Everything posted by dripley
Air dog, pcm, I'm lost.
The oe harness for the oe fuel pump is the one that needs to used for the relay to run the AD you installed. If those wires are not used then it wont give the pump the initial bump at key on. If you do have the right wires and dont have the bump at key on it is most likely ECM related. Does the pump run after start up? I lost my lift pump a few months ago and the engine will idle fine with out the lift pump working. Surging at idle could be other things as well. Check for trouble codes. If you dont have a scanner a local auto parts should be able to scan it for you and tell you what they are. There is more than one thing that can cause a surging idle. The codes will help point you in the right direction. And as Mike says, rampant AC voltage can be the root of many issues. Fuel pressure is another cause of problems, and needs to be known. Also it would be good if you would go to your profile and fill out your signature with info on your truck so we know what we are dealing with. Different year models of these truck work a little different than others. By the way welcome to the forum. This place is the sole reason my truck is still on the road 355k mile after buying it.
Floor Board "clunk" finally fixed
i would like to think that i did check all of the bolts for tightness. I have looked a couple times and dont think that is the problem. Every bolt i checked was tight. I did notice a few days ago that the plastic rivet that holds the inner fender well on has pulled thru the inner fender and is loose. I bought some replacement rivets for this purpose. The fender well moves up and down and might be the source of the clunk since I only seem to hear the clunk at low speed on a bumpy surface. All I need now is some free time to replace them. I sure hope it is not a loose tower bolt, that would make me feel like this !!!!
low fuel pressure after Lift and Injection Pumps Install
It sounds to me that your problem is in the power to the lift pump. When my grid heaters cycle my fuel pressure drops a little due to the voltage drop. You should have 12v to the pump on the oe harness. You could try hot wiring the pump to the battery just to see if that solves the pressure problem. Could be something in the ECM going out since the 12v comes from there.
Site Update & Jobs
I am seeing some wierd stuff. just trying to get thru it for now. I miss the M's.
Whats the popint?
Takes alot of the fun out of shopping.
Misery loves company. 365 days of model a ford
A buddy and me had a 48 oldsmobile coupe with a flat head inline 8 cylinder back in high school. the head on that motor looked like a picnic table with spark plugs sticking out of it. The thing was huge. We had a lot fun in it but it was way beyond anything I knew about cars at the time. My buddy decided to clean the carb one and I walked in as he turned it over and something fell out of it. I was concerned about what where the part went back in and he replied "In this box where everything else that fell out of it". And that my friends was the last time it drove.
Trailer light issue
Did you have to buy a new one?
Replace PCM?
- Hard to start
The Fass and the AD both use the relay. It's purpose is to take the power load for the pump off of the the ECM and use the oe harness as a trigger for the relay. If the pump is weak you might not see the pressure bump, but it should bump power to it. Dodge gave me on of those when mine went, for a $1000 anyway. A lot of monery for a piece of crap. Anyway when starting the engine the ECM should switrch the pump on and of rapidly to produce about half pressure for cranking. Hard to see that since the engine should fire right off. Weak lift pump pressure can take out the VP in two ways. Lack of lube for the pump's internals and no cooling for the pump and the electronics that run it. Good chance that is what is going on like Ghostman says above.- Hard to start
At key on the ECM bumps the lift pump for a second or so. The pressure bleeds off immediately and will stay that way until you turn the key. The ecm then pulses the lift pump until the engines fires off. My understanding is the VP does not like full pressure when starting. If you have or have installed an aftermarket pump and it is connected to the OE harness, that is how it should function. So key on 0 pressure except for the initial bump. Does the truck start normally on cold starts? Have you checked for any trouble codes? If he is only seeing 7 to 8 psi while idleing, he is grinding another pump to failure. He needs a better fuel pump. The in tank pump is as bad as the stock carter pump or worse.- Replace PCM?
- Replace PCM?
- Replace PCM?
The ECM In my 02 controls the cruise not the PCM. Mine is completely fly by wire. By that i mean there is no solenoid that controls the throtle, it is all electronic. I think the early 01's have the solenoid. It is located under the driver side battery. Not sure I would believe them if you do not have solenoid. I am by far not the expert on this but the only problem I have ever had with the cruise was cured with a an ECM and not a PCM. I am only speaking for manual trucks with out the solenoid. What is the problem you are having and have you checked for trouble codes? Since the ECM cost a lot more than the PCM you just dont want to replace it and hope that was the problem.- abs
Much better pics than the quickie i took.- abs
Not all have 4 wheel abs. If you look at the lower right corner of where you post you will see "More Reply Options". click on that and you can up load them from your camera.- abs
looking from behind the right front wheel. My thumb is touching it. If you dont have the wire maybe you only have rear wheel ABS.- abs
The front ones come from the unit bearing and should be clipped to the brake line and up in to the engine bay. Just look for the flexible brake line. You dont have to take off the wheel.- Truck won't crank! 1998.5 dodge cummins
Try reading this http://bluechipdiesel.com/vp44_diagnostics.html it sounds like something in the wiring but I would have to let the article speak for itself. Hot wiring the pump like you did is about halfway down under header #3 in red.- Big Line Kit
- Big Line Kit
It has been like that since they installed near 8 years ago. I am very used to it. As long as I know how much is really in there, I think I will keep my $70.- Big Line Kit
mine was very similar to that when new. I could run 60 or 70 miles after empty, near 140 at the fuel light. All that changed when the dealer installed the in tank pump. Now i get 300 miles out of the first quarter tank and about 450 at half a tank, That last half goes away fast. When the fuel light comes on now I only have 3 gallons left. All by the gauge of course.- Big Line Kit
My scan gauge blocks it and with my hearing I dont hear the chime. But i know my fuel gauge and I reset my trip meter every fill up. The light comes on at 1/8 tank like mike's pic and I have 3 gallons left. I dont push it as much as I used to but I am still guilty of pushing it.- Big Line Kit
I understand now. my AD came with a kit to replace the in tank pump also. More or less a pick up tube as I remember that went to the bottom of the basket. Very simple but works very good.- Truck died on highway, and will not start, no other electrical problems?
Hallelujah brother. Happy to see you got it fixed. That is whole lot more electronics trouble shooting than I would want to mess with. But I am happy you got it fixed.- a double dog dare for those that might remember them
I guess everyone else is chicken sheet!!!!!!! Nice train by the way, had it all your life? - Hard to start
- Tap the lock icon next to the address bar.
- Tap Permissions → Notifications.
- Adjust your preference.
- Click the padlock icon in the address bar.
- Select Site settings.
- Find Notifications and adjust your preference.
Safari (iOS 16.4+)
- Ensure the site is installed via Add to Home Screen.
- Open Settings App → Notifications.
- Find your app name and adjust your preference.
Safari (macOS)
- Go to Safari → Preferences.
- Click the Websites tab.
- Select Notifications in the sidebar.
- Find this website and adjust your preference.
Edge (Android)
- Tap Permissions.
Edge (Desktop)
- Click Permissions for this site.
Firefox (Android)
- Go to Settings → Site permissions.
- Tap Notifications.
- Find this site in the list and adjust your preference.
Firefox (Desktop)
- Open Firefox Settings.
- Search for Notifications.
