dually
Everything posted by dually
  1. Did you try 4wl with the hubs unlocked? That feature can be helpful in many ways.
  2. You could have a boost leak or even need a w-gate adjustment. What kind of turbo did you replace the factory one with?
  3. Thats not to bad. I see 800 at 70 on level road on a cool day. Maybe you should think about a water/meth kit? I didnt see injectors in your sig are they factory?
  4. The edge comp or edge/drag gets my vote. To me the edge comp boxes are the ak47's of boxes,they work no matter what . I keep mine on 5x5 most of the time. If it gets 90* or more and i am on the breeze way i turn it down because my truck will haze.
  5. The guys that p pump there trucks will speak against stainless. It is brittle and often crack and leak. Read up on it and you will see it is not the way to go. My opinion is based on the facts of p pump conversion lines. Your application is not quite the same but still i would never do stainless injection lines on any diesel.
  6. Look around for a used one. I found a miller 135 with a tank 1/2 full, and a cart with wheels almost a full spool of wire and other goodies for 500.00. The guy was moving out of state. Look around some.
  7. Dont feel bad. That happened to me a few years back. My friend towed me with his FORD. That hurt the most. New sending unit and i am good to go. My fuel gauge said 1/4 tank.When you fill up hit the trip that way you will know.
  8. She's perrrrrrrrrfect. Meeeeeooooowwwwwwonderful.
  9. http://forum.mopar1973man.com/threads/3692-What-oil-filter-do-you-use?highlight=oil+filter Go to the last page.
  10. When i changed my cam i pulled the dowl out and found a clean spot on it:doh:, What happened is as i was pushing the dowl on the wood splintered. First i took the tapet cover off (like the picture Mike posted) nothing at all. I drained the oil into a screen and found nothing, then i put a wire in the hole to no avail. I had to jack the engine up to remove the oil pan. I found the pc of wood.You never know where it will stop when something gets droped down. I sure would try the easiest thing first if i ever drop stuff in again.
  11. I never could understand this fully. If cetane makes fuel burn slower it should get better mpg? If 2 stroke oil adds btu's and helps mpg....i am lost
  12. The 98's and 99's dont have t.m. Thats when dodge started getting a bad reputation in reguards to trannys. Dodge had an answer, to help save the life of the trannys they came up with tm. Thats what people tell me anyway.
  13. I am glad it is fixed. Thanks for this thread.
  14. Last year auto zone had it for 9.99 on sale. Lets keep our eyes peeled for any deals.
  15. If you are talking about the ring that goes on the stud to sit on the drum i dont think you need them. It is to hold the drum on when new on the line so they dont rock when they build it.
  16. Look behind the drum. There is a slot that goes left to right. Stick a flashlight in it. You will see a wheel looking thing with tabs on it. Put a regular screw driver in it. Move it, if it stops go the other way, this will move the pads away from the drum. Take a hammer and a pipe or something and hit between the lug bolts. DONT hit the threads or your day will go bad. That should do it. After you move the slotted wheel in the drum move it back and forth and pull on it at the same time.
  17. No on the Grateful dead. Please understand i am not trying to make you feel guilty. I admire the work of musicians. I know they do it to themselves, i get it, i really do. Addiction is a sickness. My point is if the internet was around when hendrix died would we have this post? When there is a John belushi special on tv i never hear them call him what he was in a mean spirited way. Point # 2, is most of us here have had some kind of addiction problem or a family member has. point#3 If YOU like someone and they die from dope are YOU going to post jokes about them? Let me be the first to say, in some aspects i too am a hypocrite. I just hide it better. For the record i am not a Whitney fan. After she died i went to i-tunes and downloaded one of her songs. I do think she has a good voice and a sickness.
  18. HYPOCRITES. I bet of all the famous people you guys like never had a drug or alcohol problem.Really, now think about it. Do you like any kind of music ? Drugs and alcohol,yup never. Do you like sports ? Drugs and alcohol,yup never.I use to roadie for a famous guy. I have seen with my own eyes and experienced the lifestyle. I am NOT saying i know the life they live.Are you guys also saying you are good stewards with your time and money and how you treat your bodys? I dont think you guys can comprehend people opening every door for you, giving you choice food, any car you want, any home to live in any drug your body wants.Yes we all can say "well i would of" all crap my friends. You will never know how you will handle fame it until it happens.I like all you guys, i learn from you guys and like to chat as well. however i still respectfully say hypocrites.
  19. Men, listen to the wife. here is the proof. What did she say? "I dont feel safe" Some people will say they have some sort of 6th sense. I really dont believe that myself. I lean on the holy spirit of God. Anyway. your a good husband and i am glad she is ok. Now put a roll cage in that little dodge
  20. I dont know how far in the process you are but i couldnt see my leak until i removed the evap and looked under it.
  21. I too added dye. I didnt find it until i took the hvac box out. It was under the evap. I could charge mine up and it would last a few weeks,then a few days,then no dice at all. You could pull out the hvac box and replace the heater core wile you are in there.
  22. Get yourself a oil pressure line kit. It is only a few bucks and that plastic is about the same size. It comes in 6" length. If it is to curly slide a rubber windshield washer hose on it,that way it wont kink when you bend it.
  23. From what i understand about carfax is thats only reported accidents go on it. If you smash my dually and we dont call the cops and do a cash deal, my dually would get fixed but that record would not come up on carfax. My neighbor just bought a car off craigslist with a china replacemeny fender and that did not come up on his carfax search.
  24. Called the dealer today. You have a pm.
