5.9 engine blocks, Killer Dowel pin a concern?
- Replies 18
- Views 7.9k
dripley 5 posts
CTcummins24V 2 posts
Me78569 2 posts
notlimah 2 posts
Gear case bolts can come lose and fall out also.
I have to assume the KDP is what I am pointing to in the picture. Have not seen a photo of one in a long time. Mine is recessed maybe 3/16" maybe less.
Not true. Dave Conrad (Fishin2Deep4U) posted the work slip from his Dad's '02 that had it fall out. Not as prevalent but still the possibility. This is not the repair slip which I could no longer f
2001 coming up on 100K. Do all late 90's and early 2000's have killer dowel pin problem or just the 53 block? I know my odds of a failure are slim; coming up on 100K. But want to make sure. I'm unsure if "Mexican" block cracks more than the "53" series or if the killer dowel pin getting loose and falling is prone to one block or another or both?
Thanks
