  1. Ok. First let me show you a picture. VP44 return is on the left, then the VP44 supply is on the right. So as you can see the return side is restricted fairly well. So even if the fuel pressure coming out of the VP44 is above 14 PSI its only flow the amount of the port will allow. Since AirDog 165 has a reduced return flow compared the old school AirDog 100/150's it tends to recirculate within the AirDog itself. I don't like this method much because it can have issues with cavitation just like the old OEM Carter and Holley pumps have to this day. If you dead head a pump it will create its own cavitation issues. So with AirDog 100/150's they are flowing majority of the fuel back on the return hose.
  2. Strange but truck most truck owners out here favor the manual over the automatics.
  3. Most likely not. It sure harsh on any kind of fluid system to bounce between fluid to air. It it weird way creates a hammering force and jarring. Kind of similar to water hammer but very random. So you can imagine the pressure relief valve opening and closing attempting to keep pressures stable and air compressing.
  4. As long as the turbo lag doesn't create poor street manners and excessive smoke output. Then lag on...
  5. That why the performance was bad. Any air is compressible so every time you requested power steering or brakes the air compressed more than work provided by the hydraulics. So start this process over again check the fluid make sure its full before starting. Run it short time and check for foamy fluid if so shut down and wait 15-30 minutes top off and start again till it stops foaming.
  6. I've got a funny feeling there is something electronic that is defueling the system causing the lack of power. Then again not all codes will set the check engine light. As for the key trick the only year that it works on is the 2002 correctly. 1998.5 and 1999 don't work at all. Some of the 2000 and 2001 work correctly and other only report the PCM and skip the ECM. So just use a code reader and not have to guess.
  7. Before assembly I would clean the shaft/kick down shaft with sandpaper and brake clean before re-installing the valve body. This will prevent damage to the seal on the case. Transmission fluid look a bit darker than usual and discolored...
  8. Typically. I will get a system started and drive for short amount of time like 1/4 mile or less. Then return home and park it. Let it stand then top off with fluid after it stood for good length of time. This allow the foaming to quit. If the fluid is foamy don't drive it for long periods it can cause damage.
  9. Dodge had a NP203 series of transfer case that was full time 4WD but it was a differential front to rear case so both shaft spun. Just some old history on transfer cases.
  10. Mopar1973Man commented on Mopar1973Man's Cummins article in Engine
    I've added just a bit of rearward angle so the tip of the down pipe is rest on the back side of the bell housing. This way the oil if any drip doesn't drip on the starter.
  11. Last I heard on the pulling the bulbs is that its impossible being that they are LEDs. The panel illumination is bulbs.
  12. Most coolant leaks are from over extending the coolant change intervals. So the coolant becomes corrosive and gaskets and seals tend to give in a bit and start to leak. So I tend not to think warp head or cracked. Not like you go out street racing every night or tractor pulls.
  13. How about error codes? There is lots of error codes that do not turn on the check engine light but defuel because of issues.
  14. Tightening pan I typically grab the ratchet at the head and spin it like a palm ratchet this way it really hard to produce any excessive torque that would cause such problems. Like my new Harbor Freight ratchets are the flexible handles I just fold the handle to the extension and use it like a palm ratchet again. Either way it still tough to produce damaging torque. Yes torque wrench is the ultimate way of doing things.
  15. Safety Reminder... Most all trailer ST tires are rated only for 65 MPH speeds. Highly suggest you do not tow a trailer at exactly at 65 MPH. It would be no different that running the engine at red line going down the highway. I typically tow my RV at 55-60 MPH its a win win situation. The slower speed you net better MPG's and also tire temperatures stay cooler. If you owned the trailer... I would suggest you look at the load capacity of the tires and the GVWR. Like my RV came with Load Range D's and barely fits the GVWR trailer. So I up sized to Load Range E's. This gives a stronger carcase of the tire and pressure adjustment range. Calculated pressure for my RV I only need 57 PSI to cover the GVWR of the trailer. I run 65 PSI allowing for a bit stiffer side wall and a better towing performance. Then I'm not running MAX pressure (80 PSI) of the tire which now allows the tire to flex some when it strikes a pot hole or object in the highway. To this day I've never experienced a catastrophic tire failure or blow out on either a vehicle or trailer. Don't get me wrong I've had flat tires before even on the trailer I've picked up nails and such.
