?
A little trick to try. Pull the coolant sensor and trip a coolant code. Then plug it back in and check the codes again. I've seen this rarely where there is a pending code but the dash show something there but it like the ECM/PCM don't want to spit it out.
At my freinds tranny shop
I did...
Suggestion for Quadzilla
Ok, I've got the new version of the software up and running I'll be testing it out today on my way down to Ontario, OR. I've notice the connection time is much shorter the few times I've watched. I did have a refused connection once. I had to shut down both the truck and the iQuad to start over and get it to hook up. @Quadzilla Power already knows about the monster gear issue. (PM sent). We'll see in normal real time driving in the city if the hang up with shut down in the middle of the loading the tune.
Wrong fluid. ATF+4 will cause seal issues. ATF+4 was only used on 2003 and up Dodge Ram trucks. This is because the steering box is a Ford Steering box. Power steering fluid. Sagnaw steering boxes need power steering fluid.
Did my VP go too?
Most likely there are no codes to be picked up.
Where did you mount your Fass Relay?-(wire harness)
All my accessories are to the BATT stud in the PDC. Remember not to wire anything to ALT stud before the fuse. That is a good way to fry stuff when the alternator fuse blows it will jump up in voltage and fry anything hooked up there.
Did my VP go too?
Another way to buy an OBDLink diagnostic tool you can use it on your phone. http://www.obdlink.com/
Engine Died 1688 Code
Two separate issues. The APPS sensor is going below the minimum voltage level and tripping the code. The P1688 is a PSG electronics failure of the VP44. VP44 has zero to do with the APPS sensor and visa versa.
Fuel injector lines
Seriously rather odd to see the tip of the injection line sheared off. Like you said Dave your isolator block was missing back there.
Defueling at 1900 rpm fummins
Test your alternator for excessive AC noise. 99% of electronics failures are from excessive AC noise.
Even my 46RE that I had @Dynamic build for my 1996 Dodge 1500 is way beyond a shift kit. There is more than just a valve body. Yes Jon modified the valve body by drill out particular ports changing the shift. Then changing up springs to change shift points slightly. Adding oil ports in the body of the transmission keeping the clutches cooled. You narrowly focus on just a shift kit when there is the entire upgrade that makes it all worth it.
I've heard of stories where people didn't get the power steering and vacuum pump lined up and creates knocking noise because either it breaks the vacuum pump or breaks the power steering pump coupling.
Fuel injector lines
- IQuad V2 tune build
Might look at the Quadzilla tunes we've got... https://mopar1973man.com/files/category/22-quadzilla-standard-tunes/- Fuel injector lines
@dripley Too much Edge Comp 5x5 and driving around with a heavy foot eh?- Help stuck, failed steering gear and power steering pump
The biggest thing you need to flush all that out of the system if any of that debris plugs holes up in the steering box or hydrobooster it will cause all kinds of issues. I'd never do that. I would mount the vacuum pump. Then mount the power steering pump to the vacuum pump. Way too much weight and hose pulling the alignment of both device and making it impossible to install.- Did my VP go too?
Being I got you the deal on it.- Engine Died 1688 Code
Sure is every time the grid heaters drop there massive load of 95 Amp load on the alternator the PCM is ramping up the field voltage to keep the batteries up so you see the alternator charging against the massive load of the grid heaters. Again now the grid heater cycle has ended and this is normal AC noise level. This is one of the few reasons we are disconnecting the grid heaters. Go through the process and double check the wiring. Lucky... So I would keep that in mind. Weakness? Maybe...- At my freinds tranny shop
He heard that...- 363 over s475
@jlbayes would be a good one to ask. Another is @TFaoro he should know as well.- key trick to read the ECM.
I'm pretty sure it programmed into both the PCM and ECM. Being the 2000 and 2001 both are known to report only PCM error codes where the ECM was missing the code to report it errors. You have to remember the master computer is the PCM and the ECM is just a companion module.- Where did you mount your Fass Relay?-(wire harness)
I really don't like putting any wiring directly on the battery terminals. After a while you have this hairy mess of wires all going to the battery. Like myself I pulled a single ground lead into the cab. Then pulled a single power lead from the PDC. The reason I got away from this is all the ring terminals eventually fail from corrosion issues. So if you mount everything away from the battery this problem stops. - IQuad V2 tune build
