  1. Like JAG1 and I had a long conversation on the phone last night about this. More or less what BlueChip had done is like taking a old Chevy truck grab the distributor and twisted forward a few extra degrees initial advance. So basically using that same idea the total number of degrees advancement is the same just move forward in time more. Where most performance box do the very same thing dynamic through software for much much less money. Edge EZ - $398.73 Edge Comp - $573.18 Edge Juice - $1003.48 Some more to look at... Smarty & Smarty Touch Quadzilla Diablo Power Puck Bully Dog Problem is now you stacking timing if you add a module to that Special X pump. So this is one of the limitation I spoke of you can add a performance module to a Special X or Hot Rod pump. But now a stock SO VP44 and a Edge Comp (120 HP) or a Quadzilla (180 HP) would surely produce way more power than mere 22 HP Special X. So the only direct you can go now is injectors for power and still you have no fuel management. Just thinking about it. You could run 2 devices with that Special X or hotrod. Smarty (fuel only mode - No timing) or TST box (Fuel only box). But still the timing map on a Special X or Hotrod is dictated by ECM and it's information. Where a full module like Edge, Quadzilla has a wider range of timing control.
  2. That's why I suggest getting stock injection pump vs. Any kind hotrod or special X pump because you can tune around it much easier. With hotrod or special X you have to be aware of the limitations of each pump.
  3. I have a few friends and few of them on the site. But I've got lots of acquaintances.
  4. That's where I've got a limitation I cannot measure timing on these pump at all. But I can tell you timing it set by temperature more so. So, the colder the IAT temperature and ECT temperature the more advancement the VP44 will have. This is because colder air takes more time to convert liquid fuel to vapor to ignite. The warmer the IAT the more retarding. Because the air is already warm fuel will convert quickly from liquid to vapor and ignite very quickly so less timing advancement is required. I can tell you that the MPG fooler works from the basis of fooling the ECM to seeing 143*F which retards timing and typically gives a about 2 MPG gain. When timing is good the engine should be a bit quieter and less rattle typically the EGT's fall even more.
  5. The windows visors might keep the summer time insects out. I really hate when a be or hornet bounces off the mirror and hits me in the chest or manages to fall in my shirt. Man I really hate getting stung in the belly. Been there done that.
  6. There is a member named Dynamic here he should be able to answer that for you. He happens to be transmission builder.
  7. I would like to say "Thank You" to a anonymous person for the gift he sent me. WeatherTec Vent Visors Husky Floor Mats
  8. Excessive timing pushes the torque curve higher into the RPM span which in turn only makes power on the upper RPM span which creates the smoke issues for the lower RPM span. So lets say stock torque curve maxes out ay 1,900 RPM's. So advancing the timing moves that peak timing curve higher into the RPM span so say 2,200 to 2,300 RPM's. This is good for racing folks but bad for daily drivers. Being the pump is mechanically modified with added timing there is no real way to retard it.
  9. Too low. Typical I see like 70-90 PSI just at rest for Dodge trucks. You might see variance because of current temps.
  10. So what was you static pressure of freon? I'll dig up the schematic tomorrow morning.
  11. I should of measured the hub of the Frantz Filter and seen what size of roll I need to fit it snug again so next time I hit a WalMart or similar I can measure a wide variety of brands to see if I can hit a better roll. Still leaves me with a leaking can issue and finding the square cut o-rings that are better. I've got another 4 or 5 o-rings left and they seem to be leaking by the next oil change. Messy SOB. That why I still going to do more reading and research. There has to be a cost effective solution. Something that doesn't need to be cleaned up like spinner and Frantz. I really do hate the mess you have to deal with and leaks. Spin on filter are more appealing but "specs aren't good enough". So I have to say... These industrial applications that use these spin on bypass oil filters must be good enough for something. Being most of the application list is diesel engines that these filter are used for.
  12. Just for the learning curve I looked up drone to see what is was all about... http://en.wikipedia.org/wiki/Drone_%28bee%29
  13. If I'm not mistaken 12V engines have the coolant sensor at the rear of the head.
  14. What can I say.... I noticed they registered yesterday so I sent a PM telling them to call. It all got finalized this afternoon.
  15. Already done... Parleys is added to the vendor pool as of this evening... http://forum.mopar1973man.com/index.php?/forum/166-parleys-diesel-performance/ Thank you Paul for your efforts.
  16. How about freon in the system? Is there at least 60-90 PSI of freon on the low side? Electrical - How about the A/C relay is it good? Fuse J (10 Amp) is it blown? Is the compressor clutch got a open circuit? (Ohm test)
  17. Cleaning sensors doesn't do any good to resolve any problem that is a Internet Myth. If a sensor is failed its failed and replacement will only fix it. I no longer suggest cleaning sensors because it doesn't resolve anything nor does it change readings.
  18. Need to grab that AirDog / Raptor thread and keep building on it. Maybe between all of us we can keep the pumps going without all the constantly calling "Pureflow" for warranty work.
