Everything posted by IBMobile
Towing and tire chains
You said Save your money and use it for a warm motel if you need to. it's better that staying in a cold truck stop
How long would it take to drive in 'good' weather and could you hold off the move for a day or two until a good weather window opened that way you don't have to fool with chains.
Winter is coming
If it ever got that cold here they would just pass another tax
Fuel Pressure too high or too low?
I'm using the 'bypass valve', which really should be called a fuel pressure regulator, that came with the kit. I've had to take it apart and clean it when the pressure dropped due to a small peace of rubber becaming stuck and held the valve open. That was right after I installed it and it's be trouble free since. I am running it with the electric pump disconnected.
Random ABS light and weird braking performance
Nice code reader at a nice price. My Launch says it will do ABS/SRS and it works fine on Volvos but it won't work on my truck.
With my Fuel Boss mechanical lift pump system I see 15-16 psi @ idle on startup and go up to 20psi by 1500 rpm. After driving for 5-10 minutes fuel pressure will be 16-17 psi @ idle and still 20psi going down the road. I'd leave the pressure on the low side. My truck sees 15psi for 30-60 seconds, no big deal. Did you put in an electric "prime pump" and if so what type?
Winter is coming
I've lived in RI, MASS, and NH, when the company I worked for wanted me to go to Bangor, Maine it was adios. I had enough of the New England winters. Since I've moved to the San Diego area 41 years ago, I've shoveled snow in my driveway ZERO times.
Winter is coming
It's 4:30 and 73° with tomorrow forecast to be 80° with no chance of snow.
Heater Core replacement
My heater core was replaced in June of 2013. I used the swivel type, that's the only type my supplier had at the time. It went in fine and there's been no problems.
Just put in a new dash with that new heater core and evap and save some time. http://www.lmctruck.com/features/de/DEDP1.htm?utm_campaign=20150209_DE_Customers_1998_2002&utm_source=et&utm_medium=email&utm_content=Main_Dodge_Dash_Image
Best scan reader
If you just want to read codes you can buy a cheap code reader for about $50 and up. Their are so many out there with some giving just codes, while others give codes and live data, and others will graph the data. I have two code readers a Launch 129 and a Matco Tool MD1032. I use the Matco reader more even though it is less capable. It gives me the info I need. You should buy what you really need. If you just what to read codes get an inexpensive one but if you want live data and other options then the sky's the limit. Don't forget to read the product reviews and watch out for Chines junk knock offs.
Time to kill some rust!
It looks interesting. They have everything for a DIY guy. I like that its tint able with colors like " jungle love" "don't yell at me", and "blood bath". I wish I'd known about the Chassis Saver™ when I was redoing my boat trailer. I did some looking around and this stuff is real popular with the off road and down in the mud 4x4 sites. I didn't see one bad thing about it. Keep us up to date on this project.
Total Meltdown
Some JBweld ® Kwik™ mixed will seal it in a pinch.
How about a spray in liner like Line-X® http://www.linex.com/ or Rhino Linings® http://www.rhinolinings.com/
Fixing oxidized headlights for cheap...
I cleaned mine with Meguiar's® Plastx™ clear plastic cleaner and polish last April. I used a drill with a foam pad to clean and polish but did not spray them with any sealer. A customer had his done professionally and sprayed with lacquer. 6mo later they were yellow and the lacquer made it worse.
Happy Thanksgiving
Had our Thanksgiving meal today already. Now we can go out tomorrow and serve those less fortunate.
Thoughts on Edge EZ vs Superchips Flashpaq vs Other Econo Tuners
Had my trans rebuilt at 63K. Front band went out and all the junk,( band and clutch material) , took out the torque converter. I did a lot of backing up with my 5er and didn't have a trans temp gauge so I cooked the fluid and destroyed the transmission. I haven't had a problem since.
It hasn't been a priority with me. Living in So Cal it hardly ever rains, been in a drought the last 4 years. The last time the truck was driven in the rain was the second week of last May when I was in Wyoming. If I was to fashion something it would probably be a sturdy hard plastic container (Tupperwear®) with a removable top and cut a slit in the side for the wires to pass through. I would then seal the slit with clear silicone RTV and mount it on top of the relay box with Velcro®.
Broken Flex plate?
Put a little paint/marker pen on the shiny spots of the bolt heads, let dry, then run the engine through its steps. If the paint comes off you know you've got movement in there.
Rough Start This Morning
Bad starter motor contacts can cause a hard start problem also but with it starting and running badly for 10 seconds then smoothing out sounds like it's loosing prime, Air leak in fuel system.
Grinding sound when driving straight or turning left
I have to agree with Ironforger about NAPA. 20 years ago their parts were O'k but now they're way proud of their stuff and charge accordingly. The only thing I get from them are hose clamps, nuts and bolts, and axle shafts for the Volvos. As for A-1 cardone, I don't think I've ever used their parts.
I'll second that. Makes noise going straight or on left turn - you've got a bad right wheel bearing. When turning your unloading the wheel your turning into and loading the opposite wheel, That's why you hear the grinding in the right wheel on a left turn. It's getting pretty bad if you can hear it going straight.
lift pump help
My truck sits unused for weeks at a time. When I start it with the electric "jockey" pump unplugged, it builds operational fuel pressure within 1 second. The reason I run with the electric pump disconnected, the Airtex pump was putting out 16-17 psi and the Fuel Boss at idle will put out any where from 15-18 psi. The two different but almost the same fuel pressures made setting the Hobbs switch (pressure switch) a pain and the electric pump kept cycling on and off very quickly. I read somewhere that people where running the Fuel Boss with the electric pump disconnected or with out an electric pump in the system at all so: I tried it, I like it, and that's all there is to it.
lift pump help
It comes with all the hose and hardware you'll need and installs in 2-3 hours depending on if you put in a back up lift pump for priming and starting or not. I have an Airtex fuel pump in line but have it unplugged when I found that I don't need it for start ups. This link will give you the install instructions for the Fuel Boss. http://www.glacierdieselpower.com/images/PDFs/98.5-02-Fuel-Boss-Install-Manual.pdfoss
lift pump help
Get a FUEL BOSS. No wires, no fuse, no relay, just FUEL PRESSURE. .
