Evan
Quarterly Subscription
Everything posted by Evan
  1. Pull the front driveline off and drive it. Eliminate that atleast. Check for rocks between rotor and dust sheild. You've eliminated transmission and transfer and motor. Have you actually done anything. Looked t dust shields? Pressure wash it. Spun the front wheels by hand? It will let you know soon enough but in mean time you yet to listen to horrible noise.
  2. Put it in 4low see if the noise stays the same with speed. Or if it stays at the same rpm. In 3rd gear doing 35 40 Then rpm matched in 4low but youl be going slower. These will kinda tell you if its motor tranny noise or if its behind the transfercase. Not sure Im explaining this correctly To me its sounds like a driveline moving speed type noise I doubt it's to terribly dangerous. And will soon show you what needs fixed if you dont find it first. Keep on driving her shel let you know. I cant hear anything weird in your vid.
  3. 60Lube locker dana 60 gasket. I say 60 because they may not list it for the70. 60 70 have same cover. Upgrade gasket and cover together. https://www.ruffstuffspecialties.com/catalog/D6070COV.html Fluid looks normal to me Pinion nuts tight? Ujoints at CV joint on front driveline? Bent dust shields rubbing rotor Any ujoint Front unit bearings. Does noise persist rolling in neautral
  4. I'd start t gov pressure sensor and transducer. I would not rely on cdes . My truck didnt throw codes for transducer or sensor and i had 2nd gear starts. My vp44 went out with bo codes to.
  5. I wouldnt discount the power steering yet. Also not sure I'd go by the indicator lights on the dash. Jack up front tires ensure power steering is full. Turn wheel slowly with cap off power steering resivor. This will purge air. Check brake resivor. Check all 4 corners for leaks. While front is off ground turn tire and notice if wheel bearings are crunchy and dragging. The bearing goes out and gets hot enough to melt the abs sensor. If no leaks and everything seems good. Bleed all four corners. Starting at banjo fittings on calipers then go to bleeders screws. Would best with a helper but can be done alone. With abs light on something is wierd. Leaks, low fluid, air, master cylinder itself, sensors. Since yours seems mechanical I'd say it's not the front abs sensor. If it's cold there it could be seals,master cylinder and calipers 2winters ago we dropped to -15s and my brake system pretty much went **** up and said I'm done. Calipers leaked master pretty much everything with a rubber seal gave up.
  6. Is the under 45 crowd making a new wagon? I'm impressed by both set ups. Led and hid. Will hid get warm enough to melt snow. That would be my only draw back from going led
  7. I think Mike was saying youd like the lights but I'm not sure. I think the phone is set on her mode or is focusing on the dark areas to pic up the stray light. Phone may or may not be intensifying the scattered light. Does appear to be on far edges of the lense I to would be curious what they look like coming head on. Though to me on the wall they looked adjusted alittle high. But I have no clue the actual right way to set them
  8. Looks pretty darn good to me. Looking forward to hearing more.
  9. I agree about proper installation. I actually called and asked about lights blinding people on low. They said installed a adjusted correctly there are no issues. Spent 15 minutes or so talking lights with a guy. You have any pics of the hid burning next to the halogen? Can you see alot better now? Was it worth while? You gota remember this forum has a handful of guys on it that are old and done it all. tons of great info provided but they all tend to do the anything and follow eachother often times it is best to get in the wagon and be like the crowd but not always. Plus I'm not always wanting to go the same place the wagon goes
  10. Put my driveline on so I yanked the tcase into gear and no 4wd indicator on the dash. Mines a 02 non cad so no vacumn actuator in front axle. But it got me thinking more on replies here and if I have a vacumn line off. Sure as chit one of lines coming from under the drivers battery was off. I hooked it back up. Still no 4x4 indicator but blow by was reduced a ton. Or appears to be reduced also thinking truck is running better that's probably just in my head. The 90deg rubber boot coming off the vacuum pump looks shriveled and sad I should replace it. Thanks for help and not telling me my truck needs a head rebuild
  11. Thanks. I'll check it out for vacumn leaks. And look into vent mod
  12. I payed 200 for my smarty
  13. No time. I've rebuilt myself and they tend to grenade inside a year after I rebuild. Not sure why that is. Technician error I suppose. Lacking time I rotated tires yesterday on the jobsite. Not even sure how I'm going to get to six states by 5 this week to pick it up. Its actually a driveline I fabbed. Driveline guy was impressed that I built it. Yes that bottle Jack's about to fall Might do something about my t800 lights first
  14. Thank you. I'll watch it and run it
  15. No time. I've rebuilt myself and they tend to grenade inside a year after I rebuild. Not sure why that is. Technician error I suppose. Lacking time I rotated tires yesterday on the jobsite. Not even sure how I'm going to get to six states by 5 this week to pick it up. Its actually a driveline I fabbed. Driveline guy was impressed that I built it. Yes that bottle Jack's about to fall
  16. Been noticing mist or smoke in the headlights. Yes I yanked the bottle off long ago. Hoping valve seals is all. It doesnt use any coolant still runs the same also doesnt use oil. I am 1/4" over the hash mark on the dipstick but I doubt that's it. But who knows. Odometer reads 323k not sure I trust it. Never had more than a valve adjust. Is it time to upgrade the head? Hoping its semi normal and I'm just noticing since about 90% of my driving is in the dark right now. This is first year in about 8 that I've used her for work.
  17. Boys I'm doing it to. Getting my front driveline built right now or I'd of orderd already.
  18. Has it ever died on you then restarted like nothing ever happened?
  19. Sweet. I think it's an awesome budget light set. Post pics of install. Cant wait to see how you like it.
  20. I think the 35w hid have like 3000 more lumens then our factory lights. So I agree 35w should be plenty. I might be off on that lumen number. I dont think youl be ordering another set up. This is mopar specific kit. https://www.theretrofitsource.com/mopar-bixenon-morimoto-elite.html This kit you have to choose 9004/9007 bulbs in the pull down menu. The kit you linked. I think? https://www.theretrofitsource.com/9004-9007-morimoto-elite.html?preselect=51812%2C47589%2C47310%2C48181
  21. Crazy how hard a wind sail is to pull compared to aerodynamic trailer. To me it seems like you may need injectors. Your truck sounds like mine when the injectors were all carboned over. Yup forget overdrive or even really attempting to run at the posted speed limit. With 100hp injectors things changed and I could run 80mph cruise control set with truck not even noticing the small rollers . Later added a 62 turbo pulling all grades at ease with egts comfortable below 12.5 with pedal avaible to accelerate and get around slow vehichles. My turbo is a smedding turbo. 62 65 14. To be honest I think I'd go with 62 68 12 that DAP sells they're basically the same turbo but I feel better support will come from DAP. There is a small chance support may be needed with these cheap borge turbos. Myswell get injectors from DAP to. I'm running injectors from Ducky Fuel injection. Have nothing but good to say about them. Took me a couple weeks of questions over the phone finally made the decision on 7x009 sac's theve been great now for 6 or more years. Time flys maybe 8 years
  22. I'm going to do these to. Will have to see what the elite kit is it's about 28bucks cheaper than the other kit. I'll be a light scattering jerk with you, Make sure they are adjusted correctly and probly be good to go. Please report back I'm very interested how it goes for you. I'm going to do clear lenses. And 50w is tempting though I'm sure 35w is more light then I'll know what to do with.