  19. I've never had a issue with a criss-cross rotation.
  20. I'll have to look at freight charges...
  21. Typically its a front to rear tire rotation. Some people will take the front tires and criss-cross them going to the rear. Since the rear tires are typically wore flat faces and should cause any problems.
  22. I had a conversation with Eric at Vulcan Performance about AirDog failures. First off his knowledge of failures where mostly on the Raptor series of pump. The full AirDog 100 or AirDog 150 where fine from his stand point of failures and warranty.
  23. Source... http://www.rumormillnews.com/cgi-bin/forum.cgi?read=16386 An Open Letter to the Oregon House of Representatives: Planning on voting for "Universal Background Checks"? The NRA is the least of your personal worries. The Law of Unintended Consequences, Armed Civil Disobedience, and Lex Talionis. -----Original Message----- From: georgemason1776@aol.com To: Rep.JeffBarker@state.or.us; Rep.PhilBarnhart@state.or.us; Rep.GregBarreto@state.or.us; Rep.BrentBarton@state.or.us; Rep.CliffBentz@state.or.us>; Rep.DeborahBoone@state.or.us; Rep.PeterBuckley@state.or.us; Rep.KnuteBuehler@state.or.us; Rep.BrianClem@state.or.us; Rep.JohnDavis@state.or.us; Rep.MargaretDoherty@state.or.us; Rep.SalEsquivel@state.or.us; Rep.PaulEvans@state.or.us; Rep.ShemiaFagan@state.or.us; Rep.LewFrederick@state.or.us; Rep.JoeGallegos@state.or.us; Rep.VicGilliam@state.or.us; Rep.DavidGomberg@state.or.us; Rep.ChrisGorsek@state.or.us; Rep.MitchGreenlick@state.or.us; Rep.JodiHack@state.or.us; Rep.CedricHayden@state.or.us; Rep.DallasHeard@state.or.us; Rep.KenHelm@state.or.us; Rep.PaulHolvey@state.or.us; Rep.ValHoyle@state.or.us; Rep.JohnHuffman@state.or.us; Rep.MarkJohnson@state.or.us; Rep.BillKennemer@state.or.us; Rep.AlissaKenyGuyer@state.or.us; Rep.BettyKomp@state.or.us; Rep.TinaKotek@state.or.us; Rep.WayneKrieger@state.or.us; Rep.AnnLininger@state.or.us; Rep.JohnLively@state.or.us; Rep.CaddyMcKeown@state.or.us; Rep.SusanMclain@state.or.us; Rep.MikeMcLane@state.or.us; Rep.NancyNathanson@state.or.us; Rep.MikeNearman@state.or.us; Rep.RobNosse@state.or.us; Rep.AndyOlson@state.or.us; Rep.JulieParrish@state.or.us; Rep.CarlaPiluso@state.or.us; Rep.BillPost@state.or.us; Rep.DanRayfield@state.or.us; Rep.TobiasRead@state.or.us; Rep.JeffReardon@state.or.us; Rep.GregSmith@state.or.us; Rep.BarbaraSmithWarner@state.or.us; Rep.SherrieSprenger@state.or.us; Rep.DuaneStark@state.or.us; Rep.KathleenTaylor@state.or.us; Rep.JessicaVegaPederson@state.or.us; Rep.JimWeidner@state.or.us; Rep.GeneWhisnant@state.or.us; Rep.GailWhitsett@state.or.us; Rep.JenniferWilliamson@state.or.us; Rep.CarlWilson@state.or.us; Rep.BradWitt@state.or.us Sent: Sat, May 2, 2015 9:23 am Subject: Planning on voting for "Universal Background Checks"? The NRA is the least of your personal worries. The Law of Unintended Consequences, Armed Civil Disobedience, and Lex Talionis. Dear Legislator, In the interest of full disclosure, I am an unindicted criminal. For the past two years, my friends and I have been breaking the state firearm laws of Colorado, Connecticut, New York, Maryland and, most recently, the state of Washington, that were passed in the wake of Sandy Hook. In those states where standard capacity magazines were banned, we have smuggled in such forbidden items in defiance of those laws. We have hardly made a secret of it. We want the authorities to arrest us. To date, they have not dared. In Connecticut and New York, the non-compliance rates on the registration of firearms and magazines are estimated to be as much as 85% to 90%. In New York, county sheriffs have put the state police on notice that if they try to enforce the SAFE Act in their jurisdictions that THEY will be arrested, not their intended victims. The authorities of those states have made noises that they will enforce these unconstitutional laws. But again, to date THEY HAVE NOT DARED. In Washington state, Michael Bloomberg bought himself a "universal background check" law much like the one you are about to pass. In response, two thousand of that state's uncompromising firearm owners gathered on the steps of the state capitol in Olympia -- armed to the teeth -- and defied Bloomberg's law despite threats that they would be arrested if they did. The rally, one of the largest pro-firearm rights demonstrations ever held in Washington, came off without a hitch and the "lawbreakers" were complimented by the state police afterward for the professional way that they conducted themselves. I know, I was there. Why did they not enforce Bloomberg's law? Because they did not dare. In June, a firearms expo will be held in Yakima by the group Liberty For All -- a background-check-free gun show -- testing further the resolve of the state authorities to enforce a plainly unenforceable law. Will they dare? We will find out, because WE WILL NOT COMPLY. The lesson of the past two years is clear for anyone paying attention to see -- THERE IS NO UNCONSTITUTIONAL LAW THAT CAN BE PASSED THAT CANNOT BE DEFIED, RESISTED, EVADED, SMUGGLED IN VIOLATION OF AND COMPLETELY NULLIFIED BY ARMED CIVIL DISOBEDIENCE. And