Evan
Quarterly Subscription
Everything posted by Evan
  1. Cruising Speedo is correct https://youtu.be/cNAiULZHLZI
  2. Cant wait to see those sweet wheels finished. I may have find a set
  3. I like that plan. I think I remember seeing some stuff on Ebay when I was researching my jeep. I decided that since Chrysler went ay from the vacumn actuator that I'd bust out the welder and do the same. Jeep light comes on and says part time 4wd. My truck 4x4 light comes on half th time. Not sure why though it doesn't matter
  4. The noncad trucks are basically in 4wd 100% of the time. Ont thing that happens to engage the front end is grab the tcase lever and shift it into gear to drive the already locked front end. The cad trucks are also but the combination of spider gears and unlocked axles shafts means that if tcase is engaged and actuator doesn't lock the pwer will go to path of last resistance through the spider gears wich happens to then be the unlocked inner axle shaft. Technically everything is working just the axle is soaking up the power from the transfercase in the spider that has no resistance. I to would like to have 2hi but not on vacumn switch that will fail. Vacumn and 4wd should never go together they've been failing ever since combined in 1859 I'd like to run my dana60 with Detroit locker and old school hubs. I'd have 2high with unlokced hubs and the ability to choose to lock both hubs or leave one unlocked if running on pavement. Cost is much to high to convert to hubs unless I come across a dana60 out of a 78-79 ford and build a axle for fun someday. Maybe with long arms since that's leaf sprung axle and will need stripped to go under a coil sprung dodge I better just leave as is alone since it works and jeep hacking on my jeep . posi lock sells a cable actuator for jeeps I'd assume they also do for the dana60 cad axles. It cost like 100bucks and also gives 2low
  5. If it were mine I'd install non cad axle shaft and plug vacumn lines. My jeep has the same cad setup. I welded the collar in place permanently locking it. I also have a noncad axle with lower gears thats some day going in it
  6. I think they went non cad in 01. I'd verify 4wd doesnt work before spending to much time. My first thought was also that inner axle was swapped for a non cad 1 peice axle. With the noncad axle it no longer needs actuator 4wd will be engaged when transfercase is engaged. Wether or not light on dash is lit. Hmmm mines an 02 ,non cad. Ah64 Is damn smart. So if the truck is noncad but has cad axle4wd wont work well or possibly at all since axle will be disconnected unless it has a inner axle for a noncad axle reinstalled in the cad axle. I'm sure I've made no sence
  7. Yes. Had this truck for 12-15 years. I grew to hate it as dually now I love it. I should have tossed a bed on it from day one She stil works just fine minus 2 tires.
  8. There are definitely times to not listen it surprisingly seems lights we agree on. I saw a 2nd gen in my town with projectors kinda wondering if were behind the times hidden in a dark corner. Maybe everyone has them and I'll start noticing them now. What are you doing with your other lights
  9. Injectors. Mine was like that till I changed injectors at 200ish . They were carboned over pretty bad
  10. Been awhile since I played with saws. The other day this 372xpw popped out of nowhere for cheap . These are lack luster saws xpw runs concrete saw cylinder dropped on a chain saw as factory big bore. It was a flop meant to run with the 75cc stihl 046. But actually was out done by the 70cc 372xp I tore it down raised transfers 2.5mm to advance timing and raise rpm. Also widend intake and exhaust. This should up rpm and overall power. From passed experience it does Did a few tree jobs might play more this coming spring in the tree's
  11. **** that's nothing till you pinball through a heard of wild horses . I absolutely love Idaho you never know what's around the next bend as your thinking about that a moose jumps out in front of you. Yes a moose
  12. What's not adjustable? My taxes are due back any day. I may just do this.. Been putting lots of miles on in the dark
  13. I have tall tires to 285x75x17 not quite 35s. I think I'd be hating life if I had 31s. Though guess I'd just drive slower. I think youl be 2200 or so at 80 with small tires with 3.54. Manual and auto spin about the same
  14. That's to far. I tried. I do very much like .3.54s I tow at 80 at 2000rpm when empty I run run 1800 and under. No sense in going slow for mog while loaded
  15. That's a s300 right? Wht was leaking after clcking.
  16. I have carbon fiber front pads and have little rotor wear after 50k. I'm running napa branded rotors. My rears are ceramic and also seeing little wear. I don't get n brakes hard.
  17. Did you pull accumulator spring. They break kinda often
  18. I'm running a 62 65 14 turbo with 100hp injectors with smarty on 3 timing at 3 and duration 3. Truck makes more power then I k ow what to do with. And runs cool towing some weight. I had 100hp injectors with the hy35 and had to peddle of egts had waste gate turnbuckled made about 28is maybe 30 sometimes. And had peddle off egts towing. Now with 62 65 14 turbo I go as fast as i want while towing never even really look at egt gauge anymore. I get 17-19 but tow allitle on st every tank. Idrecommend a 62 turb and 150s then add programmer later. If it spools slower than hy35 it's just barely I have not done head studs yet and make a about 38-40psi. I'll do 150 injectors at some point and studs
  19. 4.4 to 2" back 3" is what that picture looks like with red paint
  20. Where are you.? I'd swap you my dana 80 and 60 then I can run 37-38 tires.
  21. Bend an extension to get a straight shot on valve stem. So glad I no longer have to deal with 6
  22. Cant wait to see. I guessing sport hausing with dual mementos
