Rogan
Retired Staff
Everything posted by Rogan
  1. http://www.ls1gto.com/forums/attachment.php?attachmentid=129033&stc=1&d=1287012486
  2. you get 'em on yet?
  3. I run 295/75/16s on my '01, and it required I go with a leveling kit, as I rubbed the fenders pretty good..Granted, I run a 16x10 wheel with a good bit of offset, I just don't remember what the offset is , at the moment.. I've got about 1/5-2.0" of tire sticking out from under the fender lip..
  4. not a 5600, but my 4500.. I'm no stranger LOL
  5. I went with a MOOG unit from Rock Auto (DS1413) for $107. The ball joint head is a good 40% larger than the OE unit (guessing the percentage.) But, it was definitely more heavy duty. I wish I'd weighed the two, as there was a decent amount more weight in the MOOG piece, as well. I've considered the links (above) for the tie rod ends, but ultimately went with MOOG replacements. Ball joints are next...:banghead:
  6. It's all a matter of opinion; that's the bottom line.I prefer my 12v over my 24, even to this day. I like the ease in which maintenance and repairs are performed on the 12v. Diagnosing is less painful, to me, on the 12v, due to the lack of electronics. And I like my right foot pedal physically connected to the throttle lever, rather than rely on the electronics to do it for me. We all know how finicky electronics can be.as for tuning and making power on a single income, 12V is the way to go. Case in point: 400+hp is easily obtainable for under $150-200 on a 12v. $200 gets you squat for a 24 valve.At 400_hp, my 5 spd 12v got in excess of 25-26mpg on the highway at 65-68mph. My 6spd 24v has never seen north of 18, since I've owned it (both on 265-75-16s and 3.55s.)The downside to the 12V is what I experienced; rack stuck full forward in the IP while passing someone, creating a runaway situation. It was quite scary. A reman'd Bosch pump was cheaper than fixing the old one. Oh, and this was at 105k mi.
  7. The initial adjustment of the cable is the trickiest part of it all, installation-wise, due to it's design. Once that's complete, however, it should need no further maintenance, aside from an occasional cable lube.
  8. This will allow you to operate in low range, as stated above, but still have the steering advantage without the binding you get on hard surfaces in 4wd
  9. This is generally caused by something bent or worn out. It should fully lock itself into position. Is it only in 1st and/or reverse?
  10. Thank you I think I took about 60 shots of these two osprey and only got a handful of decent shots. --- Update to the previous post...
  11. that's a fair assumption ;)
  12. yeah. see, to me, that middle lower section looks just too bulky for my tastes.. it reminds me of this: http://t1.gstatic.com/images?q=tbn:ANd9GcS_LKLetM9ULqshTBEATC7x7PzaVEc8444uK8HcyaogvdW-QSV7 OOops, I mean this:
  13. when I made my catch-can setup on my 500hp WRX, I actually made a drain in the bottom that fed back into the block, recycling the vapored oil..
  14. Taken at Turkey Point Island, in Maryland, 4/11/09 EXIF Sub IFD * Exposure Time (1 / Shutter Speed) = 1/500 second ===> 0.002 second * Lens F-Number / F-Stop = 56/10 ===> ƒ/5.6 * Exposure Program = normal program (2) * ISO Speed Ratings = 200 * Original Date/Time = 2009:04:11 13:58:42 * Brightness (APEX) = 812/100 * Brightness = 278.2 foot-lambert * Exposure Bias (EV) = 0/10 ===> 0 * Max Aperture Value (APEX) = 497/100 ===> 4.97 Max Aperture = ƒ/5.6 * Metering Mode = pattern / multi-segment (5) * Light Source / White Balance = unknown (0) * Flash = Flash did not fire, auto mode * Focal Length = 3000/10 mm ===> 300 mm * Image Source = digital still camera (DSC) * Scene Type = directly photographed image * Custom Rendered = normal process (0) * Exposure Mode = auto exposure (0) * White Balance = auto (0) * Digital Zoom Ratio = 0/1 ===> 0 * Focal Length in 35mm Film = 450 * Gain Control = low gain up (1)
  15. I'd like a version of the BuckStop. I'd prefer that the girth of the bumper wasn't so broad, or low hanging.. Something like this: http://www.4x4groupbuy.com/store/imagemagic.php?img=images/Hanson_Offroad_XJ_Prerunner_Front_Bumper.jpg&w=400&h=&page=popup
  16. I'd do the cable conversion, before replacing the vac. crap. But that's just me. Only thing is it adds an extra step in using 4WD
  17. Mpg
    Rogan replied to dually's topic in General Conversations
    that's insane.. and a big tank, apparently.. 35-36?My 26 gallon cell is in constant need of filling. last fill-up was 22gal, 284 mi.. you do the math.. :banghead:
  18. I remember when gasoline was 20-30 cents/gallon, then shot up to like 40 cents, during the "shortage".. there were odd/even days when you could get fuel, and it depended on your license plate. Wacky..
  19. humidity kicks my fat butt.I just wish we'd get some snow of significance. This piddly .2-.3" crud is worthless. And it's so dry, it looks like someone poured pixy sticks all over the place. A light breeze is all that is needed to clear the truck off.And we've only gotten down to the high-teens, low 20s thus far.
