Everything posted by Rogan
Photography - Snapshots of the Day
below pic was taken a year or so ago, while I was out cutting firewood, I saw this huge limestone wall/rock outcropping, that had this algae on it. I thought it'd make a cool pic. [*]Exposure Time (1 / Shutter Speed) = 1/80 second ===> 0.0125 second [*]Lens F-Number / F-Stop = 56/10 ===> ƒ/5.6 [*]Exposure Program = normal program (2) [*]ISO Speed Ratings = 320 [*]Components Configuration = 0x01,0x02,0x03,0x00 / YCbCr [*]Compressed Bits per Pixel = 8/1 ===> 8 [*]Brightness (APEX) = 487/100 [*]Brightness = 29.24 foot-lambert [*]Exposure Bias (EV) = 0/10 ===> 0 [*]Max Aperture Value (APEX) = 497/100 ===> 4.97 [*]Max Aperture = ƒ/5.6 [*]Metering Mode = pattern / multi-segment (5) [*]Light Source / White Balance = unknown (0) [*]Flash = Flash did not fire, auto mode [*]Focal Length = 500/10 mm ===> 50 mm [*]Camera Make = SONY [*]Camera Model = DSLR-A100 [*]Picture Orientation = normal (1) [*]X-Resolution = 72/1 ===> 72 [*]Y-Resolution = 72/1 ===> 72 [*]X/Y-Resolution Unit = inch (2) [*]Colour Space = sRGB (1) [*]Image Source = digital still camera (DSC) [*]Scene Type = directly photographed image [*]Custom Rendered = normal process (0) [*]Exposure Mode = auto exposure (0) [*]White Balance = auto (0) [*]Digital Zoom Ratio = 0/1 ===> 0 [*]Focal Length in 35mm Film = 75 [*]Scene Capture Type = standard (0) [*]Gain Control = low gain up (1) [*]Contrast = normal (0) [*]Saturation = normal (0) [*]Sharpness = normal (0)
Engine Cleanup
Mike, we just went from 70s on Saturday, to 1/2" freezing rain, topped with 4" snow last night..
Engine Cleanup
Krudkuttr on one I just finished a tbelt, steering line and valve cover gasket replacement on. Get kuttr. At Lowes Sent from my HTC Hero CDMA using Tapatalk
The above pic is of my friends Bimmer. Yes, the rusty hood is 'on purpose'.. some wild mushrooms in my front yard last spring: Lastly, some opened seed pods out on the farm, last year...
Fan Wrench
very thin wrenches for removing the fan/fan clutch.. similar to this:
Steering column gauge mount?
forgot to update, sorry guys.. It won't work. Well, it "would", but it requires relocating the rear-view mirror downward on the windshield. If you look at my pictures previously posted, you'll notice the 03+ mirror is much lower.. There isn't enough adjustment in the current position to accommodate the 3g style overhead mount. Not even close.
Fan Wrench
^^^ that's what I was contemplating doing..Nice avatar, btw
trying to find code # for paint
If it's silver, it should be one of these: Bright Silver Metallic Clearcoat S2/WS2 Bright Silver Pri Metallic Clearcoat SB/WSB Dodge vehicle color codes can be preceded by an letter such as P or Q. For example if you are looking for color code W7/GW7, it may appear on your vehicle as PW7/GW7 or QW7/GW7 or RW7/GW7, etc. It's weird that you list a different one.. edit: PFA or could be PFK --- Update to the previous post... mkay... could apparently be a PS2, PSB, DT9078, DT9079... Depends on where you look, online. Just refer to here:
- Photography - Snapshots of the Day
- 80,000 Miles......No Full Oil Change
I know this is an old thread; almost a year old...But it seems to have just "stopped" once Apache posted his findings... What ever happened?- 1.000.000 Miles Yet???
Wake up, there, Mikie!- Back door problem?
