Junior's truck needs work... a lot of work :-(
- Replies 21
- Views 5.6k
dodgedieselnewbie 4 posts
wil440 3 posts
JAG1 2 posts
Bullet 2 posts
Newbie, Sorry you are taking it that way. I don't see anyone that responded, intended for you to take it that way. That is a huge list. Most of those things I have performed
Doesn't sound like the purchase was well thought out...or that any thought was applied at all. He should sell it and use a little more brainpower on his next purchase. Otherwise he could save you th
I agree with all the above, to own one of these trucks you need to be mechanically inclined unless you have money you don't need. Best to shop around and do the work yourself, even if you have t
Hey all... My son bought a 98.5 about a year ago. He brought into a shop for something (can't remember) and they dropped a bomb ... but said otherwise... runs fantastic. I haven't been keeping up to date with things... So, I'm here asking for guidance/recommendations as far as making sure he gets/uses quality parts... please.
I don't know what a PCS BIG BORE GEARBOX is. Is this good? Is Redhead still a good or a better choice? Should he go with Dodge Off Road steering brace as well?
What track bar should he go with? Dodge Off Road?
Shocks? Bilsteins still a great choice? Which model? Stock height...
Are all ball joints created equal?
Does this quote seem reasonable?
Ball Joint 2.00 109.48 218.96 K8607T
Ball Joint 2.00 72.98 145.96 K80026
Wheel Hub Assembly 2.00 202.98 405.96 515012
Stabilizer Bar Link 2.00 88.30 176.60 K7280
Stabilizer Bar Bushing Kit 1.00 32.96 32.96 K7352
Track Bar 1.00 206.02 206.02 DS1413
Tie Rod End Adjusting Sleeve 1.00 43.55 43.55 ES2012S
Tie Rod End 1.00 103.59 103.59 DS1458
Tie Rod End 1.00 94.17 94.17 DS1459
Tie Rod End 1.00 96.54 96.54 ES3496
Shock Absorber 2.00 85.82 171.64 911103
Shock Absorber 2.00 83.05 166.10 911104
Multi-Purpose Seal 1.00 15.00 15.00 5131
Multi-Purpose Seal 1.00 12.57 12.57 710241
GEAR OIL 4.00 10.00 40.00 1
Wheel Stud 1.00 3.67 3.67 610-218
PCS BIG BORE GEARBOX 1.00 700.00 700.00 PSCSG852K3
Steering Shaft 1.00 252.37 252.37
REPLACE BOTH INNER AXLE SEAL, BALL JOINTS, 900.00
HUBS REPLACE ALL CONTROL ARMS 270.00
REPLACE GEARBOX, AND STEERING SHAFT 180.00
REPLACE ALL STEERING LINKAGE, TRACK BAR 180.00 AND SWAY BAR LINKS AND BUSHINGS REPLACE LR WHEEL STUD 90.00
REPLACE SHOCKS ALL AROUND 162.00
ORING 1.00 15.00 15.00 1
ROTELLA 3.00 16.00 48.00 1
OIL FILTER 1.00 12.00 12.00 1
COOLANT 3.00 15.00 45.00 1
ATF 2.00 6.00 12.00 1
Serpentine Belt 1.00 40.20 40.20 K080810
Water Pump 1.00 59.45 59.45 CP7145
Valve Cover Gasket Set 1.00 27.24 27.24 PS50397R
Rear Main Seal Kit 1.00 50.08 50.08 BS40650
Timing Cover Gasket Set 1.00 50.94 50.94 TCS45994
Valve Cover Gasket Set 1.00 175.32 175.32 VS50506R
RESEAL INNER TIMING COVER, OIL PAN, AND VALVE COVER, TAPPET COVER, WATER PUMP REPLACE 2,700.00
DIAG AND REPAIR LOW PRESSURE FUEL SYSTEM SENSOR 90.00
Looking at $5000.00... Let me know if you think anything is out of line and any suggestions you may have. Thanks a million!
Also... if anyone can recommend some place within an hour or so of the Phoenix area for him to take to for a second look......
Edited by dodgedieselnewbie
