jlwelding
Everything posted by jlwelding
  1. This 96 mod just started this misterious crack the throttle after he was pleged with alge in the fuel. Says everything was cleaned up, droped tank and it was spotless. I thought air leak after he said droped tank. :shrug:Truck has about 80k, all stock but the fuel plate. And that was just minior work there.
  2. When eng is cold my friends 12v will fire right up but when hot eng will crank a try to start but no go, crack the throttle and it will fire right up.What's up with that?
  3. 40 days of 100+ degree days, please let it rain
  4. And I thought I was the only one with a black cloud over my head.
  5. A rancher I do a lot of repair work for has a 06 I think, 6.0 and he was hauling 3 bulls when the turbo went out. So he takes it to Ford and they fix at it and 4k later he gets a call to come get it. Check this out though, the truck only has 10k on it. He only used it to haul loads with. So 10k worth of hauling and what 35k new.:lmao:I told him to get Dodge.Oh yea he asked Ford if they would work with him due to it still smells new on the inside.:lmao:
  6. Man you sound just like me, I got so much invested in my truck I got to drive it in the ground then plant roses around it for a rose garden. I think I would have to buy the flat bed and keep on truckin.Anything left of the deer?
  7. Just be sure to capture the the freon. There is extreme pressure in there.
  8. Dont mean to hijack but what would it take to run boost elbow on stock eng with no programer? I left my boost elbow on when I took edge ez off and it kept throwing cell light so I removed boost elbow.
  9. Rods? No problem this guy pull motor and stripped it, started dumping money, it's crazy what this guy spent. 180 or 181 cam the whole nine yards. I was wrong on the year mod. it's a 09.
  10. If you ever get the chance to ride in a really tricked out truck, jump on it it is ausome. This truck will smoke the tires at 40mph. He said here you drive I said bull s--- I aint got the money to fix what breaks.He put it in 4x4 high and I thought I was going to go thru the seat.
  11. I cant help you on that one. Hope someone will come along.Moderators, He knows he's posted in the wrong place. Can it be moved to see if someone can help?
  12. She only has 39k on the ole clock. I hope it dont have gunk build up.
  13. How many qt will it take to just change filter? And how many will flush take? 18qt is what my buddy's machine holds.
  14. If you dont need the dual disk, I would go with a southbend ofe. If I remember right I think I payed 650, but that was flywheel and all. All you need is 13" clutch and bearings, piolt and throw out.
  15. The rattling noise you described sounds like broke clutch springs. Dont hold the clutch in at red lights, put it in nuetral. You will eventually scar up the input shaft and it will then break or lock up.
  16. Did you write down serial # to send back to A/D before you mounted it to the frame? :lmao: Guess who didnt.
  17. I have heard there is no diff. heat sheild or not. The heat sheild that I build will help keep mud and water from splashing up on it. But I dont see it making any diff.
  18. I ran about 60k on my first one, it got a little oil on it and had to get rid of it:duh: we wont go there:lmao2:But I really noticed the turbo a lot with the new bhaf. You think we need to change a little more often?
  19. Man, it sure is pretty and green up there.
  20. oooh that Mike, yea his a pretty good fella
  21. Hmm, I like the thought.
  22. This is what is refered to as throw away trucks.
  23. It finally stumbled a little this morning. I watched the tach drop a little,I mean just a little then the motor, like turning on the AC and the light came on. What a joke, as many cam sensors as I threw at this truck back when I had all that trouble and now I get to use one of the three new one's I have.