that includes the state of Oregon. This is dangerous ground, truly dangerous ground. But it is not ground that we chose. All the law abiding firearm owners of this country wish is to be left alone. But collectivist control freaks like Michael Bloomberg will not leave us alone. Still, pass what laws they like, they cannot escape from the Law of Unintended Consequences. In Connecticut, the state legislators who voted for their Intolerable Act discovered that when I posted on my blog, Sipsey Street Irregulars, a list of their names, home addresses, phone numbers and email addresses. I discovered something from their hysterical reaction -- people who like to put other people on lists (you know, like the bill you are considering on Monday) do not react well when they themselves get put on a list. Which brings us to you, today. The NRA has sent out a legislative alert. You will no doubt be contacted by many, many outraged citizens. Let me reassure you, this is the least of your personal worries. What you must remember is that we understand intimately, even if you choose to ignore it, that the velvet lies of your "good intentions" are wrapped around the iron fist of the threat of state violence against those who do not comply. Now this is true of any law you pass -- all are backed up by the threat of arrest and incarceration and, yes, death at the hands of the state police if anyone resists your good intentions and refuses the honor of arrest and incarceration. The thing is, we are not your average criminals. In fact, we are not criminals at all, no matter if the last election has placed you in the position of power to declare us so. However, if you make us criminals, we will be the very best, most successful criminals we can be. For we will not comply. For there is a difference, as I have said in speeches in the past, between "the law" and the rule of law as codified by the Founders' Republic in the Constitution. Our natural, God-given and inalienable rights are not subject to negotiation, dilution, diminution or infringement, by you or anyone else. For us, it is the height of cruel irony that those of us who swore an oath to uphold the Constitution and the rule of law find ourselves required to become "lawbreakers" to remain in fidelity to that oath. Again, this is not ground we chose. Michael Bloomberg and his collectivist fellow travelers, domestic enemies of the Founders' Constitution, picked this ground. It is ground we have sworn to fight on, and if need be, die on. The question before you today is this: Is it ground that YOU are prepared to actually fight and die on? If we resist your 'good intentions," how many of us are you willing to see dead in order to enforce your will upon us? And once we and our families begin dying at the hands of the state police you send to our doors, can you blame us if your victims return the favor to the people who sent killers operating under color of law? This is not ground we chose. It is deadly dangerous ground. By your votes on Monday, we will discover if it is ground that YOU choose for Oregon. But kindly remember the words of John Locke, who wrote them nearly a century before the Founders wrote the Constitution: “Whenever the legislators endeavor to take away and destroy the property of the people, or to reduce them to slavery under arbitrary power, they put themselves into a state of war with the people, who are thereupon absolved from any further obedience and are left to the common refuge, which God hath provided for all men, against force and violence.” For there is another law, ancient and unyielding, available to the lowliest slave, and that is Lex Talionis -- an eye for an eye. And history shows that the distance between laws like the one you are considering passing on Monday and Lex Talionis is often unexpectedly short and frequently taken in mortal error. For as the ancient Chinese warned, "Be careful what you wish for, you may get it." Or, put differently, the rule of law protects you from us far more than it protects us from you and your tyrannical intentions. Again I ask, how many of us are you willing to see dead to enforce your "benevolent" will upon us? Understand in advance, if you wish to enforce such a law, you will have to kill us. FOR WE WILL NOT COMPLY. We will greet it with the same tactic that we used to nullify every such law passed since Sandy Hook -- armed civil disobedience. And who do you suppose, after the bodies are all stacked up and the butcher's bill calculated, that history will judge to be guilty for passing such a dangerous, unenforceable "law" that is absolutely destructive of the constitutional rule of law? Us? Or the people who passed it? Sincerely, Mike Vanderboegh PO Box 926 Pinson, AL 35126 http://sipseystreetirregulars.blogspot.com/2015/05/open-letter-to-oregon-house-of.html
  24. I understand that too. Because the fact again I'm not planing on super long extended oil changes. But also I do understand the function differences of bypass filter vs. full flow that include a bypass valve. I would never want to run a filter to full plugged state either.
