MAP Electrical connnection plug - how do you do it ?
IAT and ECT sensors run on the same ohm scale.[TABLE][TR][TD=width: 50%, bgcolor: #3870cc, align: center]Temperature[/TD] [TD=width: 50%, bgcolor: #3870cc, align: center] Resistance[/TD] [/TR] [TR] [TD=width: 50%, align: center] 13°F[/TD] [TD=width: 50%, align: center] 56K ohms[/TD] [/TR] [TR] [TD=align: center] 26°F[/TD] [TD=align: center] 39K ohms[/TD] [/TR] [TR] [TD=width: 50%, align: center] 87ºF[/TD] [TD=width: 50%, align: center] 7.4K ohms[/TD] [/TR] [TR] [TD=width: 50%, align: center] 91°F[/TD] [TD=width: 50%, align: center] 6.8K ohms[/TD] [/TR] [TR] [TD=width: 50%, align: center] 100°F[/TD] [TD=width: 50%, align: center] 5.6k ohms[/TD] [/TR] [TR] [TD=width: 50%, align: center] 107°F[/TD] [TD=width: 50%, align: center] 4.7K ohms[/TD] [/TR] [TR] [TD=width: 50%, align: center] 112°F[/TD] [TD=width: 50%, align: center] 4.3K ohms[/TD] [/TR] [TR] [TD=width: 50%, align: center] 119ºF[/TD] [TD=width: 50%, align: center] 3.6K ohms[/TD] [/TR] [TR] [TD=width: 50%, align: center] 123ºF[/TD] [TD=width: 50%, align: center] 3.3K ohms[/TD] [/TR] [TR] [TD=width: 50%, align: center] 127ºF[/TD] [TD=width: 50%, align: center] 3.0K ohms[/TD] [/TR] [TR] [TD=width: 50%, align: center] 132ºF[/TD] [TD=width: 50%, align: center] 2.7k ohms[/TD] [/TR] [TR] [TD=align: center] 143°F[/TD] [TD=align: center] 2.2k ohms[/TD] [/TR] [TR] [TD=align: center] 148°F[/TD] [TD=align: center] 2.0k ohms[/TD] [/TR] [TR] [TD=align: center] 163°F[/TD] [TD=align: center] 1.5k ohms[/TD] [/TR] [TR] [TD=align: center] 173°F[/TD] [TD=align: center] 1.2k ohms[/TD] [/TR] [TR] [TD=align: center] 184°F[/TD] [TD=align: center] 1.0k ohms[/TD][/TR][/TABLE]Best way to test both is to use a live data tool and see what the ECM sees. Ohm values out in the open can be skewed by just handling the sensor with your hands your body heat will cause then to rise.P0216 just means the ECM commanding for advance timing and the pump is no longer capable of getting the advancement cam to move in a timely manner. POOF! P0216 code thrown. If the electronics on top (PSG) were bad you'd see a P1688 code most likely.Be careful of the cardboard with the hole in the center you keeping the fan clutch cool and unlocked so its possible to actual get to hot.
Arrrrrrrrrr mike!
Yes. Like this... http://articles.mopar1973man.com/general-cummins/34-engine-system/144-compression-testing
AC Voltage Leak
Most likely the diodes are just cheap as you adding load to the electrical system the diodes start to heat up and fail. Just because the alternator was bought new doesn't mean its a quality unit either. I've seen reports of brand new alternators failing the AC test out of the box. I would have the alternator serviced at that alternator shop and have it done right. You might disconnect the alternator all together (field and alternator fuse) and test again with headlights on and see if the HIDs are generating the AC noise.
Tire Pressure Calculation
I know I'm reviving a old thread but I've updated the formula page with correct dual formula so people with dually rear axles can calculate proper pressures now. Show a demo of Formula vs. Table pressures from Michellin. Axle Weight: 4,850# on Single Tire Axle Single Tire Forumla: (Axle Weight / 2) / Tire Capacity weight x Tire Max Pressure = Inflation Pressure (4,850# / 2) = 2,425# / 3,042# = 0.79 x 80 PSI = 63.7 PSI Axle Weight: 8,820# On Duals Rear Axle Dual Rear Tires Formula: (Axle Weight / 2) / (Tire Capacity weight x 2) x Tire Max Pressure = Inflation Pressure (8,820 / 2) = 4,410# / (2778# x 2 = 5,556#) = 0.79 x 80 = 63.4 PSI Take note on duals tire axles you got to double the 2,778# rating of the tire and then divide your axle weight. But with both sets the pressure number is right there within 3 PSI of the tire pressure chart of Michellin.
Loss of Power
Maybe a bit more information. * What's your fuel pressure like? (Idle and WOT at highway speed)* Any error codes?
Oil pump housing failure, probable rebuild...
So the oil filter did its job huh?
Hood sound insulator
UV's is my though on that. The 1996 Dodge was left outside most of its life here and the paint that is exposed to direct UV's rays seems to be failing. Roof and top of hood. But the doors and fenders are fine and good condition.
Never had the pad on my truck but the 96 HAD it past tense. I yanked it all out for exactly what Flagmanruss just mention.
