Everything posted by Evan
Giving the jeep some tlc.
Got relay headlight harness in. I think I'm sold on it and will be doing it on the dodge. Noticably better light These are factory style halogens LEDs should be here tomorrow Do these look to high?
New Lights for my 2015 JK
Sweet. What are halo lights? I have projector LEDs coming for my jeep that say halo in the description
Muffler options.
2000 at 80 peeeeeerfect. Stock is not perfect.
4th Gen shocks on 2nd gen?
I looked them up and they appear to have eye bottom mount and post upper so will bolt on our trucks however I'd assume the bt size is the same. I also have no clue what kind of suspension is on 14-18.length could be way off. Not sure these trucks mount shock inside coil. Good luck. Also no any shock can be made to go anywhere with enough effort thought and time
1999 3500 Cummins won't crank over
This may be my simple mind working but if the truck wont crank or start how can it have trans issues? Is there more to the story. Dont **** with electrical that's has anything to do forward of trailer plug on rear bumper.
Can't boost above 22psi with the wastegate plugged
I would not be to concerned about max boost but watch how the truck makes it. Does it easily make 10 -psi to 20 will it go near 30 with some spirited pedal imput. Is she light on here feet or moving like big girl packn a fistful of cookies with crumbs all over. I wouldn't be afraid to turn timng off and give it a spin
Muffler options.
I think it starts right at exhaust hanger that's bolted into the trans crossmember
Muffler options.
Fte pulling to 80
High idle not working
My high idle came on this morning then idle around the block for coffee and it came on again. First time ever its came back on after kicking off by my foot
Engine died driving down the road won't start.
I 2nd checking for fuel at injectors lines. Pump can go with no codes mine did
Muffler options.
Me to. My pipe came off kenworth w800. I have more in the down pipe and 4.4 flange then the entire rest of the exhaust
Muffler options.
Sw3eeeeeeeeeeet I've thought about a 4" fte as close to the turbo a possible in vertical pipe
Muffler options.
I'd steer clear of ubolt clamp if you think you might want take it apart or make adjustments. Band clamps and slip fit pipe is the best option
Muffler options.
3cylinder high idle 30" fte 4" down pipe to 5" at horizontal pipe. Fte is 4" inlet 5" out let Much quiter than some 4" straight through mufflers that have packing Muffler and resonator are one and the same knock the sound waves down as close to the source as possible
DO EXHAUST RESONATORS ROB HORSEPOWER??
51" Donaldson fits semi's 5" exhaust straight through design. Walker also makes one and napa sells they're brand. Donaldson has cfm ratings and sound levels. There is straight throughand one with baffles
Wheeeerd. My high idle has came on tice this winter. Just factory high idle turned n by the smarty
47re issue
Another one bites the dust Maintenance really isnt bad. I've been keeping mine going for 15 years and find high mileage gas vehicles cost mre to repair and keep going. my transmission is the only big ticket item I've dealt with. I kinda consider it a consumable part that will need replaced or refreshed every couple hundred thousand.
I'm debating 54" Donaldson. I must b getting old
Recommendations
Whos doing that?
62 or Compounds?
DAP says 62 68 12 and 62 65 14 are about the same . No idea on compounds
24 Valve turbo / injector upgrade
I bought injectors from ducky fuel injection. Great guy with lots of info. I'm running his 100s they're on 50k or so. At some point I'll replace them with 150s I have sxe300 from texas machine(smedding) seems to be doing well. Probably have 20-30k on it
62 or Compounds?
My 62 65 14 spools very quick with 100s temp doesn't seem to go over 1100s towing fairly heavy. I'm sure I can bump to 150with similar results With the bigger turbo and towing I'm lit and making 20lbs just of idle pressure will rise about the same rate as pedal is pressed puts a huge grin on my face I dont know how characteristics would be with a 6speed. But the auto builds boost and holds it through the gears. Boost is there with no programming just Injectors and turbo , heat does not seem to be affected either way by adding or taking away fuel with the smarty . For me it's a solid set up I'm so glad I went turbo before a quad. I feel those that go quad injectors then turbo later will be watching they're temp gauge alot.
Couple questions
I change both about ounce a year. I dont really care how many miles are on it. After a year its dirty grungy and looking tired. Wether or not it actually needs replaced I dont care cause it just looks like it does
Coolant system , power steering pump , intake. Led projector headlights on the way Also got headlight harness from ksuspension in nampa
62 65 14 or 62 68 12 Either turbo will work great and make the truck a trailer yanking animal
