Everything posted by IBMobile
APPS sensor adjustment and reset difficulties.
Do the W-T ground mod, like Mopar Man suggested, along with the Alternator and PCM protection mod and PCM Ground Splice Repair mod. Have the batteries tested, a weak battery can cause problems. I just did those mods on a customer's 1999 truck this weekend; it brought the AC voltage down from .05V to .025V, a 50% reduction. https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/electrical/w-t-ground-wire-mod-simplified-r574/page/2/?tab=comments#comment-149 https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/electrical/alternator-and-pcm-protection-r617/ https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/electrical/pcm-ground-splice-repair-r675/?tab=comments#comment-115 You can replace the alternator brushes and diode/rectifier bridge. I bought my parts at an alternator/starter rebuild shop locally. https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/electrical/denso-alternator-diodes-and-brush-pack-replacement-r537/?tab=comments#comment-39 See if this helps with your problems before sending the ECM off for repair.
RV air conditioner questions
Be sure to install the correct amp rating fuse for the system also.
RockAuto.com cab size question - extended cab vs quad cab for headliner
Have you thought about pulling the head liner out and having an auto upholstery shop relining it or doing it yourself? I'm going to get the head liner material from an upholstery fabric supplier, pull the head liner, strip the old material off, spray with 3M 38808 Headliner & Fabric Adhesive and fit the new material. I'll do a write up on it, but it won't be until November.
Yet another setback. It's always something
Use the campground time for convalescing and mental therapy. Relax and let others due for you. May you have a speedy and uneventful recovery.
How hot are you?
Last year I rolled up to a job, it was as hot as your wife when you come home after being out with the guys till 3 in the morning, dam hot. I took out my infrared thermometer and check the temp on the side of the house in the shade, 108°F. I went to the front door and rang the doorbell, Owner answered the door where I inform him it's just too hot to work, "I'll be back another day".
Late July Jive...
Late July Jive...
Danger is my middle name.
Late July Jive...
I still have over a cord left from what i split last year. Since my wife burns it to put her in the mood, what kind of mood I have no idea, I won't be getting any more this year.
Vacuum pump issue I think
They could rebuild it with parts from Geno's https://www.genosgarage.com/product/GG10FV/engine-rebuild-kits-2 looking around, it seems that Cardone and Dorman are the two main choses for a rebuilt part.
When Banks tested the vacuum, did they do it at the brake actuator and at the pump? If at the pump, then the diagnosis is correct but if only tested at the exhaust brake, then there might be a vacuum hose or fitting that is leaking. Did they inspect those components during their diagnosis? The rubber fittings disintegrate over time
Bed mounted crane
Question, is your other truck white and just to the left in the photos?
Wrecked whole truck
That engine change in California would not pass state smog inspection therefor could not be registered for road use. The engine has to match the "under the hood " label and all emission control components installed.
My rear end stinks
Could be an axle seal that hasn't puked all over your tire yet. Get under there and sniff around. Good luck.
Just rebuilt 47re myself and it went out 5 days later
If the torque convertor had moved forward and out of alignment the truck would have never moved let alone cracking the bell housing while trying to bolt it to the engine block. No reverse and weak forward maybe a bad front drum/clutch pack and the input shaft, which is attached to the drum, may have buggered up the oil pump and the TC.
COVID Deaths after being Vaccinated
Dam... I'm going to need another vacs jab with more side effects. I resemble resent that remark.
I'm OK. I got the "purple hair" vacs before I left for camp but now, I'm going bald.
Quality Sealed Grommet Source?
Instead of drilling a new hole in the lid how about running the wire through a modified license plate light housing. Take the assembly out remove and modify the blub holder and cover to allow the wire to pass through then refit the parts. Something like below.
Sudden mileage drop
@DownHomeDieselhow about an update of what was found and repaired. It could help someone else later on.
It had to happen
There is a state insurance commissioner office that i could contact and fill out a complaint form but unless it's an egregious violation they most likely will not do anything about it. The "boss" would probably give the claims agent a letter of commendation for doing what they are supposed to do... give out as little money as possible per claim. I thought that contractor's liability insurance was to cover deficiencies in work performed, not for dumb driving. That's their policy but not the law. He should have sued in small claims Cort the post office and served the postmaster and let the judge see the video. An entity's policy is not a law so the police and courts will not enforce it. Some workers in law enforcement don't know the difference between policy and laws and will try to enforce policies. I'm very sorry to hear that but it explains a lot.
It had to happen
UPDATE, it's been 7 weeks since he ran his trailer into my truck, and I put a claim in to their insurance company, Mercury. The only response from Mercury has been a form letter saying that they're looking into the claim. Seven weeks is long enough to look into it. I turned it over to my insurance company, USAA, and let them deal with it. Got my wife a used Volvo XC90 a couple of weeks ago and put a dash cam with rear camera in it. It's recording coming and going.
Tire Size
Wish I was back on the bayou rollin' with some Cajun Queen. Wishin' I were a freight train, oh, just a-chooglin' on down to New Orleans.
Tire Size
I digress temporarily from tire size. Choogle definition, (slang) To ball and have a good time. To ball, (slang) To engage in sexual intercourse. The use of the word ball was used in this context in the late 1960's and early 1970's, I was there and heard it and used it this way. This brings more clarity to the lyrics. "But if you're a natural man You got to ball and have a good time" "Here comes Mary lookin' for Harry She gonna choogle tonight" With an automatic transmission, 4:10 differential, and 245/75-16 tires I pull my trailer and boat at freeway speed in OD. 55-65mph is 1800-2100RPM. I down shift to 3ed and slow to 55 for long uphill grades.
Lift pump shuts off after engine starts
Ok, I have an Airtex fuel pump plumbed in my fuel system with the fuse for it pulled. It is used as a backup if the belt breaks on the mechanical pump and is also used to prime the fuel system when changing injectors, vp44, or fuel filter. Try this, get a fuel container with a couple of gallons of fuel in it and enough fuel line to go from the suction side of the fuel pump to the contain, disconnect the fuel tank hose from the suction side of the fuel pump and install the new hose from the container. Prime the system and start the engine. If the fuel pressure stays stable, then the problem is in the tank or the fuel line to the pump. If it drops then it's in the pump, fuel filter or VP44.
If there was an air leak in the supply side the fuel would run back to the tank when the engine was shut off and there would be a hard starting problem due to a priming problem. You stated that the lift pump is "in-line style, original location on engine". Is it a Carter pump that looks something like this? These pumps are not reliable. I went through 3 of them in 2 years, that is why I installed a Fuel Boss mechanical lift pump.
