IBMobile
Staff
Everything posted by IBMobile
  1. That much wood in the back of my truck and it's on the helper springs. Nice log splitter there.
  2. IBMobile replied to DrJekyll86's topic in Introductions
    @DrJekyll86welcome. This is the place to be to help keep your truck running trouble free. You might want to do these wire mods in conjunction with the W-T mod. https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/electrical/pcm-ground-splice-repair-r675/?tab=comments#comment-115 https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/electrical/alternator-and-pcm-protection-r617/
  3. Right you are. My pic is to illustrate what 245/75 R16 tires look like on a stock suspension 2WD truck. @Mopar1973Man picture shows what 245/75R 16 tires look like on a stock suspension 4WD truck.
  4. Stock wheels with 245/75 R16 47RE 4:10 gears
  5. This is where my manual boost adjuster is mounted, the top of the alternator bracket.
  6. These are the line pressure numbers after @Dynamicrebuilt the transmission in 9/2019. Air temp 91°F Transmission fluid temp 165°-190°F Line pressure, transmission in drive: no throttle stopped 85 PSI light throttle 2ed gear 105 PSI light throttle 3ed gear 110 PSI light throttle 4th gear 120 PSI @ 2200 RPM W/O throttle 1-2 shift 180 PSI @ 2800 RPM W/O throttle 2-3 shift 175 PSI @ 3100 RPM W/O throttle 3-4 shift 150 PSI W/O throttle 4-3 shift 150 PSI 100% throttle 4th gear TCC locked @ 70 MPH 160 PSI 0% throttle 3ed or 4th gear TCC locked down hill slowing 100PSI reverse gear stall test 330 PSI
  7. Congratulations but I've seen your luggage and a paper bag with underwear doesn't count.
  8. Maybe I missed this but are you getting fuel out of the lines 4,5, and 6? and how much?
  9. Let's not forget about the next maybe "pandemic" coming down the pike, monkey pox. They are slowly ramping up the hysteria over this one. As of 6/10/22 "Public health officials have identified 45 cases of monkeypox across 15 states and the District of Columbia, up from 21 the week before, while more than 1,300 cases have been detected globally in 31 countries." ¹ The US now has over 100 million doses of smallpox vaccine with almost another 2 million either ready for shipment or being produced. ¹U.S.News
  10. Deisel fuel to go to $10/gal by this fall. Price of food to double by Sept-Oct, from what it is now, due to increase in production (diesel) costs Wheat shortage due to war in Ukraine which is the 5th largest wheat producer and known as the breadbasket of Europe. There will be famine in the world this winter. Wheat price has gone up 18% since January. Price of heating fuel oil has doubled in a year and is still increasing. The cost of LNG is going up due to supplying Europe after shutting off Russia's pipeline and lower US inventory. Housing market in in a nosedive due to overbuilding and rising interest rates, you may see a repeat of the 2008 housing market.' Let's go Brandon! They got what they voted for.
  11. These two articles might help. https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/electrical/alternator-not-charging-testing-voltage-control-r538/ https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/electrical/alternator-and-pcm-protection-r617/
  12. Is that for both sticks and auto transmissions?
  13. Hand calculation is the only way to get a true MPG reading. Be sure the speedometer/odometer reading is correct for tire size. When I changed my tire size from 265 to 245 75- 16 there was a + 3.2% error, at 60MPH the speedo was reading 62.
  14. @JAG1, just off the phone with Glenn and told him about the campgrounds you found northern CA. He says he might be interested in them and want more info. If anyone else knows of good campgrounds north of Reno or Susanville, please chime in.
  15. You're probably already doing this. Pre lube all parts before assembly.
  16. I can't afford to use a diesel pump, so I haven't experienced that problem. Cheapest diesel price near my house is $6.59/gal.
  17. Above was two short years ago and now, they got what they voted for.
  18. When my torque convertor failed it would not lockup and the trans temp would be very hot going up hills pulling my trailer.
  19. From FSM: intake valve lash .006"-.015" exhaust valve lash .015"-.030" Note: If measured valve lash falls within these specifications, no adjustment/reset is necessary.
  20. WIXS makes the NAPA Gold filters. A list of BHAF https://mopar1973man.com/cummins/articles.html/24-valve-2nd-generation_50/51_engine/air-exhaust_56/big-honking-air-filter-r566/
  21. Yes, Call @Dynamic. He rebuilt @Mopar1973Man and my transmissions. 8311 N. Glenarvon Lane Newman Lake, WA 99025 - (503) 880-5451 He is listed in the vender section.
