killer dowel pin question
  • Replies 44
  • Views 15k
  • pepsi71ocean
    pepsi71ocean
    You have to open it up and look from the inside. I wish Cummins would have marked them, but were not that lucky.
  • You have to remove the front gear cover. That requires removing  several items off the front of the motor and the radiator if you want  more room. None of it is difficult. Some folks say a few hours,
  • @Dieselfuture, I apologize for my dry sense of humor.  I did know what you meant and actually I am in the same boat with my 2002 truck.  I will also be checking my potential KDP when it is becomes nec
Another fairly easy way to pull the fan is to put a pair of slip-joint pliers (otherwise known as Channellocks) on the big nut and then use a 2x4 (or something similar) and place it on the handle of the pliers to stick up just above the radiator. Then use a decent hammer and smack the end of the 2x4. It will break the nut loose with a couple of good smacks. Just using hand tools I can tab a pin and put a new seal in in about 2 1/2 hours and not rush it.
Which bolt would that be that you had to grind down a wrench? What size was it, and how far down did you grind it?
It's the one in behind the pulley,3/8 I think, and just far enough so the wrecnh slides in
Is there something different about the 2nd gen 24 valve dowel pin? On my first gen I first hammered the the dowel pin in with a straight punch, then peened the curcumfrence with a center punch. No way it's ever comming out. I dont know understand why a kit is avail unless there is something different about the 2nd gens.
Not sure about the 1st gen.The kit for the 2nd gen that I used came with a flatten and stretched washer and a front seal to use after removing the cover. Also while the cover is off be sure to remove the 5 bolts [one at a time] clean the threads put a little BLUE Loctite on then re-install and torque. On mine one of the five was only a little tighter then finger tight.
  • 5 years later...
1 hour ago, 4Hchugalug said:
What’s the best way to get to the kdp?
You have to remove the front gear cover. That requires removing  several items off the front of the motor and the radiator if you want  more room. None of it is difficult. Some folks say a few hours, me it is at least an all day job. I dont rush myself.
  • Fan belt
  • Fan assembly from the block.
  • Crank dampener
  • Radiator (optional)
I've done mine like I said pull the belt and the fan assembly and left the radiator in. Pull the crank dampener and you should be able to pull the gearcase cover. If you pull it make sure to have a fresh crank seal ready. Now install the crank seal into the cover. Another member had a killer write up showing that you can buy 4 or 5 long bolt cut the heads off and use it for alignment dowels to slide the cover back in place. With the alignment dowels, you can get the seal over the crank much easier. Sad part the pictures are all lost to the Photobucket issue.
By doing what is said above in this thread. I worry not knowing if my trucks have the KDP or not. I have an 01 and an 02. It's less likely the 02 was built with a KDP, but no way to know for sure.
They all have the dowel but as I understand the hole in the later cases is stepped to prevent the pin from coming out. Here it is in my 02.
The two differences I saw in my gear case and one for a 99 is the bulge in the case just below the second bolt hole above the pin and the thickened area of the case between the 2nd and 3rd bolt hole below the pin. On the 99 there was no or thickened area. Whether that is indicative of a safer case I dont know for sure.
Didnt see this mentioned...but aside from other bolts comong loose...there is a KDP kit that does NOT require disassembly. It locates and drills a dowel from out side the case.
  • 4 months later...
Here is my 02. I aint worried after 17 years and 460k. But who knows.20170528_134611.jpg.2f4fa93b3a188aacdfb90e23a9bad0bd.jpg
PLOP... Out fell the pin.
@dripley has an upgraded case.
The old case was flat between the pin and the bolt and most tabbed the pin by grinding a fender washer to a teardrop shape and using the existing bolt to cover the pin.
2 hours ago, Dieselfuture said:
Can't wait for front seal to leak
Maybe the KDP will fall out and make it leak sooner, then your wish would be granted.  Of course, then there might be other minor things to repair as well.
- John
- John
Not entirely what I meant, I was just saying if my seal would leak I'll have a reason to remove the cover and find out what case I have. Changing the case is not a minor repair, I don't even know what I would do if that ever happened. Probably fix it then move on I suppose.
End up pulling the cam out to replace the gear case.
@Dieselfuture, I apologize for my dry sense of humor.  I did know what you meant and actually I am in the same boat with my 2002 truck.  I will also be checking my potential KDP when it is becomes necessary.
Of course, we could schedule replacing the seal as a maintenance item instead of waiting for failure (oops, there goes my humor again)..  After all, it's not like we haven't gotten the miles out of the seal.
- John
21 hours ago, Mad Bomber said:
We had a 02 with a dropped KDP under warranty in the NW
That's true.  Dave Conrad's Dad.  Fishin2deep4U.  After it happened Dave posted the repair receipt.
On 5/6/2013 at 11:47 PM, Lone Watie said:
All I know is that some early 24V were susceptible to the KDP issue, and some were manufactured with a stepped case which supposedly won't allow the pin to fall into anything critical. Mine is a 1999, so naturally I'm a little concerned, and for peace of mind will be taking a look at it soon. At best, I have a stepped case and I'm safe, at worst it is still in place and either hasn't and won't, or hasn't and will.
If it helps, I have a 1999 and did have the stepped case in mine. But I did go back and re-torque the case bolts just to be safe.
Pull the timing cover off the front of the motor. I pulled the front of the truck apart when i did check mine.
