Blue Chip Diesel FMS Box?
I'm not. But I've rode in one truck in Boise that had a Blue Chip box. I was impressed on the power. But once again most people don't think the price for the box and the limitations are worth it. Not exactly what I would want on top of my dash.
Why is my right tire wearing on the outside?
Ummm... Sometimes that isn't all true. Like my truck it now starting to show the feathering on the inside of the tires so I know I've got a mild alignment issues happening. I'll have to look it over and see what's going as well. I'm going to bet is going to be toe related.
Fuel Gelling with 2-stroke oil
I've gone from store to store and did my own digging. That's how I got this picture of the barrels of anti-gel or called PPD (Pour Point Depressant) behind a local Cenex Station. Like I said I'm rather fussy about where I get fuel. Like just down the road from me is Pinehurst Trading Post at 3/4 miles. I won't even buy diesel there if was cheaper. I know the fuel is not properly treated, low volume of sales, pump isn't filtered. Etc. But I know the local Chevron has to meet a certain requirements of standards. Below is the weather camera near me and I can see what I got for weather. South of me by 10 miles. http://lb.511.idaho.gov/idlb/cameras/camera.jsf?id=27&view=state&text=m&textOnly=false North of Me by 5 miles. http://lb.511.idaho.gov/idlb/cameras/camera.jsf?id=142&view=state&text=m&textOnly=false
Well, the airdog, once again..
That's bad. Now figure another $1,100 for the people without gauges and the replacement of the AirDog and the VP44. I've got those types around here in my local area.
bjytech I think is right. I'm not a alignment guy but I would figure you got one tire that is tracking straight and the other is dragging. I would like for worn parts and replace them first. Then consider heading to a alignment shop to be tweaked.
Between the Fuel boss and FASS would be my choice. But Ilikeoldfords pointed out your plumbing is already for the FASS.
Strange thing is I don't worry about cetane levels nor do I worry about pour point level. I only worry about lubricity. Now in 13 years I've never gelled up once. I'm very picky of fuel suppliers. Even with all the minus temps we get up here I've never had a issue with gelling up yet. To this day the only thing I use is just the 2 cycle oil.
Hmmm... Maybe if Charlie (Original Owner) still ran the show the pump would last as long as mine I'm on my home stretch for 10 years. I purchased my AirDog 150 from GOS Performance in 2006. Maybe if AirDog would listen to the customer base and suggestion maybe it would still be the same long lasting pumps.
Cracked Bezel
Nice... Sad the sun UV rays and heat makes all this plastic brittle.
Travel Trailer Help
Even though my Jayco is from 2000 it way over built too. Just don't look at the Lite series...
Front Crank Seal
I've checked mine a few times and its dry as a bone. The one that didn't take very good was the vacuum pump. It leaking not bad but its leaving a wet spot on the cross member frame.
Travel Trailer Help
Even mine is a so-so 4 seasons design. I've got covered tanks and some of my heat is ported into the cover tank areas. The only problem is the water lines leave the inside of the RV to the outside to get under the slide and then pop back up in the bathroom. This is its weak spot being there is no heat for this one area of plumbing. So when even looking at a 4 season RV make sure all water plumbing remains inside the RV and doesn't go through the floor. Other than that my furnace does a excellent job of heating at minus weather and I will tend to agree with AH64ID it does suck up a bunch of propane but you will stay warm.
The 200 vs 190 thermostat expierment thread.
Being Florida is already warm it might not net much of a gain at all. Were up north here might actually help the numbers because of the extreme cold.
Travel Trailer Help
Like I got to friend just down the road from me that wants to do the same thing. He's in the market for 5th wheel approximately about 30 foot or so. Something he can haul with his Chevy 2500 pickup. He done with all the renting homes and them being shacks like his current place. He's got property just north of here and would love to jusy drop a RV on his open ground to live in. Now with that said I told him to consider being mobile. Now he's loving the idea of being up north for the summer with family for the summer and then go south to other family in the winter. He's also looking into the winter package RV's with heated tanks and plumbing. Because this will be his long term home.
Driver side door hinge
Personally I would just change the hinge out. I've tried doing that on a older car and fought for quite a while. End up crushing fingers and parts attempting to fix that problem.
I think you jumping the gun a bit too fast. 1.2 MPG could be just the winter. Not to mention possible driving habit changes. Like myself with the lower price of fuel I'm driving a bit faster now and seeing a 2 MPG drop just from that.
Travel Trailer Help
Like I typically tell people... Base the trailer on your living requirements. Make sure you fit the RV. Make sure the RV will fit the truck. Kind of sad to buy a huge RV you can't tow. I would suggest buy a used unit. Typically used RV have much less problems than new units.
Grandson
Congrads to you and your family. Better teach the little one about Cummins Diesel later in life because yours will most likely still running by the time the little is old enough to drive!
Dorkweed is the one that started the whole 2 cycle oil concept back in the day. I'm the one that ran with it... OE VP44 died at 50k miles (P0216) and was replaced. I'm at 240k miles now. OE injectors are still very function and just stored away. My RV275 Injectors where used about 400k miles and managed to get another year from them. But then replaced them with +50 HP injectors and here I am today...
Scan gauge II question
I don't have that function.
Lets see who you are!
MoparMom's asking how old? How about your picture?
High Idle Kits
Right now the big problem is getting the site stable... First. Then I can move back to the high idle mod and get the stuff going with Ed. But I'm way behind with the server being too small and still need to install a better store software which is half done now. But I'll get back to High Idle stuff a bit later...
I typically don't suggest mixing products. Because some products negate the abilities of other products. Like PS is cetane boost and 2 cycle is a cetane reducer. Like PS is typically more of a injector cleaner / cetane booster and 2 cycle oil is more of lubricant. So mixing products might yield results less than favorable at times. If you use one product then you guaranteed success. Like if you stick to PS for anti-gel then the product will work properly without fail. But mixing with 2 cycle might create other issues. Becuase of how your changing the chemistry of the fuel.
Cleaning engine compartment?
Be careful with flexible neck or bent neck wands. You still have to maintain distance from particular things like cooler and radiators. Bossman down at the shop has a bent neck wand and thought he could use it to help clean out a A/C condenser but it was still way to close and the power washer was folding the fins over flat. Like myself for under truck work I wait for warmer days and use the slope of the yard. So crawl under from the high side and start spraying the low side as much as possible and work my way out. Then flip the truck around and start over again. This allows to hit both sides of the frame and body without laying in a puddle of water. Don't get me wrong your still going to get wet but your not going to lay in a puddle.
ABS / BRAKE Light
Mine was very obvious of the break. You could flex the jacket and clearly see the black wire was broken and the white wire was intact. I would suggest you inspect the plugs it might be corroded contacts.
