Evan
Quarterly Subscription
Everything posted by Evan
  1. I agree. Glad I went with 100s when my stockers were done
  2. Do your transmission first. A trans capable to 500 will drive so much better even under that
  3. Watching. My 2-3 shift is okay but never been as quick as I'd like.
  4. Lol. Yeah what I gather is bigger injectors plus quad could possibly run cooler than smaller injectors Seems like alot of work when 150s and 62 turbo are plug and play.
  5. Love it. Great work. You in McCall?
  6. Got mine. Now it's time to say the morning prayer and hit the big camb key.
  7. Lol no my apologies, feel free to edit my stuff. I didnt realize we where bouncing into different threads. Thought my reply was deleted, I was just in the wrong thread
  8. If your going to delete replies send a message say hey I deleted it didnt feel it was relevant. I may not agree but ill be fine with it. However I feel I asked good questions and brought up good points in that reply Knowing how the quad handles heat in heavy throttle towing situations with a small turbo.
  9. Yeah thts 3rd. I dont go to 4th till 55-60
  10. Injectors first. Guess I'll have to run up there with the backhoe. You will gross 31500. Kidding been a long time since I I towed that much behind a pickup. It's just hard to believe that 150s stock turbo that a quad can magically make it run cool. Ofcourse a empty truck has no concern. Fuel = heat theres enough fuel there with 150s and factory tune to see high egts while towing. Does quad pull fuel and timing to reduce this heat. Or certain throttle parameters
  11. Your more than 500rpm higher than me at 80
  12. I'd love to drive a quad truck with a proper tune with injectors and stock turbo with 15k behind it so I can gain the experience. If I dont peddle off I'll buy you a coke
  13. I'm 200k on 33-35" tires with no more problems then small tires
  14. Thanks Greg. I like decent sized tires
  15. Clean. Probably wont wash her till the next set of tires
  16. There's a fluid port inside the valve body that needs to be locked for the switch to be able to lock 2nd gear. Yours may or may not have the port blocked
  17. That's the toyo t the tire shop. Kinda thinking I should have gone with 295s These are feeling small. Just adjusted track bar to center trucking axle. I've been about 3/4" off. I'd say I'm within a 1/8" now
  18. You may see higher egt since the hx will demand slightly more fuel.
  19. Getting dirt commander's mounted 576 for 285/70/17 These are a toyo mt copy Sorry for all the pics. For some reason new rubber is always exciting. Well report as miles are put on these. Stepped down a size from 285-75-17 to 285-70-17 Truck is a 3500 with 2" lift spacers to get rid of the ugly 3500 rake. If anyone's curious
  20. Holy ****. This may be the most informative funny thread going on the forumn
  21. I've good luck with rubber gasket. I start all bolts on bench just through rubber gasket. Then raise pan to tranny then just start all bolts then snug all bolts in a cross pattern then snug again after all are snug.
  22. I live and work in ada county though I'm registered in Elmore county. I think I smke more than you but havent been pulled over. Getting 15k moving is when I put on a smoke show. Empty I'm just a good haze unless I stand on then roll some black wich isnt very often
