Good Buddy Has A DuraMax......
Either... http://sinisterdiesel.com/i-16504546-dipaco-dual-stage-fuel-pump-with-pump-mounted-driver-for-gm-1994-2003-6-5l.html?gclid=CKOznYnDlMUCFY6RfgodNGEAhQ http://www.fordiesels.com/gm-duramax-bosch-cp3-high-pressure-injector-pump-97720662-2001-2004/?gclid=COC9yZrDlMUCFdKIfgod0hcAeA I'm not sure but that what a quick Google search turned up.
removing fuel sending unit
I've seen his setup in person but like I dummy I didn't get a picture of it. I did find his old write up... http://forum.mopar1973man.com/index.php?/topic/8113-truck-bed-tank-module-access-pics/
grandpa's truck what to do
I really do love old stock trucks that are unmolested. Looking back at a simpler time versus today where you can hardly find a engine under all the tubes, wiring and BS. Ford 6.4L Cummins 6.7L
Pick your brain
Next go around flip back to normal IAT.
Lift pump fail
I got to ask the question do you have a filter before the pump? I wonder if just the pure debris value of the fuel is enough to eat the shaft up. That is odd the seal did wear out first.
what are the proper step by step to increase Hp
Some of have computer scattered around the house so I can keep up with the site. So like right now I'm reading over the site as I lay in bed for evening.
If you just flash a Smarty tune and then return to stock the high idle is enabled. That is how I got my high idle enabled.
Pick your brain
Shouldn't. MAP sensor should adjust to elevation and sense atmospheric pressure changes. Unless your MAP sensor has failed within limits which will not throw a code. Possible. Colder the IAT temperature the more advanced the timing. Warmer the IAT the less timing.
Where all you guys/ gals live.... is it gettin' crowded too?
But the weather is nicer here...
Gain another member today...
OMG... JAG1 (Michael) want to have a get together here so maybe I could get all the "Mike's" together in one spot... Just a idea...
Blackstone lab/ oil reports
I'll have to dig out the owners manual again and take a peek at the Schedule B. But I'm not going to change every 3k that's plain nuts. Even the 1996 is set for 6k miles for V8 gasser. I was of the mind set of changing every 3k on the gasser when I first got it but then started to realize the oil was still rather clean. So I read the manual at switched to 6k and it just barely darkens by then. That's a 6 quart system. Now my Cummins is a 12 quart system (mine is plus one from the extra filter) and I would have to change at 3k... Not happening. Funny part is both trucks get used around here doing trailer hauling and wood hauling too.
I got a phone call from a Michael West in the McCall, Idaho area. He had question about a high idle box he had in his truck. It looks like one of the older one that a gent made over in Cummins Forum. (Can't remember the name). But we had a nice long talk about Cummins Diesels and different things. He's got a beautiful 2001 Dodge Cummins White short bed with 35" tires. Very clean. But now he wants to get into the economy mode and longevity part. So I gave him the quick lesson on diesel and tuning and how it works. Mike doesn't own a computer but he does have a smart phone. So his limited on abilities on the site hopefully he creates a account to hang out. Mike did say he'll be coming back to have me do more work on his truck very soon. I expect him to call me again. On a side note... What is it about Michael's? I'm one, then there is JAG1 (Michael) that spent a week here, now another Michael comes to hang out. No one yell Michael or Mike around here... You never know who might come running...
Carnage pictures...
That's fried for sure. Wow!
20,000 mile oil changes roughly every 3-4 weeks. So at 60 MPH which was CajFlynn average speed that's about 333 hours on the oil. So doing a UOA at 2,500 or 5,000 isn't exactly a requirement. Like myself I run 7-10k miles on oil changes. Owners manual states 7,500 miles for 2nd Gen 24V oil changes.
Return line should be fine factory sized. It's just the supply line that is not big enough. That is a option for most pavement queens. I would just check with local laws ans see if there is any problems with bottom draw tanks being used on highway. There is a reason the fuel is supplied out of the top for safety reasons. As for me I'm still looking from a distance at the sump idea just worry a bunch about the snagging on debris like tree limbs and logs that I run over. I managed to push a dent in the passenger floor in the back seat years ago from just running over a small log. The other problem I would see for city folks is anyone what to steal your diesel fuel will have a handy drain right there. Just unscrew the fuel line and all the diesel you can carry will drain out. I know I've seen reports of fuel thieves using cordless drills and pop a hole in the tank and drain it out.
If it was me. I would change at least the engine oil and fuel filter before starting up. Then change the rest of the fluid once you get home. 58,408 miles as Google converts... That truck is very very low in miles.
Ok... So what class do you have to be in to worry about oil analysis and what class do you have to be in to not worry about it like Cajflynn?
Thanks JAG1... Now everyone eat your heart out...
Like myself I'm a long distance from everything so every time I fire up it's not a 3-5 mile trip to the store but more like 70-120 miles trip to the store. Like now working from home when 6pm rolls around its a 40 mile round trip to New Meadows for my parts when I do have a parts order. So I'm not the typical driver myself. This year I won't be going into the back country much at all for firewood. So I'll have mostly highway miles.
Mine is odd... The tank band is under the carrier bearing bracket.
thanks Mike! I redid the air conditioning pump on my truck due to failed clutch.
Like down at Lindy's shop he usually grabbed the Windex bottle because it would foam right up on a leaking fitting, seal or connection. I've seen sniffers used but never per say used one myself. I typically used UV dye with a black light and soap & water typically. I usually base my recharging on the fact if the system has pressure or not. If there is existing pressure then typically I would just top it off and let the customer go with the notice that the system is leaking and should be repair when fund and time are available. But if the system is dry without pressure I will not charge the system not knowing if we have a severe leak or what. Then I typically will ask the owner if they would want it fixed.
That's my problem. I would have to take the canopy off first. Then clear the bed out. The unhook all the wiring and tail lights. Then pull the bed. Dropping the two tank bands (I drop the carrier bearing because of the front band is under it.), 1 electrical connection, 3 hoses and 1 fill hose and vent. Tank is on the floor. Notes If you want to get it done easier. Invite friends over to drink beer and get him to drop the tank for you.
The Uninvited Bees
You might have to go into beekeeping as well. Between Hex0rz and LiveOak I'm sure you can get some good information on bee keeping.
I tend to agree with Bill (Wild & Free) slow leaks and detecting them is a PITA at times. I fought that battle too on my truck where the freon would last just long enough for a summer and be dead. But with some of the knowledge I've learned in the years there is way of improving detection. UV dyes, Freon sniffers, Soap & water, etc. Just have to having the patience to do the work and get it done. Like the Chevy Blazer above has had a slow leak for many years I find got the owner to buy a seal kit and allow me to re-seal it. After leaving it sit on a vacuum all night and seeing the gauge still where I left it last night I was happy to fill it back up in the morning with freon. In A/C work a job well done you shouldn't see the custom again.
Front end noise - Tie Rods
I'm not saying it not possible to run taller tires but most people don't want to beef up the rest of the suspension and front end to handle the geometry changes. But thank you for the comment...
