Everything posted by IBMobile
Got a 5th wheel to move tomorrow
Glad to hear the move went well. Easy money.
2nd Gen Articles
I did a lot of Dana 30, 1030, and 1031 differentials in Volvos. If you are just replacing the bearings or spider gears, it's not hard but replacing the ring and pion can be a real PITA. Mike needs to hire a gaffer.
Quad Turbo Timer
Gas "Motor" oil has about the same flash point as diesel motor oil. Information from safety data sheets. Refiner Oil Type Flash point Shell Rotella T6 5w-40 435° F Chevron Delo SDE 15w-40 399° F Chevron Delo XLE 15w-40 399° F Valvoline Synthetic Diesel 5w-40 >390°F Valvoline Motor oil 10w-30 >390°F Valvoline Synthetic motor oil 10w-30 >390°F
Be sure those trailer tyers aren't rotten.
Oil leak after vp44 replacement
Different gaskets. FEL-PRO 12V timing cover gasket part #TCS46001 FEL-PRO 24V timing cover gasket part # TCS45994 Permatex Ultra Black will also work. "Permatex Ultra Black retains high flexibility and oil resistant properties through use of a patented adhesion system. Ultra Black is sensor safe, low odor, and non-corrosive with resistance to oil, shop fluids, and vibration. This sensor-safe, low odor, non-corrosive formula meets performance specifications of OE silicone gaskets and can be used on high flexibility and high oil resistant applications such as timing covers, transmission pans and oil pans." " Permatex Ultra Grey Rigid High-Torque RTV Silicone Gasket Maker is designed specially for high-torque and high vibration applications, like those common in import engines. Grey RTV has higher density when cured for higher vibration resistance and tight tolerance applications."
I live off Nordahl Rd, near the Costco. If you want me to give you a hand with that PM me.
Did you check the tappet cover?
16" Wheels suggestions?
I installed truck Pac Brake on my truck. I now have greater speed control and confidence when towing. One of the best things I've added to the truck.
Thor - New Project Truck
If the other lines are good, you can get an OEM #4 injection line, part #5289447, for about $80 plus shipping. Here are just two sites of many that I found. https://s1partscenter.com/brands/cummins/other/5289447?gclid=CjwKCAjwh-CVBhB8EiwAjFEPGabB-qwrPVEfg4s2gW8DqTB7PYGiQJfcnEgYwU4wI3d1DzqvuCJ5nhoC-cQQAvD_BwE https://shop.cummins.com/CSSNAStore/s/product/a2w4N000003sEiDQAU/cummins-injector-fuel-supply-tube-5289447?ppc_keyword=&gclid=CjwKCAjwh-CVBhB8EiwAjFEPGVRQsPata6N0QYh5OAuLlubg8rgPi1WVebPNBejMELgXqMCUj9GzsBoCwsMQAvD_BwE
Stock Fuel Filter
https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/air-exhaust_56/big-honking-air-filter-r566/ NAPA filters are Wix filters reboxed.
2nd VP in 2 Weeks
Hot wire the pump to see if the engine will start that way. this will eliminate there being another bad pump, then test wires and components for voltage, continuity, and grounds. https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/59_fuel/hotwire-test-vp44-r615/?tab=comments#comment-87
Turbo/Injector balance for towing/EGT control
My truck is used 98% of the time towing my 8000lb 5th wheel with my boat sometimes behind it. I've logged over 55 k miles in about 10 years with that size Michelin - LTX A/T2 tire. The first set rotted off. I tow 60-62 mph and tack 1800-2000 rpm in overdrive. When going up hills I'll leave it in O/D unless the exhaust temp goes above 1200°F or the transmission downshifts, then I lock out O/D set the cruise control for 55 mph and enjoy the ride.
It had to happen
Where people are intelligent and not constipated. Here in SoCal there seems to be a dumb a$$ butthead around every corner in a hurry to get some where. They think there time has more value than my time. That's what happened in my case, The truck driver was in a hurry and tried to squeeze by instead of stopping and checking or waiting for me to move my truck. Now I'm spending time dealing with an insurance compony that doesn't give a rip about me and then taking it to the body shop for repair, which is a 45min trip one way.
01 24v dead in the water....
I suggest doing a VP hot wire test to verify if the VP44 is dead or not. If VP starts then VP is good, if no start then VP is dead. Below is the link on how to do it. https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/59_fuel/hotwire-test-vp44-r615/?tab=comments#comment-87
Testing to the battery ground is best but any clean grounding point will do to start with.
It had to happen
And pay out $ as little as they can. "You're in good hands" and "We're on your side"...not.
Ohm test the following wires from ECM to fuel injection pump (FIP): ECM pin 23 to FIP pin 1--- 0 ohms ECM pin 13 to FIP pin 2---0 ohms ECM pin 30 to FIP pin 6---0 ohms ECM pin 30 to ground---0 ohms If open circuit is detected repair wires or clean ground. Do you have a stock lift pump or an aftermarket pump with a relay? If stock pump, is it in the tank or on the left side of the block? the grounding point, G107, for the lift pump is on the left side of the block next to the starter motor.
It had to happen
NO. This event occurred May 25 and the claim was submitted the same day with the truck owner's insurance company, Mercury. I was told an adjuster would call me the next day, crickets. I called the Mercury contact person on June 15 and was told she has been trying to contact the owner of the truck, for 3 weeks, BS. I told her that after June 22 I'll be filling a claim with my issuance compony for damages from an uninsured motorist and let them handle it.
New member from Canada
Welcome. Nice looking truck. I like the color combo of gold over black. Let us know what your questions are.
It had to happen
I Had an 4' high by 88' long block wall built with all the materials delivered on 12 pallets. The block and brick company charges a deposit of $31/pallet. I bring back 6 pallets at a time and after returning the last 6 I drive up to the office for the refund. My wife says, "park it here in front of the sales office". OK. My wife and I go into the office, get the refund, turn to leave and are greeted with "is that your truck out there"? "Why yes, it is" I replied. He then requests if I could move it because his trailer is "Real close " to my truck. " No problem" I tell him, and we go outside to see what needs to be done. I see that his trailer is almost inside my truck and the trailer's spare had rubbed on the right door. I moved my truck over a couple of feet and that's when I saw the damage to the right front fender. This guy wasn't going to tell me that he had damaged the truck. I think he hoped I would have just moved the truck and not looked for damage, wrong. When I saw the damage, I said "license, registration, proof of insurance" and he gave it all to me. All right. I then pointed to my trucks wind shield and said "Do you see that camera in the windshield? It's video recording everything that going on". With that revelation he finally said " Ya, I did it". I uploaded a 3-part video on YouTube from the dash cam. In the first video the action starts at 1min 44 sec into it. The second video the action stops after 50 sec. The third video has action all the way through it.
Looming Economic Crash
And yet some people see the evil at play and turn a blind eye towards it...it fits their agenda.
That much wood in the back of my truck and it's on the helper springs. Nice log splitter there.
New Guy
@DrJekyll86welcome. This is the place to be to help keep your truck running trouble free. You might want to do these wire mods in conjunction with the W-T mod. https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/electrical/pcm-ground-splice-repair-r675/?tab=comments#comment-115 https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/electrical/alternator-and-pcm-protection-r617/
Right you are. My pic is to illustrate what 245/75 R16 tires look like on a stock suspension 2WD truck. @Mopar1973Man picture shows what 245/75R 16 tires look like on a stock suspension 4WD truck.
