Everything posted by Evan
3500 rear axle into 2500
I like the toyo mt. I ran set of tall narrow ones when my truck was a dually. Did well towing the horse trailer in harsh offroad conditions and handled the street good to. I to had them aired down to about 50 in the rear and 60 in the front. Or something like that. Wheres the pictures. I like the 305x70 size it's just big enough
Let's talk about shocks.
My 5100s feel like they arent doing much seem to be getting softer every day. Been looking into fox shocks 2.0s I need want more control. Between the 5100s on the front and kyb on rear my truck is all over the place. Just not enough control with a almost 10,000lb truck giving them hell. Also thinking about dual shocks on the front get another pair of cheap shocks. Or fox 2.0s performance series are bolt on
Smarty s03 today :)
Running sw5 5 4 2 still Just got on the freeway mashed it in 4th at over 1500 truck pulling hard sucking me in the seat turbo screaming probly very little smoke psssssssddddd I hear over the turbo like a aerosol can emptying instantly but not exploding. Chopped the throttle dove off the shoulder thinking head gasket no coolant though hoses still intact all fluids good. Cruised 40 miles after like nothing happened at 70mp making 5ish psi like normal. Haven't gone over half throttle since. It's got me rattled Umm I feel like a gomer hmm I found what it was can you? How I drove 40miles with it staring at me is beyond me.
Vacation fun
Doesnt matter what I'm talking about.
Truck died while driving
Everyone thinks I'm crazy but the grid heater cables came loose on me. The ones below drivers battery. Truck would die driving down rd Check them,Only takes a minute.
98.5 fluids..
Nice Notice it does say manual trans specific that's weird. Is it red? I think I saw that truck with camper in Boise
Cummins big cam 365 and Cummins C brake.
Yesterday she over heated enough it couldn't recover and I shut it down with a load on it. That's worsted case scenario at times it's the bread earner. And has been for the last few days. I found myself researching low flow coolant systems last night. Wtf . May be a tstat issue but likely is the low flow radiator with 1.2million miles on it.. I try to free fridays for repairs and maintenance that almost never works out lol though I guess today it will. Hopefully back moving material later today or tomorrow have been in contact with Mac's in boise they seem knowledgeable on the low flow coolant systems I better go get at it. Check tstats out and go from there Good to have cummins here. Truck had two bypass tstats.
Truck died second version
To those helping here your amazing. As I read this it reads as its FUBARED, my mind says, but your collective minds may get it going . Pretty good group of guys here
You might be able to make a trade with someone for a dana 70. Post an add on craigslist
Did some looking today. With ignition on brake switch on it has 12v on all 3 solenoids. With truck running front solenoid has 13v plus middle and rear have 1.9 . Possibly I'm wired wrong grounding out through ignition switch.
2001 Battery Cable Length
Lengths are listed http://www.fostertruck.com/dodge/dodge-battery-cables.html
SAC Injectors
I really like talking to the power driven diesel guy. Talked his ear off about the 47re before and after mine was done and not buy them. I joked that when it's time for tranny # 2 I might drive there yank mine for the core and install his in the pking lot or motel pking lot
I haven't changed anything but the switch. To me it sounds like week solenoids or possibly I dont have enough voltage going to them. I really have no clue. Thank for lash tip. Didnt know there was such a thing or that its adjustable I've personally put about 200k on the truck. Motor was inframed at 837000k trucks at 1.2mill now. Never messed with anything but wiring. All wireing is falling apart I noticed a few relays marked retard 1 2 and 3. Might be worth changing them just for shits.
Maybe this is the best place to post this?Theres a cummins big engine guru here that i cant remember his name. I'm trying to get more breaking from the big cummins. I'm dropping solenoids or butterflies at 1800-1500 rpm. I've rewired so all solenoids come on all the time the 3 way switch is gone but still losing engine braking at high rpm. 365 has no trouble idling with switch on sounds like only one solenoid is on. At and idle I flip the switch motor just about dies then powers through and idle at about 700rpm chugging right through the brake. I'm not entirely sure how the system even works. Thank for any help.
Smarty s03 today :)
I have not checked coolant temp or iat. I have been flushing my coolant system for a week or so off and on. Was running on upper side of 190 now running on lower side of 190. Do I plug it into a scanner to read iat readings? I thought I noticed it run differently after flushing but thought it was just me. Temp gauge barely changed Trying to have a working heater by winter. I'm on sw5 5 4 2 smokes less, aggressive hit of power at 1800-2000 I got on it ounce. Assuming timming locked.
SAC Injectors
I'm running 7x09 sac from ducky fuel injection. Only thing I've noticed is truck is harder starting in cold temps. Like -10 it cranks quite a bit belching black smoke then finally starts firing on 1 cylinder then slowly pick up the rest one at time. This also not running a block heater. They might be more smokey than vco injectors. Go with ducky fuel injection again not sure if I'll stay sac or go vco again I'll
Diff switch from 3.55 to 4.10
Not sure what to think anymore. 32.75 works for my tape measure and me
By .5" lol Heres a set of tires I have that say 35x12.5x17 on the sidewall same height as my 285x75x17 but look much bigger because they're wider. The 33x12.5x15s i have on my jeep are noticably shorter than my other tires
https://www.deantires.com/tires/back-country-mt/specs Heres the specs look it up yourself.
285x75x17 Just gps verified. Speedo set at 80mph cruise control on GPS reads 79.5 For me the tape measure works great from alignment to setting tire size. It would be way off to plug in 35" off alittle to plug in what manufacturer says it is. I'd screen shot it but it was a app on my phone no way to get speed and app reading at the same time. I'm sure the wrong one that I didnt calibrate or something and it was reading 5-10 mph off. Lol. Close enough for me. I wonder if cruising done the rd the tires heat up and gain alittle pressure and height
We got another jetta
This tank of fuel cost more than the jetta. 2.85 maverick on cloverdalea Got water pump in. Found pump had already been replaced. I replaced it anyways along with timming belt that faught me. Kept being 1 tooth off.
Yes so you run listed tire size not actual rubber measured in front off you. Being passed I'm off 1ish wich I figured to be the .25-.5" variance between tires. I bet dropping to 32.5" squashes my 1mph being passed. Man why am I even putting the effort in thinking about this
I highly doubt I'm off 5. Though I may be off .25-.5" measuring tires. Manufacture will list specs for they're tires. I think mine list at 33.2. Either way it's close enough. Everyone passes me when I run 1800-1900 rpm. I dont think the tacks off
I go off actual measured tire size not sidewall. It's about 1mph off my 2012 caravan that has stock tires. I could care less what resell is not sure odometer is working correctly anyways. I haven't verified speed with GPS but it seems close enough for me. I'd assume all those that plug sidewall size into the smarty are off. In my case that would be off by 2.25" of rubber
