Everything posted by Evan
CAD Questions
I think they went non cad in 01. I'd verify 4wd doesnt work before spending to much time. My first thought was also that inner axle was swapped for a non cad 1 peice axle. With the noncad axle it no longer needs actuator 4wd will be engaged when transfercase is engaged. Wether or not light on dash is lit. Hmmm mines an 02 ,non cad. Ah64 Is damn smart. So if the truck is noncad but has cad axle4wd wont work well or possibly at all since axle will be disconnected unless it has a inner axle for a noncad axle reinstalled in the cad axle. I'm sure I've made no sence
Dana 80 4.10's to 3.54 swap
Yes. Had this truck for 12-15 years. I grew to hate it as dually now I love it. I should have tossed a bed on it from day one She stil works just fine minus 2 tires.
New Headlights for Big Blue
There are definitely times to not listen it surprisingly seems lights we agree on. I saw a 2nd gen in my town with projectors kinda wondering if were behind the times hidden in a dark corner. Maybe everyone has them and I'll start noticing them now. What are you doing with your other lights
Sucks on the highway
Injectors. Mine was like that till I changed injectors at 200ish . They were carboned over pretty bad
I like to build saws
Been awhile since I played with saws. The other day this 372xpw popped out of nowhere for cheap . These are lack luster saws xpw runs concrete saw cylinder dropped on a chain saw as factory big bore. It was a flop meant to run with the 75cc stihl 046. But actually was out done by the 70cc 372xp I tore it down raised transfers 2.5mm to advance timing and raise rpm. Also widend intake and exhaust. This should up rpm and overall power. From passed experience it does Did a few tree jobs might play more this coming spring in the tree's
Be alert!
**** that's nothing till you pinball through a heard of wild horses . I absolutely love Idaho you never know what's around the next bend as your thinking about that a moose jumps out in front of you. Yes a moose
What's not adjustable? My taxes are due back any day. I may just do this.. Been putting lots of miles on in the dark
I have tall tires to 285x75x17 not quite 35s. I think I'd be hating life if I had 31s. Though guess I'd just drive slower. I think youl be 2200 or so at 80 with small tires with 3.54. Manual and auto spin about the same
That's to far. I tried. I do very much like .3.54s I tow at 80 at 2000rpm when empty I run run 1800 and under. No sense in going slow for mog while loaded
HE351W Turbo upgrade
That's a s300 right? Wht was leaking after clcking.
Front brake pad life, auto trans
I have carbon fiber front pads and have little rotor wear after 50k. I'm running napa branded rotors. My rears are ceramic and also seeing little wear. I don't get n brakes hard.
Help Please
Did you pull accumulator spring. They break kinda often
upgrade HY 35 turbo to HX 35
I'm running a 62 65 14 turbo with 100hp injectors with smarty on 3 timing at 3 and duration 3. Truck makes more power then I k ow what to do with. And runs cool towing some weight. I had 100hp injectors with the hy35 and had to peddle of egts had waste gate turnbuckled made about 28is maybe 30 sometimes. And had peddle off egts towing. Now with 62 65 14 turbo I go as fast as i want while towing never even really look at egt gauge anymore. I get 17-19 but tow allitle on st every tank. Idrecommend a 62 turb and 150s then add programmer later. If it spools slower than hy35 it's just barely I have not done head studs yet and make a about 38-40psi. I'll do 150 injectors at some point and studs
4.4 to 2" back 3" is what that picture looks like with red paint
Where are you.? I'd swap you my dana 80 and 60 then I can run 37-38 tires.
Love it
Dual wheel inflation solutions? Crossfire?
Bend an extension to get a straight shot on valve stem. So glad I no longer have to deal with 6
Cant wait to see. I guessing sport hausing with dual mementos
Faulty Cruise Control
Stupid question what is running the throttle when cruise is on vacumn? Mines an 02
47re won't downshift to 1st gear
I doubt it will start in first I when selector is in 2nd. I agree regardless of parts age that pressure sensor and transducer are likely suspect, Regardless of codes thrown or not. Mine had similar issues I also thought it was temperature related. I also already had upgraded electronics on board. I did change to GM sensor and new transducer at the time sensor is gms 4l60e gov pressure sensor. Not entirely sure how much of an upgrade or any over the borg sensor. For some reason the GM sensor is listed for 2000up 47re not sure why. I was not expecting to notice anything but did notice quicker shifts after installing and 2nd gear starts went away truck never threw codes. I think transducer was likely the culprit but no sense in changing just one alone. Higher pressures are hard on parts exspecly when idle psi is at factory wot pressure 2000up https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F123656733827 Listed for 98-03 https://rover.ebay.com/rover/0/0/0?mpre=https%3A%2F%2Fwww.ebay.com%2Fulk%2Fitm%2F302114185385 I actually found this part instock at a local transmission warehouse in idaho. Directions with part even say 2000 up Good luck
Value of 98 3500 4x4 dually?
I'd value it at 2-3k
Brake switch
Yup cruise control and pretty much th brain of the truck. Took two to get right on mine while following directions. Installer error on my part.
47re for 2001 4wd
I've never found a 47 for 150. Think 400 is the lowest ive seen . I haven't looked in dynamics area bought 10hours from me.
BG 44 Gold Can
Looks interesting
4th gen steering shortfalls?
I got my truck at 150k . All ujoints shot except inside the dana 60 I've never done thise yet. Been thinking about doing them because I'll have to listen to one clatter limping one day. I have done front driveline a total of 3 times now to get to 350k truck isnt ran in 4wd very often but has had quite few adventures pulling the horses through slop I was unsure of. Rooster throwing on the turbo for miles hanging in the borrow ditch kinda adventures. With the please dont stop prayer rolling in my head. Rear drive line only ounce
