Charging Issue (it's not charging)
Normal that is how it regulates power from the alternator by controlling the gorund leg and vary ground voltage amount. I'm going to bet your Alternator fuse is blown or cracked. Remove the two 8mm bolts in the fuse and test it with a ohm meter.
Dually suggestions
6 Speed doesn't have the 5th gear nut problem. But parts are MUCH higher in price since NV5600 are not produced anymore. Now as for the NV4500 transmission there are more common place and use in both the Chevy and Dodge trucks and there is plenty of parts and upgrades being the NV4500 was used for many years. You have to remember New Venture went out of business. After 124 years, on Thursday, August 24, 2012, New Process Gear (New Venture) ended production and closed their doors for the last time. https://en.wikipedia.org/wiki/New_Venture_Gear
Led Fog Lights Causing High Beam Indicator
That means there is a wiring issue with the bulbs your using. Something is back feeding on the high beam leg. LED light is polarity sensitive be sure you are set up right. The headlight bulbs are backward to what you may think. The what you would think is a ground or common terminal in the bulb is actually the +12V and the hi / lo legs of the bulb are ground legs. Where the fog lights are normal hook up like you are use too.
- PCM starting issue
C3 is the bottom most in the diagram. Starting from the A/C clutch relay down. VSS is in the C2 plug. C3 the big thing is the CCD network. Since the source of the network starts at the PCM. I would have to say its a CCD network issue.- trreed's upgrade thread
I've got a 1" ratchet in my toolbox. I typically use the handle off my old floor jack for a cheater for leverage. Last unit bearing change on my truck I used my 1" ratchet and that floor jack handle to pull the very same nut. Needless to say the ratchet handle now got a curve to it now.- Morning Pic For Today...........Post A Pic around your place.....
That storm dropped nearly a foot of snow here in one storm alone. I've been hired out yesterday for plowing driveways. Then last night I was hired out again for the same people to get there driveway opened up this morning. Hence why I'm up so early pouring coffee in me and get ready to saddle up on my iron horse.- Anyone Know.....
They did this back in the 70's going from locking hubs to solid axles and all the time 4WD. Then back to locking hubs. Solid axle have been the best design so far even back in the 70's. Less mechanical failure. Any design with a locking axle or hubs tends have a weak point.- Led Fog Lights Causing High Beam Indicator
Better image...- Anyone Know.....
I've got a later series axle and it solid on my 2002 Dodge. Now my 1996 Dodge is a CAD axle. Some people love the CAD axle because you can make it 2WD LO for parking trailers. Personally, I've had nothing but problems with CAD axles. Solid axles just always work and never fail you.- Track Bar failures
I must be the weird one. Only two track bars replaced in 335k miles. They do hold up but the biggest factor is tires and tire size.- Morning Pic For Today...........Post A Pic around your place.....
Slammed back to back winter storms. Piling up fast out here. I've been hired out 3 different times to plow driveways for people. My own driveway is done twice a day when I'm home. Crazy storm is really putting the white stuff down.- Injector ash
Never been a big fan of Optilube personally because of the cetane booster typically used.- Valuable parts question
I come armed and with cash. I'll even bring "Diesel" for guard duty while I'm digging through your junk.- Injector ash
No. I pour approximately 1/2 quart for half hank a tank of fuel. Suggested is 128:1 ratio of 1 ounce of oil for every 1 gallon of fuel.- Injector ash
This is not normal. Cetane booster tend to add soot to the injectors. 2 Cycle Oil you might try it. I'm going to bet my 80k miles injectors are cleaner that your 2 year injectors.- Morning Pic For Today...........Post A Pic around your place.....
For me, anything above 32*F is warm and that jeans and tee shirt weather. Now between 0*F and 32*F is cold requires a good heavy coat. Below zero is plain frigid and dangerous survival at these temperatures is very short if out in the weather. Add wind to that you talking serious life threating problem. @Marcus2000monster It's all good. We both live in the cold country. That one of the reasons I don't carry a bunch of spare parts in the truck and tools. I carry food, water, blankets, extra clothing, gloves, etc. My own survival is more important than trying to fix the truck. The truck can be towed to safety. As for MoparMom and me, our lives are much more important.- Lift Pump took a dump
You need to unplug the pump. Bump the starter. Measure the voltage at the plug. If 12V is present everything is fine with the ECM and the lift pump is junk. If 0V is at the plug you just lost the ECM lift pump circuit. Also, the lift pump is junk too which caused the ECM failure.- Lift Pump took a dump
AirTex pump. That is direct connected to the ECM. Test to see if the ECM is still producing power to the lift plug (disconnected) with a starter bump.- Does this bother anyone else?
Another thing if you didn't catch it but I did the door jam in the first picture appears to be dark blue. Come on you can't even paint the entire rig door jam and all? What is this an Earl Scheib paint job?- Laughter is very good medicine
One of the few reason I never bought into the iPhone Craze. I might not be much better with an Android (just fitting for the video). My circumstance is different than most people mine is used as a true tool and like 99.9% iDiots out other. Since I'm on the road 3 days a week I use my cell phone to keep up with the website and business as a travel. Now seeing two people in the same room texting each other, now that is stupid. What happened to getting together and talking using your voice and looking the person in the face? I'm used to seeing kids playing in the river and swimming. Even back in the day kids creating places in the forest to go camping and hang out. Now all you see is kids sitting at home with their tablet or phone. Mostly on Facebook. Again here is a platform I don't really use. I use it for advertising the site but I don't go posting about what I did everyday.- Missing, random codes, occasional stumble at idle
I'll admit its rather confusing but that's what came out of the book.- quad v2 wiretap settings
Tap on the text box at the bottom and enter each one by hand. The EQ sliders personally suck. Look cool but impossible to use. Especially when you're trying to hit exactly one number.- Advanced timing with Blue Chip Special X VP44
This is exactly true... Special X pumps and Hot Rod pumps are now a thing of the past. The other problem like I've learned in tuning now is everyone forgets about their fuel cetane rating. My current tune is bit retarded compared to stock in the cold weather. Being the fuel ignition ability is better as cetane goes up so adding timing on high cetane fuel will actually increase engine load (fuel consumption).- Does this bother anyone else?
The back seat is even worse... Can't you even afford to keep the interior the same? - PCM starting issue
