Everything posted by IBMobile
Hydrogen Fuel Cell...
This is a good quick read about the subject. https://www.popularmechanics.com/cars/a3428/4271579/
Knowing your load capacity and how to load your RV
A YouTube video about this. (293) RAM 3500 Frame Cracked In Half By Camper Fail: This Is What Happens When You Assume... - YouTube https://www.youtube.com/watch?v=JHD_R8NUCa8
Good Source for Re-manufactured 47RE Automatic Transmission
Dynamic Transmisson was my choice when my trans needed rebuilding. I shipped it from San Diego to his shop.
Good source for a new dipstick
Here are three but there are more; Google 2001 Dodge Ram 2500 turbo diesel dipstick. https://www.thoroughbreddiesel.com/3937748/?gclid=CjwKCAiA-8SdBhBGEiwAWdgtcEV-gOnjYLV28iJN4k5IsL3fpi-HggXHwLtmy27GwMOXXQUJtUHI9xoCuxAQAvD_BwE https://www.ebay.com/itm/265237412749?chn=ps&_trkparms=ispr%3D1&amdata=enc%3A1FtIoryZKRn-Hn5T-_JaRqQ82&norover=1&mkevt=1&mkrid=711-117182-37290-0&mkcid=2&mkscid=101&itemid=265237412749&targetid=1644837434523&device=c&mktype=&googleloc=9031295&poi=&campaignid=16743749222&mkgroupid=138744546207&rlsatarget=pla-1644837434523&abcId=9300842&merchantid=138378214&gclid=CjwKCAiA-8SdBhBGEiwAWdgtcDAuVpch1R6jsIQlflRXGEzrfcPOyCNTeqV3fuMERdfOoizp-N5lLhoCNJsQAvD_BwE https://www.xtremediesel.com/cummins-3959009-engine-oil-dipstick-flat-blade-style?gclid=CjwKCAiA-8SdBhBGEiwAWdgtcKhPe6jsYGfon4lWXExcveOLq1h_JKjNsJ2qDq2nowflxqYECI69txoCIokQAvD_BwE
Happy New Year 2023
May the New Year bring you happiness, peace, and prosperity. Wishing you a joyous 2023!
W-T Mod Early 1998.5 Need Assistance
leave that ground attached to the head. You may want to clean the connection there. Reattach all the connections to the back of the alternator, one cable is for the ground and the other cable is the B+ charge which will be routed to the positive terminal on the right (passenger) side battery. The other two wires are for voltage control from the PCM. The blue wire is where you can install a (5-7.5 amp) fuse for PCM protection. It's not that much work to open that wire harness to expose everything. If you disconnect the alternator charge wire at the PDC you will then have its full length to work with when routing it to the right-side battery via a fuse or circuit breaker. When you open the wire harness up you will see where the ground wires are all joined this where you want to make your cut so that you have enough wire to work with and have a clean looking job.
Wood Heat
If I had a load of mesquite I'd be barbecuing a pig.
Truck Not Running Right
Another thing with high electrical loads is the fuse you add, to protect the PCM, in the blue wire from the alternator. I tried a 5-amp fuse, but it popped when the grid heaters and E-brake air compressor were on together. I put a 7.5-amp fuse in and no more trouble.
Huge puddle question
No, I wouldn't worry about those things at all.
Check that the vent hoses on the axles are there and no water infiltrated the axle housings and contaminated the oil.
It's always something
Google push pin rivet. I picked up a spare in the pick apart yard.
Antifreeze
A simple answer is yes, a 50/50 mix will work for your location in Texas. As the concentrate of antifreeze is increased the boiling point is increased but the drawback to that is at higher concentrations the ability of the coolant mixture to absorb and release heat is reduced. I experienced this in 1986 when a customer's car was running hot/overheating all the time. After talking to him he said that he had "flushed "the cooling system and fill it with 100% antifreeze. After draining and refilling the cooling system with a 50/50 mixture of antifreeze the overheating problem was fixed. The other import part of the cooling system to increase the temperature at which the engine coolant will boil is the system pressure cap. The higher the pressure the higher the boiling point. For every PSI increase in pressure the boiling point is raised ~2.5°F (1.39°C). There for an OEM radiator pressure cap rated at 16 PSI will raise the boiling point to 252°F (122.24°C). Do not go above the vehicle manufactures recommended pressure or failure of other cooling system components will occur.
Antifreeze
No cold start problem.....help
This is part of the sacrifice they must be willing to make to the environmental Goddess Gaia, the preventer of global warming.
Last minute prep for first measurable snowfall
It sounds like the solenoid/Bendix in the starter motor sticks when very cold.
Some of us are of the mindset that you need the fuse, and some say you don't need one. You can do the full mod and install the fuss or circuit breaker later; just leave the cable from the B+ alternator terminal to the right-side battery positive post a bit longer to have something to work with.
Make a wind block out of cardboard, plywood, table turned on its side, and a tarp.
Antifreeze
Merry Christmas
May all that is beautiful, meaningful and brings you joy be yours this holiday season and throughout the coming year!
Why yes, there are plenty of snowflakes, but they all melt when they hit the ground and they don't amount to anything.
Getting on site
I use Wi-Fi for my phone and the laptop with no problem getting on this site. Somebody savvier than me will chime in. Help Mr. Wizard.
Insulating Heater Hoses?
I wouldn't do it. It is a lot of effort with minimal outcome for your environment. The time would better be spent polishing the rims.
New VP44 No Start! Codes P0382 , P1689
You can control the FASS fuel pump, if it has a relay, from under the hood and bypass using the key by using a jumper wire. Attach the jumper wire to terminal 30 of the FASS fuel pump relay then the positive post of the battery to energize the fuel pump. This will turn the fuel pump on for as long as you want.
