Marcus2000monster
  1. @Tractorman Would you be interested in making an article on your BHAF muffler?
  2. But wouldn’t those compression ratios cuase a difference in sound or am I dreaming?
  3. Do you have a kit? Luke that I could buy from you? I’m thinking the big difference is HO vs SO. I definitely like the HO sound better.
  4. Wow that seems much better. I’m not sure why but my map lights just literally don’t seem to be they’re. The lens is theyre but it just rattled around in the housing. Apparently it’s a cover up of some kind.
  5. Awesome! Get me one when the tests are done!
  6. @IBMobile I’m interested in your grid heater switch. How is this coming?
  7. I can definitely be something in the brakes.
  8. Let us know how that goes Mike. That could save us all a shot alternator not to mention it would reduce AC noise correct?
  9. I was planning to buy the ATMs but i found a used set of Wranglers almost new for 300$. I will likely get the Hankook tires next time. We get a lot of vehicles at the shop wiith the Dynapros and most of them are wearing real crappy but i think its mostly neglect to rotate and keep the rest of the front end in shipshape. Im currently shopping for some 3;55 axles and im going to downsize to 245s likely. Its obviously the way to go. I also think i could see mpg gains with the 3;55s.Between MPGs and the extended life of front end parts etc i think i can pay off some used axles quickly. i found a axle locally for 500$ that im calling on this morning. Hopefully i can grab it for like 450.
  10. That’s interesting. Well it is doing it’s job! Although I didn’t mean the word I used in a negative way lol.
  11. Actually it looks almost identical to a Ford 300 In-line 6.
  12. It’s a good thing Mike. It keeps the site clean. Not that theyre is many here that would clutter it up with that stuff though.
  13. I’m gonna keeprunningmmybbatterys and see what happens as it gets even colder and than I’m going to ****** up those Everstarts from Walmart. Holy cow the filter on the site is sensitive! I’m going to pick up those Everstarts....
  14. Dang that’s sad. It’s obviously not a 24 valve and Iv never had a valve cover off anything else. Obviously it’s a 12 valve.
  15. Hey guys here is the video of the 2001 at the shop. I had just installed a fresh thermostat. I just noticed that the oil pressure gauge goes up to normal with key on engine off.
  16. I’m considering messing with my injector pop off pressures. Iv heard of people having good results with 320 bar with the 75HP sticks. Basically I want the optimal pop pressure for my truck that is not running any tuning just the larger injectors. Part of the reason I’m pulling them is to make sure I have them installed correctly and all washers, o rings, etc are properly installed. Anyways what’s the verdict on pop pressures?
  17. I have the Milwaukee drill/ driver combo that i love.
  18. Umm im not 21 but we can run to the gas station i got a wallet! seriously i might come over sometime though. @Mopar1973Man Is there some good camping around theyre? Might try to combine a camping/hunting trip.
  19. The ground kid is on the list for my truck. I want to take A drive to New Meadows next spring and maybe have you do it!
  20. Here at our shop just before I started a employee was nearly severely injured and could have been killed by a tire he was mounting with a tire machine. I have friends in Pennsylvania that have had tractor tires blown in they’re faces. One case killed a 12 year old boy. Just proof that they can be deadly if not treated carefully. I’m currently shopping around for new 3:55 axles for my truck. I’m thinking I’ll go with 245/75/17 tires and I’m curious if this is a good ratio? Final ratio would be 3:68.
  21. Earthquake XT all the way! Just had a mechanic stop in with one. Sweet gun for sure.
