Tractorman
  1. Not according the FSM...., Installation - Removal - (16) Support the cover on a flat work surface with wooden blocks (Fig. 105), and using a suitable punch and hammer, drive the old seal out of the cover from the outside of the cover (Fig. 105). It is probably not crucial to remove and install the seal according to the FSM, but there could be a reason for doing it this way. I used a sleeve and installed the sleeve and seal with the correct sleeve installer tool and seal installer tool. I have yet to see if there are leaks as I have not run the engine yet. - John
  2. That is a PTFE seal and it sounds like you installed it correctly. I am not sure if slipping in a standard seal size sleeve will stop the leak, but I can see how it may be worth a try. From my understanding of how a PTFE seal works, there is a frictional bond that occurs where the two dry mating surfaces meet on initial shaft rotation, before engine oil contacts the surface. It is that action that seals the seal. Hopefully, installing a sleeve will work for you. Let us know what the results are. - John
  3. Just double checking here. Was the new seal a PTFE seal? Was it installed dry (as it should be)? Interesting coincidence - I just installed one yesterday. - John
  4. I assume you talking about the driveshaft from the transfer case to the front axle. Has that driveshaft failed in some way? If not, I recommend re-installing the driveshaft and don't worry about it. Two weeks ago I pulled my non-serviceable front drive shaft for inspection. All joints were working smoothly. I re-installed it. It has logged over 380,000 miles. I used to be a believer that non-serviceable u-joints had shorter life spans, and maybe they did 30 years ago. Since then, I have learned that there is a lot more that goes into an OEM non-serviceable u-joint - mainly the triple lip seals that keep the grease in, and the dirt and moisture out. - John
  5. If there is no voltage present on circuit A, then the problem is in circuit A How did you arrive at "there was no voltage through A at all."? In circuit A, Fuse #9 (30 amp) in the PDC is directly wired from the positive post of the driver side battery. Are you saying there is no voltage there. Terminal #30 on the starter relay in the PDC is wired directly from Fuse #9. Are you saying there is no voltage there as well? - John
  6. The photos below show the wiring circuit for the starter operation. You can quickly narrow down the problem by removing the starter relay and using a jumper wire to join terminal #30 to terminal #87 in the relay base. Use the wiring diagram on the relay to identify terminal #30 and #87. If the starter cranks, then you know: Circuit A - There is current flowing from the driver side battery, through the 30 amp fuse in the PDC, through your temporary jumper wire, and onto the starter. Circuit B - You would need to check for current flow through the circuit that would begin at the ignition switch, an then pass through the clutch safety switch, the coil portion of the starter relay, connector C130, splice S128, connector C126, splice S168, and finally splice S109 that ends up at the negative terminal of the driver side battery. If the starter doesn't crank, then you know Circuit B is good and you will need to check Circuit A. - John
  7. Common rail fuel injection started in 2003 for Dodge Cummins engines. Each injector has an electrical coil and is fired electronically. Every injector has fuel pressure available 100% of the time via a common fuel rail. This is why these injectors are very expensive. One new OEM Bosch common rail injector costs almost as much as 6 new OEM VP44 era injectors. - John
  8. @Doubletroubleand @Mopar1973Man, I appreciate your prompt replies. I agree on many of your points regarding the life of an injector over time - specifically the weakening spring (lower pop pressure) and the internal needle and seat wear. I also understand that the injector tip holes can erode over time. I am in touch frequently with two other Dodge truck owners - one with a 1999 Cummins and the other with a 2002 Cummins. The '99 has 295,000 miles on the original injectors. I have recommended that he replace his injectors. The '02 has has 185,000 miles on the original injectors. Both of them still perform well and both of them have not experienced any change of engine idle rpm. So, what gives here? @Mopar1973Man, is it possible that this engine load / rpm change that you refer to is more evident with aftermarket high horsepower injectors and not with stock OEM injectors? Just my opinion, but I think the average life span for new OEM injectors for this era of engine would be closer to 200,000 miles. Thank you both for your input. - John
  9. I have heard the same, but it has never worried me. I believe there is a marginal sized oil passage for a particular bearing (not sure which one) that can starve that bearing for oil. I have a NV5600 that has logged 386,000 miles with no issues and I tow up to 21,000 lbs up 6% / 7% grades in hot weather. The only work done to the transmission was to replace the rear seal at 297,000 miles while I had the transmission out when I replaced the first clutch. I do make sure the oil level never gets low and sometimes even overfill it, just because of the above-mentioned oiling issue. I would place a lot more trust in a NV5600 or a G56 than I would in a NV4500 even after modifications were done. Beside, the extra gear is worth a lot, as well. - John
  10. First, I am not singling you out @Doubletrouble, but I am curious as to why there is so much emphasis placed on replacing injectors at 100,000 - 150,000 miles. Also, I don't understand the engine load / increasing idle concept that is displayed on the Quadzilla tuner relating to poor performance of injectors. The only tuner that I have used is the Smarty S03 during the last 50,000 miles of my OEM injector life. On my personal truck, I ran the OEM injectors for 303,000 miles. I only changed them out because I thought it was time and they had served me well. The engine rpm had never changed at idle throughout the life of the injectors. Fuel economy was always very good, the power was very good, the exhaust was clean (for this era of engine), and the engine always started fine in cold weather right up to the time that I replaced the injectors. In fact, when I replaced the injectors with RV275's, I really couldn't tell any performance difference other than the RV275's delivered a little more torque on the low end, but engine idle was the same - smooth, and at the same rpm, The OEM injectors (303,000 miles logged) are shown in photo below. In my opinion all of the injector tips looked very clean for the miles logged - no evidence of poor performance on any of the injectors. The appearance of the other four injectors looked the same as the two injectors in the photo. - John
