- Replies 55
- Views 8.5k
Evan 12 posts
wil440 9 posts
Mopar1973Man 6 posts
dripley 6 posts
I know the angst you had. After following Jag1 up and down the cow paths of Oregon my trans fluid was dark in color and it was only a couple of thousand miles old. I use Valvoline synthetic.
I bump pressure to 120psi and run tractor transmission fluid in it. If tools and ability to learn is high put shift kit in. But can bump oressuwith out a kit. Put borge Warner
dont concern your self with HP...pay attention to Torque. the 47re is a 700lb ft torque number...in my case, i am right at that point, hence why I feel it has lived so long.
Morning guys, I’m wondering what I will need to have my trans hold 350 hp and reliably tow? I have a deep pan on the way and planning to do a lockup switch. I’m thinking I will do a set of rv275s and a small tuner of choice. So that’s about all I’ll be doing for power. Also what do I need to know about monitoring trans temps? What is to high and what is safe?
Edited by JAG1
