Everything posted by Evan
another 47re question
Put neutral idling for 5 or 10 minutes. See what that does. Power braking is super heating the fluid. Might be a temperature thing
Safe to assume my alternator just quit?
Pdc? Terminals in fuse block? That's where I thinking to put. It Power distribution center.
Wil do. Yes its been hooked to alternator per air dog directions
New alt is charging well However lift pump wireing does not fair well wrapped around the fan No time working today hauling rd mix to Kuna working to stay working doing repairs and fixing my screw ups
I don't know. Curious if it will start in gear
I don't anything extra. Its changed now on the rd again. Factory alt had metal dust falling out of it
Well I have an alternator on me. Running on battery power for 60 miles. Can she do it. Pumps down to 15psi. Not even to freeway meridian yet Maybe I have tools.
Old ken and I are stopoing now for alternator . Hoping napa is open
The place mike mentioned his great reputation. I do sometimes work near them but today
Ok. I may just grab a alternator before parts stores close they're doors for awhile
Did a throttle chop as check gauges light came on voltage reading zero. Got to job site checked cables fuses restart truck and voltage reading well under 14 but not tripping check gauges light. Alternator has 334665 miles on it. Anything else to check before I replace it. If I do replace it should I keep it to have rebuilt. Or turn in as a core. I'm in Star idaho closest place to me is NAPA . Thanks guys.
Built 47re 2-3 Bind Up Help
10/4 Mine runs almost the same locked in 3rd and 4th. Close enough I'd call it the same. When it sees ove the the 95ish could his computer be having issues?
Isnt 122 alittle more pressure than stock. And about 50s at idle Also noticed TC lock in 3 and 4 is different. Should it be?
1st post and need advice and or help ?
Theres a small vacumn line by the power steering cap that can get damaged by breathing on it wrong.
New turbo and injectors
Just to feel 150s and that turbo on factory tune. I'm running almost factory tune 100s and a similar turbo. My injectors have some miles on them. May bump to 150s soon I don't feel I need much more than turbo and injectors
Pepsi's modified 1999 Long Term Injector study.
Lol.
Almost! Depends on where the user tunes the power to come in. Back in the day the smarty ws popular for its plug and play power off idle. Offcourse this is where the transmission is making its least amount of pressure. So it needs to be adjusted accordingly to compensate or fuel turned down. The smarty just isn't a programmable programmer like the quad that can be refined through pedal range and power band . I'm still uncertain what change sw# has compared to tm# seems it may change alittle with sw#
Torque converter slippage
If temps are regular over 150deg with no load I'd say theres large percentage of slipping
Homemade Intake Horn
The more power we make from the fuel burned under the hood the more pressure we need from our hydraulic fluid in the transmission to hold that power. Does not matter what name is on the programmer . Us auto guys have more tuning to do but end up with good drivable combos that are a step above the stick sticking out of the hump in the floor. Ooooops did I say that
350-400hp 24v Auto
1200 sounds very fair to me
I don't think he wants to change tune
I bet your rear mains leaking. Is it shifting higher rpm now that the tv is reset?
Drove right thru a milestone
That's awesome. I'm also bout 160 behind you
Need to know what kinda of pressure you have before raising it. I've found very slight TV pressure changes can affect shifting alot. Like dynamic said loosening TV cable might help improve shift feel. I to like dynamic. Hes not a bullshiter
