BBHD
Everything posted by BBHD
  1. Is it all back together?
  2. I had this guy in the lower yard yesterday morning.
  3. What nuts did you guys( @trreed, @TFaoro, @notlimah) use for the tie rod ends? I read in @notlimah'a thread it was a M14-1.5. I've had one sitting in the shop for a while and was thinking of slapping it on this weekend.
  4. Some amount of air will move out any exhaust/intake valves that are open at all unless you loosen all the valves so they are closed.
  5. Yes 4x4, 6bt, NV4500, NP241DHD, 285/70R17's stock height suspension(probably settled) Quad cab SB
  6. I was finally able to get on some pavement. Measurements are straight up from ground even though the pictures look crooked.
  7. If I can get on some level ground I'll get some measurements for you.
  8. Have you tried cleaning it?
  9. My sister lives in Steamboat. I've been over that pass many times. It's beautiful up there.
  10. 2wd, Dana 44 rear, 727 trans and a 258 Inline 6. Steering wheel on the right. It has a twin that I brought up about a year ago.
  11. 2wd, Dana 44 rear, 727 trans and a 258 Inline 6. Steering wheel on the right. It has a twin that I brought up about a year ago.
  12. I hauled up a new little toy to Colorado yesterday.
  13. It's an adjustable boost elbow. You turn the screw in to help keep the wastegate closed longer in turn building more boost. I would suggest checking that screw for boost leaks as well. Were the injectors new or used when you installed them? I didn't look back in all the threads to see but if they were used I would recommend getting them re-popped.
  14. It's a late 40's early 50's Ford( my brain fart!)with I believe a little CAT and an Allison. It also has rear steer and can side walk taking up two lanes. I'm hoping to get a close look at it parked somewhere during a cruise weekend in Golden.
  15. Thought of this thread after seeing this in Golden, CO
  16. My front shaft measures 30 3/8" from t-case(241DHD) 4 bolt flange to front yoke strap flange. Nv4500 trans
  17. Shoot I won't be back up until the 25th. I would definitely be up for shooting clays. My uncle and I just tuned up his thrower a couple weeks ago. Let's see how the weather and work looks when I get back.
  18. It was nice day today for sure! We still need to meet up one of these weekends.
  19. Quick and painless. I enabled mine a few years ago with @TFaoro's smarty.
  20. Roadwire and Katzkin both make new leather kits for seats but they replace the existing upholstery cloth or leather and reuse the existing seat foam.
  21. Hmmm? Above Central City by chance @trreed?
  22. How does the tappet cover gasket look? Anything coming from the driver side of the block? It's a common leak point if it's still OE. They get brittle with age.
  23. @dripley that's the cheapest I have found as well. I never think to order one until I'm cleaning it or someone asks me about it haha