  11. Looks like you made a good trade. Good idea having the skateboard for emergency transportation while you are getting a feel for the truck's reliability. - John
  12. The diagram below shows how I wired my 1999 truck with a 47RE transmission in stock form (3rd and 4th lockup only) when the truck was new. I used a momentary foot switch in series with a throttle switch. This allowed for manual operation of any combination of convertor lockup with or without the use of the exhaust brake or the service brake at any engine rpm in 3rd or 4th gear. I had no aftermarket computer trying to control converter lockup and exhaust brake operation. The system was very effective and would be even more effective in a transmission with converter lockup in all forward gears. - John
  13. @Sycostang67, your truck looks really nice! - John
  14. Well, that's going to be problem..., most drivers aren't blind , so are they going to hit it? - John
  15. Can you give more detail about the year and model of your truck? As for the loose headlight - the piece that you are seeing is not a nut, but a metal clip that holds tension on the guide pin that you circled in the photo. The clip may be missing on the right headlight. As far as the mystery wire connection - the year and any other pertinent information about your truck is needed. For example, on my 2002 truck there is no connector there, just a continuous wire loom at that location. - John
  16. You can use dielectric grease, but I don't think it will help your situation. The dielectric grease primarily helps keep out moisture and reduces the likelihood of oxidation on the pins. I would carefully inspect the multi-pin connectors for any spreading of the the female terminal and inspect for any wires that may be partially pushed back inside the connector. - John
  17. The two photos below show my setup using a 0-5,000 ohm variable resistor (potentiometer). I have it set to display a constant 143° when checking with my OBLink scanner. The temperature never varies. There are lots of resistors (fixed and variable) to choose on Amazon or other sites. Here are some excerpts from Michael Nelson (Mopar1973Man) from a few years ago. They should be helpful for understanding how cold intake air / warm intake air affect engine performance and fuel economy. - John
  18. Mine has been on my truck for about 8 years. I will take a photo of it tomorrow and post it here. From what I remember, it is a 5,000 ohm 1/4 watt variable resistor. I mounted it in the engine compartment near the driver side hood hinge. Essentially, the IAT sensor is disconnected and sealed off. A two-pin Deutsch male electrical connector with a six inch lead can be purchased from Amazon and used to lengthen the wiring to the the mounted potentiometer. It is a relatively simple process. I can post more detail tomorrow. Also, I forgot to mention that I use a homemade winter front during the winter months for faster engine warmup and improved driveability. This also helps improve fuel economy. - John
  19. The speed was quite variable. On the way to Cresecent City, the roads were snowpacked for about 350 miles, so speed was about 45-50 mph with a lot of time in 4WD. On the return trip, speeds were about 60-65 mph where the roads were clear which was most of the way. The speeds were slower through the mountain passes (7 passes each way). - John
  20. Have you done the IAT sensor fooler with a resistor yet? I use a varaiable resistor that sets the IAT sensor reading at 143° all the time. This really helps for winter performance and fuel economy. Plus, the engine runs quieter when cold. I use a Smarty S03 on a mild tune with stock timing - RV275 hp injectors. About a month ago, I made a trip from Baker City, Or to Crescent City, Ca (a 1,000 mile round trip) carrying about 800 lbs in the bed for traction. I averaged just over 20 mpg with ambient temperatures ranging from 5° below zero to 40° above. Most of the time the temperature was in the 20's. - John
  21. How about when the engine is at idle. Does the APPS stay at zero percent when the engine rpm's vary? - John
  22. I use an OBDLink LX OBD2 Bluetooth Scanner through my Android phone to read live APPS signal data with the engine running. Do you have this capability? It would be good to verify that there is a 0 percent APPS signal commanded when the engine is at idle. What exactly do you mean when you say, "I can watch my throttle on my adrenaline and its fluctuating up and down when using accelerator."? Are you talking about the per cent of throttle commanded? A steady throttle should result in a steady per cent value for the commanded APPS signal. - John
  23. Since the W-T wiring mod essentially shortens and improves electrical grounds for the ECM and PCM and alternator, I would think it would be less likely for electrical interference to be a source of your problem. Not sure if you have done the mod and also not sure if your question was referenced to after the W-T wiring mod, or before the mod. - John
  24. Interesting that the surging goes away while using cruise control. With manual transmission trucks, the ECM controls throttle while using cruise control - the APPS is completely out of the loop. It seems like you are getting an unwanted signal through the APPS when driving without using cruise control. I think you need to physically disconnect the Adrenaline completely and then test drive. If possible, use a scanner to observe the APPS signal with the engine running and while driving the truck. With the engine at idle, the APPS signal should be 0 percent. This is controlled by the idle validation switch in the APPS. I recall someone having a similar problem and it turned out to be that the throttle low limit set screw was loose and the APPS couldn't set the idle validation switch. - John
  25. I was wondering if there was a latch adjustment of some kind. Thanks for the tip. - John