- wiring harness
wtf??- Oil Pressure
Coolant Temp fooler.- Engine Cleanup
my miracle cleaner: Let me find a before/after pic of my old civic's engine bay, after using this stuff.. edit: Here's a semi-before pic. It was actually a LOT dirtier than this. This is after Simple Green.. And here's after KrudKutter (air intake back on, as well)- wiring harness
sorta.. you'll possibly need to change a couple connectors at the trans, but it should work, aside from that. --- Update to the previous post... Additionally, I'll add that my '96 (albeit older) was originally an auto truck. I converted it to 5speed, and ran the auto harness for several months. My only illnesses with it were that the Trans Temp light stayed on, and and I had to change 2 connectors at the trans. Later, I swapped to a manual trans harness and ecm, because someone was in search of one to swap with their manual stuff, so I did.- Muffler questions
My 5" DE tbe came with a 4" down pipe and 4to5" adapter, then 5" the rest of the way. I pulled my 9000lb trailer today, and the exhaust tone was deep, but not really loud. Sounded damn good, IMO.- Engine Block Warmer
Nice, Don. Thanks for sharing (I didn't know what the firs pic you wanted was of..)How much did the socket thingy run ya?- Favorite Auto Parts Store
yeah, i know the thread is different, but that's not worth the $150 extra! :banghead:For 150-200$, I can put a couple aftermarket gauges in.- Favorite Auto Parts Store
I look up prices on the napaonline site, since my local store is usually within a couple bucks of that.. I ALWAYS shop prices before I buy a replacement part. As for the OP6725, that's still an insane price for a freaking oil pressure switch.. Not just NAPA, but any place.. Everywhere is way too expensive for that thing. Especially when a gasoline engine's OPS is like $20 bucks.- Tires
- True Mileage
this is absolutely correct..- Favorite Auto Parts Store
I have my choice of local places: AutoZone Advance Auto Car Quest Napa Motion Auto Pep Boys AZ and AA are usually one in the same. Although I usually drive past AZ to get to AA. I used to be a store mgr for AZ, and they treated me (us) like poo.. So I tend to avoid them. NAPA seems to have to order everything I need, and it's usually 20-50% more expensive. Pep Boys... well.. They DONT have everything but gas.. It always amazed me that as big as that place is, they never seem to have what I'm looking for, their counter people are brain-dead, and the only thing you can usually walk in, pick up and pay for, is something in the stereotypical aisles.. Car Quest (the one here is an actual distribution center) ALWAYS has what I need.... At a price.. But IF I need something and can't wait, here's where I go. Sometimes, their normal parts pricing will beat AA or AZ. Motion Auto Parts is basically a NAPA and CQ peddler, with a mark-up. So, if I'm not in a rush (if I can wait a day or two) I ALWAYS use RockAuto.com. Cheaper prices, BY A MILE!! Case in point, I am currently looking to replace my 24 valver's Oil pressure sender, since mine is stuck at 40psi.. Yes, key-on, engine-off, I show 40psi OP.. 2001 Dodge Ram Cummins Oil Pressure Sender: NAPA = $225 Echlin Ignition ECH OP6725 AA = $213 BWD S4192 AZ = $192 Duralast PS398 RA = $155 SMP PS407 2001 Ram 2500 Radiator AA= $341 Ready Rad 43-2464 NAPA= $303 Spectra NR2464 AZ= $240 Spectra 432464 RA= $166 Vista-Pro 432464 ...funny, all the part numbers are the same, with 3 different "brands"... makes a guy wonder..LOL 2005 Hyundai Sonata GL 2.4L Radiator NAPA= $299 Altrom ATM 1533408 AA= $180 Spectra 43-1501 RA= $89 Spectra Premium CU2339 Just a few examples, there. As you can see, I'm a price-shopper. And I always get at least 5% off on the RA orders, which usually covers the shipping fees.- How do I post pics off Craigs list
- Tap the lock icon next to the address bar.
- Tap Permissions → Notifications.
- Adjust your preference.
- Click the padlock icon in the address bar.
- Select Site settings.
- Find Notifications and adjust your preference.
Safari (iOS 16.4+)
- Ensure the site is installed via Add to Home Screen.
- Open Settings App → Notifications.
- Find your app name and adjust your preference.
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
- Select Notifications in the sidebar.
- Find this website and adjust your preference.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
- Click Permissions for this site.
Firefox (Android)
- Go to Settings → Site permissions.
- Tap Notifications.
- Find this site in the list and adjust your preference.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
