Would You Invest in My Truck or A Newer Truck
- Replies 56
- Views 10.5k
Mopar1973Man 7 posts
JAG1 7 posts
NightHawk 6 posts
The_Hammer 5 posts
tank the monthly payment amount you would be spending and save it for 6 mo or a year. then see if your thoughts are different. me. i went to a 3rd gen and love it. but have to admit i miss my 02.
In the end, it comes down to what YOU want. If you really like the truck, fix it and roll on. If you want something new go for it! What I will say is these trucks are easy and cheap to fix. Ever
It isn't always that we don't value our time, but some of us bought a second gen when we should have bought a third gen and now are kind of stuck in the decision. I have a paid for truck that
Hello Everyone,
I have been going back-forth for several months now on if I should invest in my truck or a newer truck.
Now it must be stated that my current 2nd gen has been nothing short of awesome to me, always completed the task asked (towing, road trip, hauling) but its now 15yrs old with 171k miles. I just got back from another road trip to visit my friend out of state (360 miles each way) and I came to the conclusion I either need to invest in my current rig or search for something newer (3rd /4th gen).
The below list are the items I know of my truck would require to be invested in (not necessarily in order) to be 100% in my book (some may not be necessary to others). Let me know what you think and thank you !
Cracked Dash (all cracks repaired with epoxy, doesn't look the best but covered by a dash mat)
Driver's Side Heated Seat No Longer Works (pad has broken connection, annoying to me)
Drive's Side Power Seat Back Switch is Toast (requires a whole new control panel)
Driver's Side Seat is ripped along the seam (needs to be re-stitched)
Stereo speakers are worn and sound fuzzy ( annoying to me)
AC isn’t “cold” anymore
Four New Shocks (original set still on truck !)
Track bar bushing are worn (original set)
Control Arm bushing are worn (original set)
Sway bar bushing are worn (original set)
Two New Batteries (they are 5 yrs old and starting to cause corrosion issues @ terminals)
Two New Battery hold downs (corrosion issues from batteries)
Terminals/grounds need a cleaning (time investment-not money)
Stock Headlights are faded (restored them twice with a kit but doesn't last long)
Stock Foglights are faded/cracked
Transmission (auto) leaks @ the pan (bent pan)
Transmission (auto) leaks @ the shift selector shaft (bad oring)
Leaks oil from @ supply line vaccum pump connection (drips after 3-4 days of sitting, non running)
Exhaust System is rust/rattly (annoying to me but works fine)
Stock Air Box leaves something to be desired (works fine, but like the S&B dry filter setup)
Front Grill cracked in places (needs to be replaced)
Front Bumper plastic is faded (looks terrible in my view)
Rear Bumper is bent and needs to be replaced
Sport Mirrors aren’t the best for towing