  16. Be careful. As you increase turbos the lag will always come with it.
  17. He has a point... I've don't have children so we are all adults and manage water wisely. Children is a new angle I can't answer for..
  18. Holding tanks... To start a trip I fill my water tank with clean potable water. I now take a 5 gallon bucket fill it and pour it down the toilet. This pre-starts the black tank. Now you don't have to waste large amounts of water on the black tank. I typically don't bother to turn on the pump for #1 for #2 I will fill the bowl partially to flush solid waste. So there is no worry about poo-pyramids then. As for holding tanks typically most RV are design to hold more waste than water so it very very rare to see your tanks fill. I typically run out of water before my tanks are full. So if I holder 50 gallons of water typically your going be still right close to the same 50 gallons of water in waste just in different waste tanks. So there is no issues towing with full waste or full water tank. Either way its still about 50 gallons of water either waste of fresh. If I return home like this trip and I barely used a 1/3 of a tank of water I will use a garden hose and finish filling the black tank up so it will dump completely. Then dump my gray water tanks as a rinse. At end of season I will fill all three holding tank completely full of water and dump one last time before winter as a final rinse. Since I use irrigation water I've got plenty of that for rinsing. Since my dump station is right here in my front yard no problem doing the job right.
  19. Absolutely YES! I can watch over the air TV or turn on a DVD movie and never see full hook ups nor listen to a generator humming in the background. I love it takes me a mere few minutes to setup but I can watch TV, play with the laptop or just charge up my cellphone. The wonders of a 1,200 watts of inverter and batteries... Flip on the inverter, plug in the solar panels, toggle the transfer switch and 110 VAC is live in the trailer without the noise of a generator. So who's laughin' now... Even parked out here I watch Spider Man Movie on the side of US95... No hook ups. I didn't even put the solar panels out just turned on the inverter plugged in the TV and kick back and watched a DVD movie.
  20. Most people have smart phones you can get an level app for most phones. Just lay it in the fridge and level it the best you can. Doesn't have to be perfect but close. Trailers you do the left to right first. Once you have the left to right level then you do your front to rear after your unhitched. I carry 2x6 boards and a shovel. I've been known to dig pits for the tires so the door and first step isn't a big step to get on the first step. Dumping holding tanks is simple just make sure the hose is all locked in place before pulling any knife valves. Always start with your black tank (toilet) then finish with your gray tank(s) from your sinks and shower. Like said before do not leave your tanks open if you have full hook ups. Always fill the up 3/4 or better before dumping. Myself full hook up camping is just relocation of your house. True camping you pack in and pack out.
  21. Once you own an RV you tend to have double batch of everything. Like my RV I've got basically everything you need to go right now. I've got to just got to check the dog food supplies, pack clothes, fill the water tank, dump the holding tanks, and grab personal stuff. That it. There is bare basics for food on board. I always travel with a full water tank since 90% of my use is boondocking. I very rarely use RV parks any more. So I've got thing like Coleman liquid fuel stove for cooking outside, cooking baskets for cooking on a open fire. Bedding wise there is the standard minimums like MoparMom and myself we both have favorite blankets that we pack along. In a nutshell it really don't take us long to pack up to leave it just the matter of closing down the house that takes time. Typically the day before I've got the fridge fire up and cold and everything hitched up and ready. So if you own the RV you can basically leave it packed / set up. Like MoparMom and myself were discussing different can goods we would like to leave in the RV for the summer time so if we leave late in the evening like this last trip we can grab of a can of something and munch for dinner. Even the dog has a extra dog pillow to lay in the RV. So we are not constantly packing and unpacking a bunch of stuff. Like anywhere is home for us now...
  22. I'm sure @Dynamic could spit that out fast...
  23. All speed signals come from the ABS module. The speed sensor on the automatic transmission is for shifting control not speedometer/odometer function. Basically the rear speed sensor is your speedometer/odometer in the rear differential.
  24. Any error codes? Use a code reader. What is your fuel pressure like? Any rubbed holes or cuts in the boots? What's your boost pressure like?