I agree with Bill I would rather be the one to tear down the engine looking at all the damages one piece at a time and documenting everything. Then have a shop look it over as well and between the two make a judgment call on what needs to be replaced, repaired, etc. I know on the assembly process I would do my own if all parts had been machined for me to fit. But usually its just easier for a shop to assemble it for you. Something about taking the time and effort into making this kind of repair really gives you a big learning curve and then being proud of being capable of doing the job as well. As for me I've done a few V8 360's and 318's and even a 383 out of the Charger in my days.
Finally made the leap..
Work. As for jobs and making a bit of money as long as you keep your mind open to almost anything you can always find a small job for extra cash. Like tonight I got a Fire Dept meeting and I'm going to talk to my Fire Chief about bringing his 06 Dodge down so I can change the clutch in his truck. In the past I use to help a friend bone out wild game and make money doing that. I've been as low as dish pit in a local restaurant to manager of a motel. Done all this right here in Idaho. What's amazing about this is all these jobs I've never done before but if you open minded and willing to learn why not?
Here is the battery I'm using. http://www.trojanbatteryre.com/PDF/datasheets/L16REB_TrojanRE_Data_Sheets.pdf Typically you get about 12-15 years from a set of batteries as long as they are maintained properly and and not discharged too deeply. I still have a re-occurring power bill but its trimmed way down during the summer to like $30-$40 bucks tops winter time it does go up to about $100-$130 tops. Power outages around here are very common place in the storm seasons and outages might last for days sometimes longest I've seen is 14 days without power. I opted for the wet cells because I can maintain the electrolyte much better and equalize charge the batteries monthly to keep the sulphation down to minimum. As for AGM or gel cells you end up paying more for a battery but typically the life span is much shorter because both batteries are sealed and do vent moisture over time and then fail once the cells dries out.
gird heater
I'm also the same way light frost and wiper solution will typically knock it off. But heavy snow or ice build up is a different story and the good ol' fashion ice scraper comes out. I would typically at this point fire up and set the 3 cylinder high idle and exhaust brake. By the time I'm done scrapping the entire windshield the heat has caught up enough to get the last little bits by the time I start moving. But this is rare for me. I typically store my truck in a unheated shop.
Hey wait what am I drooling about I live in the woods. :doh:Somewhere along that line you should consider power options. I see you'll have plenty of firewood for heating all winter long.
No. I never seen it happen with my truck when getting fuel slosh below 1/8 tank. This pump has never tripped a P0216 code yet. The only time you need to clean these sensors is if you own a Exhaust Brake. If not there should be zero reason to even pull them. Heck even with my Exhaust brake I quit pulling the IAT sensor and MAP a few years back to see if I could actually foul the sensors. Has not happen yet.
gird heater
So very true. The only other way to warm up a truck quickly is with high idle and exhaust brake. This way you create a virtual load for the engine and create heat. Don't want to do that either that a wonderful way of destroying the alternator being its only rated for 140 Amp tops and you dropping a excessive load of 195 Amps on for 2-5 minutes most likely overheat the alternator in a quick hurry.
Hello from Ca
Radio mostly. But the steering wheel controls went back over to the Central timer to be sent out on the CCD network. So its the central timer and the radio as a communication pair. Still a easy way is to measure the CCD voltage and see if there is 2.49 and 2.51 volts in reference to ground. If not start unplugging all the accessories one at a time looking for the voltage to return. The one that allows it to return is the failed unit. You only need PCM, ECM and instrument cluster to work.
I suggest you practice with the ABS computer plugs first being they are right in front of you and easy to look at. But Bill is right just slight the red tab over and then squeeze the release and lightly tug it will slide right off.
gird heater
Only to a point. I would imagine if the intake air was heated to 120-140*F constantly it should improve warm up times. That's the way it was back in the 1970's muscle car they had a thermostatic vacuum valve that controlled heated air for the air cleaner to air in warm up times. But some where in the 80's that all went away and Cold Air Intake was the rave and electronic fuel injection came out. EGR isn't a good thing in any sense. All you doing is fill the manifold with CO2 and heat and not making a burnable mixture for the next cycle. But heated air would help out I don't see any reason why it won't.
Stihl MS 260 Pro
You might try talking to my guy that does my saw work. http://www.yellowpages.com/ontario-or/mip/drapers-outdoor-power-equipment-4199353
02 cummins overcharging after external VR installed
40 warm up cycles to self erase codes. I would personally just erase the codes with a OBDII code reader and take it for a test drive and then check again to see if the codes returned. If so then you'll have to deal with the codes.
It's a different life style that's for sure. Just give your self time to adjust and don't let it get you down. Like for me moving from Los Angeles, California to New Meadows, Idaho was a huge step. Now today I couldn't imagine moving to California or even Boise, Idaho to live. Just way beyond me.
Hello from Ca
Correct. The Radio is on the CCD Network because of the remote steering wheel controls in the upper models. So the remote steering wheel controls sent there data over the CCD Network to the radio to turn volume up and down or tune to your favorite station.
Timing a VP44 - Quest for MPGs..
Ummm... Product will be out very very soon... http://www.dieselautopower.com/product_p/high-idle-switch-98-02-cubby.htm
greetings from ABQ NM
I'm all over the place. I'm always working on something somewhere. But welcome to our little family here.
Announcement
Everyone is just one big happy family. There is times when some family member don't see eye to eye but we all get along. So welcome to the our little family of Cummins diesel nuts.
