Evan
Quarterly Subscription
Everything posted by Evan
  1. Been running here 2500 miles a month. Feeling like something's going to happen. Had something rattling and never found it then it stopped on own. I think the rear end. I allowed pinion nut to come loose it growled I thought transmission. Took it to my tranny builder I was going to yank it h ed insisted it wasn't a tranny noise. Do finally I found the pinion nut on the dana 80 was loos allowing the pinion gear to walk in and out of the ring gear eating itself. I'm going to run it till it goes then unfortunately caught up the money to buy a ring and pinion 3.55 gear set and rebuild it. In the mean time I'm driving the jetta around town. I work 40-120 miles from where I live. The jetta just isnt the work rig I need. Also been debating a newer truck. I keep thinking my 02 is getting tired. But maybe shel go another 4 years who knows. Here she is parked for the night. That's a friends 12 valve its next to. They used to be 1ton twins.
  2. Lol yeah. I kinda close my ears whenever I hear or see built 47re. Most people that seem to say it have no clue what's in it
  3. 350 horse with a triple can break input shaft under normal driving conditions. Ohh you said intermediate. ?
  4. Grid heater connections below drivers batter might be loose
  5. I wonder if I could do input shaft myself. My single isn't slipping but still I've had thoughts of upgrading to a triple.
  6. Ohhh nice super easy to swap then with no special tools
  7. He wouldnt have to do locked shifts
  8. I unbolted control arm to do coil springs no compressor needed.
  9. Could it be a synchro. If its grinding it's still there?
  10. Lol. I have a hard time fixing something that ain't broke. If something is broke I can fix it if it's not broke it's a 50/50 chance that it becomes broke ounce I'm done fixing it. This time I just saved labor
  11. Stock I also put red lock tite on them after cleaning bolts and threads with cleaner. Wait I think arp had a spec for them I used. Either way I dont think itl matter as long they're tight I did not replace my rear main seal. Now its leaking
  12. Ok Mike haha I'll try the string method. See what happens. My my truck is about 1.5" taller in the rear with the 2" leveling kit installed. Rides like a caddy with 2k centers behind the cab the goosekneck just barely makes it touch the overload. I put just enough weight on the truck but leave most of it on the trailer axles. The bumper pull does push the rear just under level. I'm actually with welder on board at about stock height. It sags front and rear about 1" I measured. Was surprised it put the front down the same as the rear.
  13. Did you just ask if you should get a stock style or billett. I should slap you. Billet billet and more billet. May as well do a billet flexplate from georend to. I did. I also did arp flexplate bolts just for some insurance.
  14. Got bored this weekend. Jeep tires needed coverd.. still not finished have rear to do and finish front
  15. 25000 miles
  16. Sounds like you've got it under control
  17. Sometimes it wont start. Over the 15 years of owning my 02 longer start times have always been battery, starter or battery cable issues. Never had pump issues the only time it would not start it was one dead battery or start contacts. The only other times were in cold temps fighting battery cable issues. Ohhh injection pump ounce caused no start.
  18. Why the hell at -15 air temp would it matter where the fuel lines are running. You have no heat source till trucks running. Leaving it running all night? Sometimes you guys crack me the **** up
  19. Our other trailer. We run this trail at its rated capacity 25k. It's not able to withstand daily use at this capacity. Ive rebuild all suspensions spring hangers and the tongue. The backhoe beat through them. Its on the cheaper end but I do not believe the ones costing more are any better . They do have gussets tongues, pj's are nicer better welds alittle more pride goes into them. But you get to the working end at the axles and they're all the same cookie cutter mounts. Most people wont run a trailer like this at capacity very much. My thoughts for the morning.
  20. I thought those were womens legs in red leggings
  21. Got rid of the 02 tdi it was cool just needed so much work. Few years go buy and this one pops up for cheap 2.0gas. Had steering issues, over heating, fans weren't coming on. Was the relay under the dash. Still blowing coolant with fans running. Hmmmm Yanked the head off resurfaced and back together. Seems solid have a few miles on it. I kinda like these vw's. I'd like to try another tdi
  22. Transfer case in neutral?
  23. Yes still running 9 3 3 3. My best tune yet Lol yes. Normally I dont get on but have been noticing less smoke since I have. Were doing a tree job tomorrow christine and I. Seems I'm doing all the work getting saws ready and shes already sleeping. Haven't done a tree job in awhile, she needs the money. And I'm usually working anyways. So well do it Thought about laying the tree on the goosekneck but think it's to big. Well just put it in the dump truck and use the backhoe. That's off topick. I did see 1100 on some small grades pulling basically the empty trailer at 80 just under 2000 rpm running 900s on the flats. Boost never going over 20
