Filling oil filter when changing oil?
Well seasoned school bus mechanic tells me when they get somebody new changing oil it's only about 2 weeks till they stop filling up new filter with oil before threading on new filter without prefilling.  Interesting part to me was no failures that he knows of.  I fill mine but wondering if really necessary. Other than manual says so.
Do you prefill?
  • Replies 208
  • Views 39k
  • I will ALWAYS pre-fill an oil filter if possible.  Been doing this for decades and will continue to do so too.  The whole "you can pour something into the filter by accident and it will get into the o
  • Very interesting discussion gentlemen. It is good to see two folks of differing opinions have a sane discussion. Now if we could just get congress the learn that ability they they might be able to get
  • I've been trying to live by a new creed after 65 years and 44 years of marriage.   I stopped explaining myself when I realize other people only understand from their level of perception, not
After just having my oil line off for the head gasket it was still clean.
4 hours ago, AH64ID said:
Actually they do.. just not the same style as HO. They have to have some sort of piston cooling jet as the piston cooling jet is also what lubricates the wrist pin/bushing.
Interesting...  I've read many times that Cummins added the oil cooling jets on the HO motors.  I didnt realize that it was simply a different type.  Good to know too because I always wondered how the SO motors survived. :thumb1:
I think the ISB is a plastic cooling jets if I'm not mistaken. There is an upgrade for metal cooling jets.
You are actually not too far off. Back in the day before the 5.9, the big truck engines did not have them. I think that is where most of the horror stories of melted pistons originated from. Back then, melted pistons was real, on turned up trucks.
I have pre filled just a little. Most times I forget and dont prefil
Im not worried about it being unfiltered oil, cause its brand new oil right out of he jug and I do oil changes in a clean room at a hospital and I dont change oil during a sand storm or in a rodeo arena with bulls and horses kicking dirt all over the place :thumbup2::lmao2:
Edited by GSP7
I love rodeo arenas, hate hospitals. After Obamacare I'd rather take my 'cleanliness' chances in a rodeo arena. OK, I'm done :ahhh:
How many folks have had an engine failure due to pre-filling their oil filters with the 'dirty' new oil ?
That is an interesting question that can't be answered. From the comments above we have all taken different directions to the issue. There is no way that one oil change is going to kill a motor. I have gone both ways thru my 50 years of driving and only lost two motors. One thru total oil starvation, ask the wife about that one. And one on the V10 when it blew shortly after an oil change. Always thought they put to much oil in but by the time it blew the engine had spit the oil out thru the tail pipe.
 I have 455k on mine with lots of idling and it still runs fine. I do have a weeping HG at the t'stat that needs to be dealt with soon. That is coming soon.
 So I say take your choice and run with it.
I don't know about you guys... everyone knows these are spark plug boots.
- John
- John
 Your CTD has spark plugs?
:shrug:
- John
Glow plug harness connectors! :lmao:
- John
:shrug:
OMG... :duh:
10 minutes ago, Mopar1973Man said:
OMG... :duh:
Yes spark plugs and wouldn't be best to have oil analyzed before putting it in, you know to make sure the oil is good?
I think that's why @TFaoro rebuild his engine due to clean dirty oil. I don't think I ever figured out why he did rebuild it, other than that.
If the oil is so dirty I wonder if that's why the cylinder wall look good because that oil is filtered first. Where the oil I poured in the valve cover ate the valve guide? :shifty:
Yeap, we're finally on to something here
Seriously this why I don't buy into the hype of synthetic oils and name brands. As long as the oil meets or exceeds the requirements of the engine use it. Our engines require CI-4 or better and typically 15w-40 viscosity is fine for most normal operation. Synthetic oil is not required. The only thing about filter filling I would heed the warning about filling the oil filters. Long ago there were reports of the oil cooling nozzles being plugged up with debris. Some of this came from the Fram oil filter problems and other came from debris falling into the center hole of the oil filter. (foil cover). Either way, anything placed in the center hole is unfiltered oil head for the bearing and cooling nozzles.
Myself, I typically do not fill the filters anymore. Startup to oil pressure is typically 2 seconds tops. After having the head off and seeing the cylinder walls I was happy with the oils I'm using and plan on continuing down that path. Like currently running Delo 15w-40 CK-4 oil. I'm currently using NAPA filters being the frequency of my oil change is very short in time but still 7k thereabouts.
I saw a guy change to synth one time... after about a hundred thousand there was oil all over the engine from leaks. It was incredible how he thought it was so good and kept going on and on about how I need his car not to go looking at any others. He was college professor. Of course I walked away and found a real cream puff, no leaks, no tappet noise etc for 5 thousand bucks. It served us well for a long time on fred flintstone oil rinses every 5,000 miles.
