Everything posted by IBMobile
I know this is sudden but...
May good health envelop you, spurring a quick recovery.
truck failed it's MOT test today
Same thing happened to me. Brakes got smoking hot coming down a grade between Banff to Jasper Canada. About 6k miles later I was changing the right wheel hub when visiting @Mopar1973Man.
2nd Gen Cummins heater temp differences between trucks
No idea, it's not shown in the FSN section 8W-42 AIR CONDITIONING-HEATER.
Not starting straight away every time
BS, after going up and down a couple of stairs the morning after surgery I discharged myself that afternoon.
HELLS BELLS
It must be a doctor thing. The surgeon, replacing my left hip, ask me the same thing just before I lot consciousness.
Think of it as a forced vacation and relax; there's nothing you can do about it so make the best of it and enjoy the down time.
Had my left hip replaced a few years back. It went so well and easy. I was off major pain meds in a week and back at work in 4 weeks. Wishing you well and a speedy recovery
Just out of curiosity
Is that like being hen pecked? Dave Ripley and me in Hickory, NC 11/4/2018 I'm the good-looking guy on the right.
Website is going to get busy again.
Is that you, second on the left?
Lift pump
To check for a cracked pickup tube in the fuel basket fill the fuel tank; the bouncing needle will go away because the crack is covered with fuel.
Air in Fuel Line problems
GASKET, BANJO BOLT - 12MM O-rings at fuel canister. The rubber seal in the O-ring may have gone bad. https://www.genosgarage.com/product/bf-3963983/fuel-system-seals-gaskets
Power Steering Pump bad after flush?
Stay with the stock to start with and check out the relief valve on the old pump to see what went wrong.
You might have made a small burr on the housing when you drilled the valve causing it to stick/bind. Have you taken the case/reservoir off of the pump to try and access the valve. Below is a video on Saginaw pumps you may find useful. https://www.youtube.com/watch?v=7TIXOCrYPNQ
Do you still get fluid flow from any return line? The pressure relief valve (flow piston) may be stuck open; pull the pressure relief valve that you "hot rod pump mod" on and see if the valve is stuck open dumping the fluid into the reservoir and not building pressure.
Which I50 Amp Circuit Breaker
O'Rielly 150 amp circuit breaker. https://www.oreillyauto.com/search?q=150+amp+circuit+breaker
You have a point. Thinking a little deeper, if the fuse blows the alternator might just be junk, shorted to ground, and they're not going anywhere anyway.
America Today
For major co₂ reduction, population control, and protein production soylent green, in the end, is the answer
This customer can push a reset button but can't turn a wrench there for a circuit breaker not a fuse if that's what you're referring too.
I have used a 150-amp fuse on the last three W-T mods I have done and want to try a circuit breaker on the next one. So my question is which 150 amp circuit breaker did you use that is trouble free and where did you get it.
Hilary's coming to your place Mike...
It was about 50mi west of my house with a magnitude of 3.7 at just after 1am. Everything is fine, didn't even know it happened.
EXACTLY
RV Battery Isolator
I have never seen an isolator in the FSM, .
Sudden loss of lockup
I had a torque converter clutch go bad. I would have 4 gear but the trans temp would run very hot, 260°F.
