Everything posted by Evan
Quadzilla adrenaline boost issues on my 99.
Power driven diesel should treat you right they seem to be stand u company
When "bolt on"isn't quite bolt on
Looks closer to bolt then accidentally ordering a 3rd gen short actuator turbo with a 4.4" exhaust outlet. That's what I did had to redo cold side and fab downpipe still have not figured out waste gate. Ran it now for quite awhile with waste gate turnbuckled closed.
Idles fine, sluggish response, no boost, no codes
I cleaned my motor ounce with sewer cap on the turbo. With filter in the back seat it didnt want to run at all.
Sound like a boost leak ?
Lol yeah. Truck is kinda on the back burner latl. Its parked 3-5 days a week. Seems shes now alittle hard starting after sitting for few days. Dunno why. If I cycle the grid heater twice it starts easier. Then back to normal. Temps are warm here.
My idea of the ultimate towing turbo
Whoooooa whooooooa whoooooo I saw that sac 150 price ;)
Rpm is 2200-2500 shes been smoking more than normal. Smarty is on 9 3 3 3. Used to only haze over 1800 when really on it. Sac 100s are probably tired over 100k. Would they still smoke at higher rpm. I haven't pressure checked anything It makes nearly 40psi. Putting around rarely over 20. Egts never over 1200 around town egts are 400-600 cruising about 750ish. For some reason I suspect a boost leak. Just thinking out loud as I've been noticing a noticable amount of smoke that isnt normal . With about 10k behind it I was pushing black like a freight train getting into traffic on the freeway rpm was around 2000. I actually chopped the throttle thinking something was wrong and merged onto the freeway. Thanks for helping me think.
VP44 help
Guys please whisper when talking about this stuff.
Need help
I'd check cable terminals below drivers battery and all other cables first.
airdog 4g 150 install trouble
What do you mean straw wont reach bottom of stank? I cut mine so it reaches bottom. Maybe I didn't follow directions?
Turbo/Injector upgrade (Heavy Towing) Shoutout to Me78569
62 65 14 turned my truck into a towing machine. I'll agree 350horse tows well and runs cool. I regularly tow 18k plus with cool temps. It definitely moves some air. I think it spools fast. Fast enough to surprise many here. In 5 years itl be mandatory to have 62 almost like it seems the truck wont run without a quad now. Lol
I also found his comments on the draw straw odd I will say diesel guys and tranny builders are set in their ways and are stubborn as ****. They have good reason its because they're always right ;) I run the draw straw and can suck 50 gallons out of a 30 gallon tank. Could only pull 40 with the factory pickup.
He does have reputation. Though I've never personally met him.
I'd it running now? Headed for freeway and cruising by
Giving the jeep some tlc.
Thanks dripley I love it here. I built shock towers through the floor then I see this in my head. Offcourse I built it. One thing I've found is jeeps might go damn near anywhere but you cant bring **** with you May build a bulk head behind rear seat to mount shovel and hi lift on. I feel naked without a pony shovel. At some point fuel and spare tire will go on the roof. 120 Mile's is pushing it pretty hard. Heres how the storage started. Shocks are new take offs that came off gladiator. I'm believer in good shocks now. This jeep rides and handles very well. You can hit bumps at speed now. Slow trails are more comfortable. The truck may get some someday. The bilstein do little to nothing literally compared to blown leaking shocks they replaced. Have a good one everyone
Thanks. Joint at pitman arm wouldn't take grease. Props to ruff stuff they sent a replacement no questions asked. From yesterday
I did not meddle with return line when I did mine. Did draw straw 1/2" all way to injection. Fuel returns through factory line. It shouybe all puslock connections now with a fitting supplied to gl into filter houseing. Plug harness in supply power and go. I pulled my bed off
1ton steering and track bar Knuckles reamed Trail tested. Feels great. No bump steer. Took my time making sure drag link attach bat werecat thecsame angle and length
No start need help!
Anytime, glad to help
No start need help!
I'm going to go by tonight . I have sledge hammer. One good wack will make it good as new. I told him crack all 5 crank to see if fuels present at the head. Will my smarty read his codes?
Still truckn
Just moving equipment across boise. My truck is last two move. Takes me 3 trips minus my truck Mike should have snow this a few days ago. Can still go sledding if I want Here's 8500 elevation a week ago. Christine is on 4'-6ft of snow.
Dynamic valve body
Dammit you and he beat me to it
Still truckn
Kina was 1.89 gas 2.47 diesel
Still truckn
That's a sweet truck. How much is fuel up there. Diesel is 2.40 to 2.50s down here. Rumor is barrel prices have gone negative today
Still truckn
Dynamic valve body
When you have to let off to make the up shift does t slam in. Does it upshift with normal pedal pressure. If so what rpm.
