Rogan
Retired Staff
Everything posted by Rogan
  1. http://forum.mopar1973man.com/attachment.php?attachmentid=4499&d=1348267513 that is SOOO not how I pictured you looking like.. Oh, and...
  2. so I gave it another go today... no dice.. that mofo'n sensor is denying me retrieval...
  3. MY 2gen has good lenses, but the output is trash.. I can't hardly see a damned thing at night, especially on low beam..
  4. hey, fish. I believe they all had blocks, and all same height (2500 4x4, anyway.)My 96, 97, and 01 all had same size blocks. I never measured them, but I think (guess) they're around 3" in height..
  5. Wow, that's a big difference!
  6. I dunno.. I know they're hairline, but it'd still make me nervous...
  7. Of course it does... ;)
  8. TYC is decent quality for aftermarket..
  9. Maybe it's the twin turbos...Send 'em my way, and I'll install them and let you know if I hear anything... ;)seriously, keep us posted.
  10. Thanks. I was hoping to not have to pull that one as I can't get to it, let alone OUT.. From the Galaxy S3
  11. Where u guys putting your aftermarket temp sensor on the 12 valves? And what's this for?[ATTACH]4498[/ATTACH]From the Galaxy S3
  12. This truck is so hodge-podge, aftermarket OL packs wouldn't surprise me.. BTW, the Fennco 3" coupler lasted 4 days before it made it's exit.. It was really loose on the contact mount; it probably just fell off.. How do you secure yours to stay? - - - Updated - - - Russ, that piece you see is inboard of the actual spring mounts/stops. It's part of the bed..
  13. Hag, I used to run these exclusively in all my rockcrawler jeeps. They do transmit vibrations and road noise to the body, but they're rebuildable and easily maintained. The axle-end, I left the rubber style or urethane ones, for a couple reasons when using 3-link setups (like below).. 1. Helps aid in axle isolation. 2. The axle end doesn't need to flex yaw or roll, only pitch. On 4-link setups (where maximum articulation is key), I'd use the joints in both ends. This helps keep down the binding. Below is my 3-link setup. Notice the axle-end (lower LCA mount) is urethane, and the frame-end is the joint..
  14. My OE rubber 4wd U/LCA joints are rotted... I'm contemplating these @ $47ea: but like Hag, I prefer a smoother ride and these will undoubtedly transfer much road noise into the cab..
  15. It all depends on the 'brand' you ordered.. But I've never received a cruddy part from RockAuto.com yet..
  16. '97 3500 4x4, heavy-assed bed, 4:10 gears.. 4-5 @ 60mph empty, 7-10 @ 65mph towing enclosed trailer...
  17. John, I'm gonna have to check.. I may have them backwards.. - - - Updated - - - I mis-typed.. It is SynchroMax in the 5600, and Max Gear in the 4500... My bad; I'll correct the above post..
  18. I saw a Sheriff's Dept. car yesterday that had Hydrogen badges on it..
  19. I'll have to try this again, when it stops raining...On the plus side, I must've bumped something... My tach now works consistently..
  20. I can only imagine..
  21. I hear what you're saying, Luke..
  22. Ditch the 16.5 wheels and go to 16s, and your tire options double, while your tire prices half..Been there, done that..
  23. Only when I'm on a time schedule ;)
