Everything posted by IBMobile
Pump gone bad?
P0230 is the ECM not seeing the lift pump power draw at terminals 15 and 35, not a problem. P0254, P0370, and P1690 are all codes for a VP44 injection pump failing.
Air Vent?
Did you mean 64 KB and not MB. I edit mine down, on a laptop, to around 150 KB before posting.
Overhead
This should help you. https://www.youtube.com/results?search_query=2000+dodge+ram+overhead+console+removal The release tabs on mine broke so I used two small Sheetmetal screws to secure it. The switch and plugs for the video screen of the rear view out of my 5th wheel is located in the overhead.
Both Trucks showing up with slow to non working wipers...
- Both Trucks showing up with slow to non working wipers...
Yes, the wiper parking switch is in the motor. With the hood up and under the black plastic cowl.- Olympics
Put a jump in that course and now it's in the X-Games. Olympics...NOT ONE MIUTE!- Low Boost After Boost Elbow Install
It would go down into the oil pan. It might get sucked up to the oil screen on the oil pump pickup.- Low Boost After Boost Elbow Install
Had the same thing happen to me when replacing Turbos on Volvos. Sometimes the hole would be round and other times rectangle. So long as the bolt holes line up, and the center hole is large enough for good oil flow use what you bought.- Olympics
- Winter weather - What do you see where your at?
It's 65°F right now (9 AM) sunny and still no snow.- Surging while driving
DITTO- Missing People in Idaho
Here are a few videos about HX35 rebuild. https://www.youtube.com/results?search_query=hx35+rebuild- Low Boost After Boost Elbow Install
With all that "coke" deposit at the waste gate opening, don't know how good of a seal it had.- Dreaded P0216 code, help/advice
When the factory lift pump died, I took it apart to see what was in it. Pump head with filter screen- Low Boost After Boost Elbow Install
What do you have to lose? Clean the area with brake clean and a toothbrush before applying. I have used JB weld on an intake manifold that was leaking coolant. It fixed the problem.- Winter weather - What do you see where your at?
Clear, 72°F, with 4.1magnitude earthquake 20 miles from the house.- Winter weather - What do you see where your at?
Just having my breakfast in shorts and short sleeve shirt with the patio door open, sunny and 71°F. Still no snow.- 99 Ram 1500 no blinkers
Yes. The power flows from fuse #4 to the flasher timer/relay, to the hazard portion of the CS (combined switch). The power then flows around the left/right turn part in the CS to power the 4 turn signal blub wires. When using the left/right switch if no power is flowing to those wires, then the CS is bad.- Fuel in Oil, not sure what to do!
You'll find engine oil leaks.- FNG
I've run 4 and 6cyl pushrod engines with the valve cover off and used shop towels over them to keep the oil from spraying everywhere. You can use old rages to do the same thing, lifting one at a time for inspection. Another thing you might want to do is remove the fanbelt, so you're not worried about getting caught in it or the fan and there is no wind being generated to disrupt the rags that are laid down. A short engine run with it off will not hurt anything.- Another hard start/loss of prime
Same problem Volvo diesel cars had in the early '80s', air leak at the fuel filter banjo fitting for the fuel line to the injection pump. We'd replace the copper washers and no more hard start problem.- Another hard start/loss of prime
That sure can do it. Plug the drain hose off first and see what happens. It may be a cheap easy fix.- Anyone with an RV near N.W. Ohio?
Is this the Scottish 500? North Coast 500 | VisitScotland https://www.visitscotland.com/see-do/tours/driving-road-trips/north-coast-500/ - Both Trucks showing up with slow to non working wipers...
